Hobie 18 jib sheet #18770
04/18/03 11:07 PM
04/18/03 11:07 PM
Ontario, Canada
av8or Offline OP
av8or  Offline OP
Ontario, Canada
Just wondering how many use just one sheet in a loop or two separate sheets.? Is there a right or wrong way?
Thanks
Dave
Re: Hobie 18 jib sheet [Re: av8or] #18771
04/18/03 11:13 PM
04/18/03 11:13 PM
PSAILOR Offline
PSAILOR  Offline
It is a single line from becket on one side , trough the jib block, back through the cam, over to the other side, through the cam, then the jib block, then to the other becket. I think the Hobie parts catalog has a diagram and may also be available online. The set-up is similar to the H16 / H17 but to the side tracks instead of the front beam.
Re: Hobie 18 jib sheet [Re: av8or] #18772
04/19/03 08:53 AM
04/19/03 08:53 AM
Jensen Beach, FL
BlowMe Offline
BlowMe  Offline
Jensen Beach, FL
Seperate sheets seem to always get tangled up with something important or wind up in the drink dragging along side the boat. One sheet is best! Especially for roller furling. If you use roller furling be sure to have enough slack in the sheet so it will extend out to the forestay when the jib is rolled up.
AJ
Express 6.0
0 registered members (), 21,808 guests, and 852 spiders.
4 hours ago
