Inter 17R weight #188062
08/14/09 01:00 PM
08/14/09 01:00 PM
Mike Fahle Offline OP
I cannot find a weight listed for the subject boat. Please tell me what you can about that and why it is not listed. Thanks.
Re: Inter 17R weight [Re: Mike Fahle] #188066
08/14/09 01:23 PM
08/14/09 01:23 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
That...my friend is a closely guarded secret.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Inter 17R weight [Re: Mugrace72] #188069
08/14/09 01:59 PM
08/14/09 01:59 PM
500-600 lbs I think is what I heard...
smile
Re: Inter 17R weight [Re: PTP] #188070
08/14/09 02:22 PM
08/14/09 02:22 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
156kg- 343lbs.
E-Scow
24' ULDB
Re: Inter 17R weight [Re: Mugrace72] #188071
08/14/09 02:37 PM
08/14/09 02:37 PM
Yep; that is why it does not ahve an SCHRS rating as no-one knows what it is.
I've been told 11 different weights for this boat. None backed up by measurment cert.
Re: Inter 17R weight [Re: FasterDamnit] #188077
08/14/09 04:23 PM
08/14/09 04:23 PM
What is the source for that weight and what does that include?
Re: Inter 17R weight [Re: Mike Fahle] #188085
08/14/09 06:08 PM
08/14/09 06:08 PM
Lake Murray SC
Lake Murray SC
http://www.h2o-sensations.com/eshop/english/proddetail.php?prod=NACF17SLOOP
and
http://www.nacra.com.au/race/nacra-f17sloop
This one says 130kg
http://www.sirena-voile.com/en/bateaux_neufs/catamarans/nacra-f17,6.html
E-Scow
24' ULDB
Re: Inter 17R weight [Re: FasterDamnit] #188087
08/14/09 06:11 PM
08/14/09 06:11 PM
Lake Murray SC
Lake Murray SC
And once more that says 145kg-
http://en.allexperts.com/e/f/fo/formula_17_%28sailing%29.htm
"The Formula 17 Class (www.formula17class.com) was formed in July 2006 and is in discussion with Hobie Cat and Performance Catamaran in developing a set of class rules. The idea behind the Formula 17 Class is similar to the Formula 18 Class, except it is for single-handed spinnaker-rigged catamarans of professional construction. The intent is to develop a class where Measurers only need to measure an example of a manufacturer's product to certify it meets the rules. Any deviation from manufacturer's parts for that type of boat would disqualify that boat from being legal to the Formula 17 Class rules.
The name F17 is used by Nacra to identify their carbon masted N17, a 17 foot single-handed design. Hobie Cat markets a 17 foot single-handed design called the FX-one.
The Formula 17 Class is talking with Hobie Cat and Performance Catamaran (Nacra) to agree on a single set of class rules and allow designs and makes of other boat builders into their racing fleets. .
Currently the specifications of both boats are : (source : www.texelrating.org)
Hobie FX-one
* Overall length : 5.23
* Overall weight : 149 kg
* Overall width : 2.5 mtr
* Overall sailarea incl. mast : 14.91 sq. mtr.
Additional comments :
The Hobie company itself doesn't use the F17 identifier in any official way. They are committed to the one-design status of their product.
Nacra N17
* Overall weight : 155 kg
* Overall width : 2.6 mtr
* Overall sailarea incl. mast : 13.68 sq. mtr.
Nacra F17 w/ spinnaker (source: http://nacra.us/F17/Findex.html)
* Overall length : 5.23 mtr
* Overall weight : 145 kg
* Overall sailarea mainsail incl. mast : 15.14 sq. mtr.
* Overall sailarea spinnaker (small) : 15.5 sq. mtr.
* Overall sailarea spinnaker (large) : 18 sq. mtr.
The Nacra Company does use the F17 identifier for their latest 17 footer. The F17 has a 9.25 mtr (30' 4") carbon mast, differing from the N17 with a shorter aluminum mast and less sail area. In the past, Nacra has launched and produced the following variations of their 17 foot boat. Australian Inter 17 (a doublehanded sloop which replaced the Nacr 5.2 in that market), European Inter 17, US Inter 17, Inter 17R and now the Nacra F17. The Australian Inter 17 has different hulls than all the rest. The European and US Inter 17 were the same. The US Inter 17R and F17 are almost identical and only differ in some component differences which are relatively insignificant."
