| Sail/Storage tube #186370 07/28/09 03:16 PM 07/28/09 03:16 PM |
Posts: 171 Cary, NC | Anyone know where to pick up one, or better yet have one that they would want to let go for cheap near Raleigh? I am upgrading the trailer for the Isotope and would like to add one.
Ryan 1983 Isotope
| | | Re: Sail/Storage tube
[Re: Storz]
#186373 07/28/09 03:32 PM 07/28/09 03:32 PM |
Posts: 6,049 Sebring, Florida. | Try any big irrigation supply outfit, check the yellow pages. They should have rather large water pipe (PVC tubes, 12" diameter or more) and you can have them cap one end and put a screw top on the other, or both ends. I have no idea what they cost but I've seen lots of them on trailers. I've got a smaller one on my H14 trailer, (6") just big enough for the boom and mainsail.
Blade F16 #777
[Re: Timbo]
#186376 07/28/09 03:39 PM 07/28/09 03:39 PM | DougSnell
| DougSnell
Unregistered | Try any big irrigation supply outfit, check the yellow pages. They should have rather large water pipe (PVC tubes, 12" diameter or more) and you can have them cap one end and put a screw top on the other, or both ends. I have no idea what they cost but I've seen lots of them on trailers. I've got a smaller one on my H14 trailer, (6") just big enough for the boom and mainsail. Home Depot use to sell them. Doug | | | Re: Sail/Storage tube
[Re: Timbo]
#186378 07/28/09 03:53 PM 07/28/09 03:53 PM | andrewscott
| andrewscott
Unregistered | I have no idea what they cost but I've seen lots of them on trailers. I looked into this a few years ago.. it was when the cost of gas was sky high .. but 12" tube was going to cost me about $250. I was FLOORED!!! i ended up getting a crappy used tube for around $75. It weighed about 75 lbs. it worked ok.. but it wouldn't fit my sails when i upgraded from a TheMightyHobie18 to my mystere. I hear / know Treys box's rock. and i am sure they are worth every penny... but its so hard to part with $400 (or whatever the exact cost was) when my sails fit in my car (but it sure stinks carrying them up and down 3 flights of stairs every time i ended up getting the worlds crappiest aluminum box for $40. it stinks but works... | | | Re: Sail/Storage tube
[Re: ThunderMuffin]
#186379 07/28/09 03:55 PM 07/28/09 03:55 PM |
Posts: 3,293 Long Beach, California | I have a Lunchbox. Make the investment - you'll have it forever, he sells them at a very good price, and they are worth as much or more than the original cost if you ever decide you need to unload it. Do a search on this forum - there are threads about cat boxes every couple of months.
[Re: Storz]
#186388 07/28/09 07:20 PM 07/28/09 07:20 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH
Posts: 329 Chicago, Illinois USA | If you decide to go the cheap route, here is one of the manufacturers of the black corrugated tubes (with smooth inside pipe). http://www.ads-pipe.com/en/product.asp?productID=177 There is one other manufacturer that I know of, but I can't find the web site. I went to their web site and got the local rep number and called to see who the distributers were in Chicago. They come in 20' lengths, but the distributer I went to cut it and sold me a 10' section. Cost about $80. The end caps are around $35, but I picked up a design for an end-cap from the guys in CRAW using outdoor ply. On the plus side, these are cheap, hold quite a bit if you get the 12" diameter and they are light and easy to secure to the trailer. On the downside, they are kinda ugly. PM me if you want to see a picture.
Blade F16 USA 725
[Re: davefarmer]
#186399 07/28/09 10:40 PM 07/28/09 10:40 PM |
Posts: 1,383 Kingston SE South Australia | Just my thoughts Dave I do a bit of roofing with galv it doesn’t handle other metals at all not even touching a newer piece of galv. You might have to be careful storing sails in the galv tube even if they’re dry, condensation forms really easy with galv and everywhere stainless or aluminum touches the galv electrolysis will start which will stain your sails as they slide in and out. regards
[Re: carlbohannon]
#186456 07/29/09 12:14 PM 07/29/09 12:14 PM | andrewscott
| andrewscott
Unregistered | I talked to 3 pvc suppliers and they were all in the same range. one refused to cut a 20' section.
in the end i bought mine (used) from a local hobie dealer that had a few in the yard. It was an exciting drive home with a 11' tube sticking out my passanger window... i scared a guys on the bike path!
[Re: Storz]
#186563 07/30/09 01:20 PM 07/30/09 01:20 PM |
Joined: Nov 2006 Posts: 30 Lake Norman, NC Doug_P182_LKN
Posts: 30 Lake Norman, NC | Take a look at some commercial construction sites in and around the area. I found mine as a piece of scrap that they let me haul away for free. 18"x 3/4" thick sewer pvc. I cut 2 feet off the ends, cut them in half to make 4 hull cradles. Two painted plywood cradles bolted to the trailer and end caps. Maybe I put $50 and 8 hours work into it. That was 8-9 years ago and it's still holding up. I'm 228-lbs and can stand on one of the four cradles without it breaking. I had posted pictures of the rig here once before. Just remember to take BOTH end caps off the tube when you launch the boat off a ramp and sink the trailer. Especially if your end caps are sealed. If you leave the front one on, that much air volume can and will float the trailer, boat, rig and all. How do I know?
Doug Bernstein Prindle 18.2 'Special Treat' #590 Lake Norman, NC
[Re: Doug_P182_LKN]
#186565 07/30/09 01:29 PM 07/30/09 01:29 PM | andrewscott
| andrewscott
Unregistered | Just remember to take BOTH end caps off the tube when you launch the boat off a ramp and sink the trailer. SINK THE TRAILER???? why would you need to put your trailer more than 1/2 wheele deep? | | | Re: Sail/Storage tube
[Re: ]
#186575 07/30/09 03:30 PM 07/30/09 03:30 PM |
Posts: 30 Lake Norman, NC | Just remember to take BOTH end caps off the tube when you launch the boat off a ramp and sink the trailer. SINK THE TRAILER???? why would you need to put your trailer more than 1/2 wheele deep? Well of course you don't need to sink the whole trailer. In fact, just get to where the transom begins to float off the cradle and push it off. But as you're looking in the rearview mirror for the stern to begin to float and instead the whole boat and trailer begin twisting and heeling 20-deg to starboard... Ummmm... YIKES! Ah the things we learn by doing them the stupid way! That which doesn't kill you...
[Re: Doug_P182_LKN]
#186577 07/30/09 03:35 PM 07/30/09 03:35 PM | andrewscott
| andrewscott
Unregistered | just get to where the transom begins to float off the cradle and push it off. I have had beach wheel's for years so my trailer hasn't got wet in years.. but when it did.. i would back it ONLY to where the trailer tire was 1/2 way in. i would then push the cat off (till it was balanced on the rear rollers) and let gravity take over... i would be sure the bows gently rode over the rollers.. it worked fine. If you are submerging your trailer up the boat sterns in salt water... you will be reducing the life of your lights / trailer bearings / leaf springs / and everything else that gets wet (IMHO)
[Re: ]
#186591 07/30/09 04:58 PM 07/30/09 04:58 PM |
Posts: 1,383 Kingston SE South Australia | G'day Andrew power boat trailers do it all the time, I launch with beach rollers but when my 5.8 got terminally beaten up in a storm I got towed to a ramp where I backed as deep as I could go without filling the sail boxes and you wouldnt believe how easy it was to just glide it on, tie it down and drive off, probably 3 minutes retrieval. Off coarse I didnt have to worry about mast, sails etc but thats another story. regards
1 registered members (Seanziepop),
676
guests, and 84
