| Re: Portsmouth number revisited, need input
[Re: WindyHillF20]
#186926 08/04/09 10:32 AM 08/04/09 10:32 AM | andrewscott
| andrewscott
Unregistered | just curious. and i know its rude, but since you stated how much a new tiger sail is, how much is a new TheMightyHobie18 sail from Chip? | | | Re: Portsmouth number revisited, need input
[Re: WindyHillF20]
#186930 08/04/09 11:15 AM 08/04/09 11:15 AM | andrewscott
| andrewscott
Unregistered | cool, thanks when i was looking at a new jib, chip was FANTASTIC to work with. i ended up getting a slightly used one from Robbie, but i really thought Chip went above and beyond to work with me... | | | Re: Portsmouth number revisited, need input
[Re: WindyHillF20]
#186936 08/04/09 12:01 PM 08/04/09 12:01 PM |
Posts: 1,403 | This is my thinking as well. The TheMightyHobie18 and H18SX have the same hulls, tramp, rudders and crossbars. The difference is the mast height and main sail size. There is a hit for not running the wings as well that I would apply, wings slow the boat down.
Hit for the main, spin and wings above the SX number? I see a hit for using the wings, nothing for taking them off. Am I missing something? "Any other deviations from standard class configurations, including the addition of wings, can be assessed a penalty of at least 0.995. Multiple deviations may incur multiple penalties. Penalties may be greater than 0.995. Please identify any such modifications and penalties assigned and include with results reported to the handicap committee and Portsmouth Numbers Committee | | | Re: Portsmouth number revisited, need input
[Re: ThunderMuffin]
#186941 08/04/09 12:37 PM 08/04/09 12:37 PM |
Posts: 1,403 | the standard class configuration for the 18SX is with wings. Agreed, as I don't think DP-N has an adjustment for taking the wings off.
[Re: WindyHillF20]
#186944 08/04/09 12:45 PM 08/04/09 12:45 PM | andrewscott
| andrewscott
Unregistered | the penalty is a pain in the butt!... literally!  | | | Re: Portsmouth number revisited, need input
[Re: WindyHillF20]
#186946 08/04/09 12:52 PM 08/04/09 12:52 PM |
Posts: 1,403 | Undecided is correct. There is a penalty for not using the wings. I haven't looked for it yet but will today. Ahh Duh!!! Got it it "Any other deviations from standard class configurations, including the addition of wings, can be assessed a penalty of at least 0.995........ So take the 68.10 X 0.995 for a rating of 67.76 at least this is what I am able to get off the Portsmouth Website.
[Re: WindyHillF20]
#186950 08/04/09 01:18 PM 08/04/09 01:18 PM |
Posts: 1,403 | Here is what I see from the portsmouth 2008 numbers. The SX w/spi is rated 71.3. No wings is a .995 hit, oversized non-standard main is .980 hit. There is no mention of a hit for a smaller than standard jib and no hit for the spi(mine is assymetric). The jib I can understand as there is no gain. The spin I run is quite an improvement over the SX spin so some penalty should apply but what? I calculate it 71.3 x .980 x .995 = 69.52 Didn't know the boat came with a spinnaker, Not very familiar with all the different TheMightyHobie18 configurations. So used to adding the hit for the older boats. But looking at this; there is only a 0.01 difference in the base rating of the SX vs. the standard and the magnum at 71.4. And they would take a hit for the spinnaker. What are the difference in the regular/magnum H-18 and the SX, Mast, spinnaker, anything else. Question, is the new main within 5% of Calculated Approximate Sail Area?
[Re: Ventucky Red]
#186955 08/04/09 01:57 PM 08/04/09 01:57 PM |
Posts: 1,200 Vancouver, BC | Let me get this straight...adding wings to an TheMightyHobie18==> no adjustment.
Subtracting wings from an TheMightyHobie18 SX (or whatever they are called)===> takes a hit
Weird, no?
[Re: Ventucky Red]
#186956 08/04/09 01:57 PM 08/04/09 01:57 PM |
Joined: Apr 2003 Posts: 440 Graham, NC WindyHillF20 OP
Posts: 440 Graham, NC | regular TheMightyHobie18 and Magnum run a 28' stick, SX runs a 29.5'. The Magnum has the shorter wings on it and can be run without them with no penalty. The SX came with long wings and a spin kit was available from the factory, the boat is to be raced with the wings on. The SX spin is a bag launched full cut spin, mine is flat and snuffed on the pole. The SX rating doesn't seem correct but thats all there is to go with.
I'm not sure if the new sail is within 5% of the original or not. There is another boat on the left coast running the same main, "Wind Raider" is the boat. Its pic is on the Whirlwind site.
[Re: Tornado]
#186959 08/04/09 02:27 PM 08/04/09 02:27 PM |
Posts: 1,403 | Let me get this straight...adding wings to an TheMightyHobie18==> no adjustment. Yes there is it is .995 Subtracting wings from an TheMightyHobie18 SX (or whatever they are called)===> takes a hit Weird, no? That too!!! regular TheMightyHobie18 and Magnum run a 28' stick, SX runs a 29.5'. The Magnum has the shorter wings on it and can be run without them with no penalty. The SX came with long wings and a spin kit was available from the factory, the boat is to be raced with the wings on. The SX spin is a bag launched full cut spin, mine is flat and snuffed on the pole. The SX rating doesn't seem correct but that's all there is to go with. Looks like you got yourself a sleeper rating there and should clean up in open class. | | | Re: Portsmouth number revisited, need input
[Re: Ventucky Red]
#186962 08/04/09 03:31 PM 08/04/09 03:31 PM |
Posts: 1,200 Vancouver, BC | Let me get this straight...adding wings to an TheMightyHobie18==> no adjustment. Yes there is it is .995 Subtracting wings from an TheMightyHobie18 SX (or whatever they are called)===> takes a hit Weird, no? That too!!! Hang on a minute, see this post:
TheMightyHobie18 Wing Mod where you and others claim there is no mod for an TheMightyHobie18 carrying wings!?!?!
2,499
guests, and 502
