| Re: main sail deep or flat
[Re: scooby_simon]
#187827 08/13/09 08:54 AM 08/13/09 08:54 AM | andrewscott
| andrewscott
Unregistered | Hey Scoobie, what is that line on your sidestay (or trapwire) for? | | | Re: main sail deep or flat
[Re: mbounds]
#187933 08/13/09 02:09 PM 08/13/09 02:09 PM |
Posts: 3,528 Looking for a Job, I got credi... | The wonders of PhotoShop: ![[Linked Image]](http://www.catsailor.com/gallery/albums/userpics/10063/normal_149788-flatmain1%20copy.jpg) The sail looks seriously screwed up in the second photo. The leech is very loose up top. Draft is too far forward. Top of the sail is too twisted away, I have fixed that with some work on the sail battens. Sail now stands up better when loads of DH is applied. Did some work on it with different top battens. I'm light so I am quite happy with the draft well forward and little of it!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: main sail deep or flat
[Re: ]
#187934 08/13/09 02:17 PM 08/13/09 02:17 PM |
Posts: 893 | Hey Scoobie, what is that line on your sidestay (or trapwire) for? Stops the Spinnaker being pulled up between the forestay and sidestay wires and getting jammed in light wind ( you can virtually use the flat spinnakers we use on the F16's as reaching sails ) | | | Re: main sail deep or flat
[Re: waynemarlow]
#187935 08/13/09 02:26 PM 08/13/09 02:26 PM |
Posts: 3,528 Looking for a Job, I got credi... | Hey Scoobie, what is that line on your sidestay (or trapwire) for? Stops the Spinnaker being pulled up between the forestay and sidestay wires and getting jammed in light wind ( you can virtually use the flat spinnakers we use on the F16's as reaching sails ) Yep. It also helps me sailing very high in very light winds to tack the kite with less risk of snags.
[Re: scooby_simon]
#187947 08/13/09 03:23 PM 08/13/09 03:23 PM | andrewscott
| andrewscott
Unregistered | gotcha.. thanks... i never have a problem like that.. my problems are at the waterlevel. | | |
2,874
guests, and 307
