H16 running rigging list? #187388
08/07/09 11:19 PM
08/07/09 11:19 PM
WA, ID, MT
davefarmer Offline OP
WA, ID, MT
Can someone point me to a list of lines for the H16? Thanks!
Dave
Re: H16 running rigging list? [Re: davefarmer] #187389
08/07/09 11:45 PM
08/07/09 11:45 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
This might help:
Line Lengths
Re: H16 running rigging list? [Re: SurfCityRacing] #187403
08/08/09 08:40 AM
08/08/09 08:40 AM
The sheets on that list are a size larger and a little longer than what comes on new boats (and most racers use) now.
5/16" for the main
1/4" for the jib
The stuff that comes on the boat new is made by Liros.
Re: H16 running rigging list? [Re: SurfCityRacing] #187405
08/08/09 08:51 AM
08/08/09 08:51 AM
WA, ID, MT
WA, ID, MT
Thanks Jeremy, that's precisely what I was after!
Dave
Re: H16 running rigging list? [Re: davefarmer] #187407
08/08/09 09:21 AM
08/08/09 09:21 AM
U
ulianokr Offline
ulianokr  Offline
U
I don't see how 20 feet of 3/16 line can be enough as it's stated below... I've got 30' and I think I'm about 2 feet short.... the line has to gofirst to the becket then down to the block riveted to the mast, then back up to the block attached to the wire line and then back down once you've attached the jib to roll up on the cleat on the mast... somebody help a fella out...
Jib Halyard Line (old wire halyard)
3/16' Halyard 20'
Re: H16 running rigging list? [Re: ulianokr] #187418
08/08/09 10:31 AM
08/08/09 10:31 AM
Santa Cruz, CA
Santa Cruz, CA
Something's different about your system, friend. That's the correct length for an older style 3:1 wire/rope jib halyard (actually 21 feet is more like it) The Aussie system uses 71'of 4mm (+or-) low stretch.
Re: H16 running rigging list? [Re: ulianokr] #187423
08/08/09 01:08 PM
08/08/09 01:08 PM
3/16' Halyard 20'
You only use the purchase for the last couple of feet of the halyard hoist.
Tie the halyard to the becket, then loop it through the becket block. When you raise the jib, pull the block down until you can reach it, pull the loop out from the block, hook it under the block on the mast, tighten and cleat off.
Re: H16 running rigging list? [Re: ulianokr] #187424
08/08/09 01:13 PM
08/08/09 01:13 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
3/16' Halyard 20'
Maybe you're thinking of the Aussie halyard system. It uses a lot of line as the blocks are at the head of the jib and the tang on the mast..
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: H16 running rigging list? [Re: hobie1616] #187516
08/10/09 11:18 AM
08/10/09 11:18 AM
brucat Offline
brucat  Offline
Could we get that list updated?
Also, what length are people using for the 6:1 downhaul (and what is supplied)? Mine is stock (2006) and seems like it's 4 feet too long. At Rochester this weekend, there seemed to be all sorts of different setups. What works best?
Re: H16 running rigging list? [Re: brucat] #187518
08/10/09 11:33 AM
08/10/09 11:33 AM
Santa Cruz, CA
Santa Cruz, CA
I have a few in my head (which is a bad place to store stuff).
AUS jib Halyard= 71'
Split Jib traveler adjustment= 11'X 1/4" X2
Most people use from 28-30' of 1/4" jib sheet.
6:1 downhaul 21'4-5mm.
That's all I know.
Re: H16 running rigging list? [Re: brucat] #187524
08/10/09 12:48 PM
08/10/09 12:48 PM
Why are you asking that question here? You know who manages the HCA-NA website.
Re: H16 running rigging list? [Re: mbounds] #187530
08/10/09 01:15 PM
08/10/09 01:15 PM
brucat Offline
brucat  Offline
Brain cramp...
Re: H16 running rigging list? [Re: SurfCityRacing] #187537
08/10/09 02:25 PM
08/10/09 02:25 PM
Santa Cruz, CA
Santa Cruz, CA
That's all I know.
The split trav adj is 3/16" not 1/4". Same with the downhaul. I typed it wrong.
0 registered members (), 2,928 guests, and 135 spiders.
