Footstraps on a Tiger #187536
08/10/09 02:22 PM
08/10/09 02:22 PM
Frozen Offline OP
Frozen  Offline OP
I put windsurfer footstraps on my Tiger behind the rear crossbar. Any thoughts on this?
Seems like I don't need a second set. Again any thoughts on this.
BTW I love the ones behind the Xbar.
Alan F
Tiger
Re: Footstraps on a Tiger [Re: Frozen] #187558
08/10/09 06:48 PM
08/10/09 06:48 PM
Scarecrow
Scarecrow
You really need the foot straps for your back foot. If you stuff the boat hard with the front foot in a strap but the back foot free you'll hinge around the front foot.
Re: Footstraps on a Tiger [Re: ] #187565
08/10/09 09:08 PM
08/10/09 09:08 PM
Brett Goodall Offline
Agree with Scarecrow.
Your foot strap should be as far back as possible and used for your back foot. However some crews add a second foot strap just behind the rear beam. This is never for the front foot, it's used in lighter conditions when the crew isn't needed right at the back of the boat.
Personally I have experimented a fair bit and there is alot to be said for hooking up a good safety line (Jesus line, chicken line whatever you want to call it).
Re: Footstraps on a Tiger [Re: Brett Goodall] #187595
08/11/09 08:03 AM
08/11/09 08:03 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Are people just holding onto the chicken/jesus line or are they actually hooking in somehow? I'm a little uneasy about having my crew or myself actually hooking in. If people are simply holding the line is it excessively fatiguing?
F18 USA 242
http://www.solarwind.solar
Re: Footstraps on a Tiger [Re: David Ingram] #187596
08/11/09 08:16 AM
08/11/09 08:16 AM
Tornado_ALIVE Offline
Hook up and send it. Would not sail downwind in breeze without one.
Re: Footstraps on a Tiger [Re: Tornado_ALIVE] #187599
08/11/09 08:30 AM
08/11/09 08:30 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
How do you not end up hanging in the air like in Tornado blast on youtube?
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Footstraps on a Tiger [Re: JeffS] #187624
08/11/09 01:51 PM
08/11/09 01:51 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I have had chicken lines set up two different ways. One, was with an S hook that was affixted to a roller cleat (like used on an adjustable trapeze system. The hook goes to the trap ring NOT the harness. This is a nice system and easy to set up and use, but you need to be careful jibing to hook the S hook to the hiking strap on the tramp when jibing other wise it bounces around on the hull. It works great for distance races, but not so much for buoys. The other plan is to attach to jam cleats to your harness bar (mine are attached to small plates that I had welded to the bar). This way the chicken line just goes into the cleat and when not in use, sucks back into the rear beam with a bungee. A little quicker to use and suits both buoy and distance races. I have crashed while attached to both systems, and neither have hung me like the video.
Re: Footstraps on a Tiger [Re: ksurfer2] #187652
08/11/09 07:35 PM
08/11/09 07:35 PM
Holding onto the chicken line is a no no for two reasons:
1. When you plant the bows you'll never be able to hold on hard enough.
2. If you wrap, or it accidentally wraps, around your hand you'll rip your hand off.... or break it at the very least.
If you think I'm kidding, I've straightened an 8G S hook that was hooked into my harness.
The best version of the chicken line is as ksurfer2 described with the jam cleats on the spreader bar. That way it's easily adjustable and it will release if you fall on it the wrong way. The problem with this is if you don't have a bar on your harness you can't attach the cleats, so you need a hook onto your harness... I find hooks dangerous and stuff gets caught on them. I actually use a ball and loop system... it's hard to explain but I'll get some pics up soon.
Also, while hooking to your trap ring may be a little safer it is not as stable.
Re: Footstraps on a Tiger [Re: Brett Goodall] #187683
08/12/09 03:01 AM
08/12/09 03:01 AM
Hook onto the dog bone. When you come off your ring unhooks. In the T blast video, Forbes hooked onto his harness intentionaly to add visual affect to the intentional capsize.
Re: Footstraps on a Tiger [Re: Tornado_ALIVE] #187714
08/12/09 10:54 AM
08/12/09 10:54 AM
Clermont, FL, USA
Clermont, FL, USA
I'll give the hooks a go, I like the ball and loop idea too. Any thoughts on using a snapshackle?
I have to do something, sweetness has already issued a few threats when she is "requested" to wire up downwind.
F18 USA 242
Re: Footstraps on a Tiger [Re: David Ingram] #187717
08/12/09 11:17 AM
08/12/09 11:17 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
We had the lines with hooks (chicken lines) on the Tiger we just sold and liked them a lot. Only used in really big swell and wind. In "normal" conditions it was not used. Only, only only hook it to the trapeze handle and NEVER the trapeze harness.
My plan on the Infusion is to make a cup that inserts into the hole at the end of the crossbar so the hook will hide inside when not in use. So as not to accidentally grab one of the sheets. That does not happen too much but thought it would add a bit of comfort.
Our system was a line from the rear of the boat with the length we wanted it to be, then put a bungee on that line into the rear crossbar so it can be sucked in with no slack.
We also had footstraps that were added before the line. The first ones were attached from the back of the rear crossbar to the hull. That was not far enough back and we added a second set to the very back of the boat. Kept the first ones on. Sometimes I sail with people that are not comfortable getting all the way back on the boat so they can use the front ones.
Later,
Dan
Re: Footstraps on a Tiger [Re: Dan_Delave] #191994
09/25/09 11:05 AM
09/25/09 11:05 AM
Frozen Offline OP
Frozen  Offline OP
Have you tried straps for the crew?
Alan F
Tiger
Re: Footstraps on a Tiger [Re: Dan_Delave] #192014
09/25/09 03:15 PM
09/25/09 03:15 PM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
This is very, very clever! In this case one can use a fast eye snap or carabiner. Currently we have an open hook, but during tacks my main sheet gets very often tangled in this hook.
F18: C2 / A-Cat: Minelli
0 registered members (), 4,759 guests, and 1,032 spiders.
