trailing a Hobie #18773
04/19/03 09:28 AM
04/19/03 09:28 AM
St. Louis, MO
nova Offline OP
nova  Offline OP
St. Louis, MO
I was wondering were the supports on the trailer should be. The hobie sits on the trailer right in line with the front and rear pylons. That leaves the whole front of the hulls sticking out there. Were as my friends sits about 2 feet in front of the front pylons. Is it ok to have the hulls sitting out that far or should I rework the trailer and move the support forward?
Re: trailing a Hobie [Re: nova] #18774
04/19/03 07:57 PM
04/19/03 07:57 PM
Sodus NY
h16bill Offline
h16bill  Offline
Sodus NY
When Hobie 16's are laid up the keel area is all solid glass so there is
no real worry about where it sits on the trailer.
cheers
Bill
Re: trailing a Hobie [Re: nova] #18775
04/21/03 06:54 AM
04/21/03 06:54 AM
West Texas
Hobie Dave Offline
Hobie Dave  Offline
West Texas
It concerns me the way my boat loads with the center of gravity so far forward, but I have towed my boat for thousands of miles this way without any problems. Just be sure the rear of the boat is securely tied down. If the rear is not tied down, the boat will want to tip over forward.
David
Re: trailing a Hobie [Re: Hobie Dave] #18776
04/24/03 05:14 PM
04/24/03 05:14 PM
St. Louis, MO
nova Offline OP
nova  Offline OP
St. Louis, MO
I was hoping to get a few more opinions. However since no one has disagreed with h16bill or HobieDave I guess I'll leave the trailer as is.
Thanks guys on your thoughts on this subject.
Re: trailing a Hobie [Re: nova] #18777
04/24/03 05:30 PM
04/24/03 05:30 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Hi,
When I switched from a Hobie 16 to my Prindle 18 (same trailer), I thought it looked like a lot of weight on the single front roller. I thought about picking up some fiberglass hull cradles, but instead went with a double roller system. This spreads the weight out quite a bit. I have some photos of it at http://www.thebeachcats.com . Just go there and do a search for "double rollers".
Good luck,
Jack Hoying
Prindle 18
Fort Loramie, Ohio
Re: trailing a Hobie [Re: jmhoying] #18778
04/25/03 07:47 AM
04/25/03 07:47 AM
Punta Gorda, FL
KARTZ1 Offline
KARTZ1  Offline
Punta Gorda, FL
We used to trailers 2 16's on one trailer. Other than the wind drag that caused the gas milage to plummet when driving over 55, we never had any problems.
Re: trailing a Hobie [Re: KARTZ1] #18779
04/30/03 08:21 PM
04/30/03 08:21 PM
Adrock Offline
Adrock  Offline
Watch how you weight the thing too wuch weight on the toung and it might get squirly vise versa. I found this out towing my boat from San Diego to New Jersey
0 registered members (), 257 guests, and 39 spiders.
