Is it possible to have too much rake? #187279
08/06/09 09:44 PM
08/06/09 09:44 PM
Cincinnati, Ohio
Tri_X_Troll Offline OP
Cincinnati, Ohio
Is it possible to have too much rake? Some of the old timers that I sail with keep telling me that I've got too much.
I've raked the rudders under and have little weather helm, and get my 6:1 within 2 inches of block to block with the main I bought brand new last season and have only sailed perhaps a dozen times.
I seem to be able to point much higher, however they seem to have a little more boat speed when falling off, well more than I do when I fall off.
Re: Is it possible to have too much rake? [Re: Tri_X_Troll] #187338
08/07/09 12:08 PM
08/07/09 12:08 PM
California
mmiller Offline
mmiller  Offline
California
Depends on the wind speed. In high winds (over 20 plus) I have seen two blocked mains with floppy leechs smoke. They had loosened the Jib halyard and let the mast lean WAY aft. It was a matter of survival for light crews at a high wind Worlds event.
Higher the wind... rake more aft. You do give up a little down wind though. You have to adhust for the conditions and your sailing skill set.
It is good to get to the weather mark first! Pointing higher helps.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 2,968 guests, and 164 spiders.