E-Scow
24' ULDB
Re: Inter 17R weight [Re: FasterDamnit] #188090
08/14/09 06:23 PM
08/14/09 06:23 PM
Devon Offline
Devon  Offline
Scroll down, this is what I sail in Aussie, 1 up with self tacker jib same as F18 and spinnaker also same as the F18 but a bit smaller main square top, check out the boats weight 125 kg and 1 up with F18 jib and spinaker wing mast kevlar/carbon hulls OMG!!!! http://regatta.nacraxtreme.com/photos/6.html
here are some vids and pics of this Deamon... in the Nacraxtreme website enjoy
Home
Race boats
Fun boats
Accessories
Sailing gear
News
Contact us
Race boats page one
Maricat
DESIGNER: n/a
BUILDERS: Brisbane Catamaran Centre
LENGTH: 4.27m (14’)
BEAM: 2.35m (7’7”)
DRAFT: n/a
DISPLACEMENT: 98kg (216lb)
SAIL AREA: 10.9sqm (117sqft) The Maricat 4.3 is a very versatile Catamaran,being an ideal
boat for family fun,yet it has all the go fast gear fitted as
standard to make it a top racing catamaran in the 14ft division.
The hulls are know made out of foam sandwich construction
which makes the boat stiffer and faster plus will help them last for many more years to come.
The hulls feature storage lockers inn each hull and the natural
stability of the Maricat 4.3 have helped to make it Australia's
most popular and long lasting 14ft Catamaran.
Your safety and comfort are well catered for as well.Saddle
sores are a thing of the past when you sit on the Maricat.The
trampoline joins smoothly into the curved fiberglass decks and
provide comfortable seating whether you are pottering along or straining to hold the boat down on a screaming reach.
Mobile: +61 400 701 878 Fax: +61 (2) 9953 6697 Email: james@nacraxtreme.com Web: www.nacraxtreme.com
Nacra 5.0
DESIGNER: Roy Seaman
LENGTH: 5m (16’4”)
BEAM: 2.44m (8’)
DRAFT: n/a
DISPLACEMENT: 130kg (286lb)
SAIL AREA: 19sqm (204sqft) The Nacra 5.0 harmoniously blends high performance with the simplicity of a boardless day sailor. Nacra’s low aspect
ratio is one of the most endearing features of the 5.0.
Featuring fine ‘V’ forward sections for high pointing and
true tacking whilst the rounded aft sections give the 5.0
the ability to manoeuvre for easy tacks and effortless
gybes. For those who like to keep their high performance
sailing simple and hassle-free, the 5.0 is unbeatable.
Boomless, boardless, limitless. The Nacra 5.0 is the
multi-role catamaran capable of racing on the edge or
quietly cruising with friends on lazy afternoon sails. Best
suited crew weights 110-150kg.
Nacra 17
DESIGNER: Ross Guinea
LENGTH: 5.3m (17’3”)
BEAM: 2.45m (8’)
DRAFT: n/a
DISPLACEMENT: 125kg (275lb)
SAIL AREA: 21sqm (226sqft)
SPINNAKER: 16sqm (172sqft) and 20sqm (215sqft) The Nacra 17 is by far the most advanced sports
catamaran in today's market. Its advanced hull
design and high aspect boards and rudders make it
a pleasure to sail. With a range of standard features
including: Self Tacking Jib, Mid Pole Snuffer System,
Square Top Mainsail and Kevlar/Carbon lay up. The
Nacra 17 has the ability to match the performance
of much larger cats. The Nacra 17 has been
designed for mid weight crews (120 - 155kg) and
with its pointing and tacking ability as well as ease of
spinnaker use, the Nacra 17 will be the spinnaker
catamaran of the future.
Nacra 5.8
LENGTH: 5.8m (19’)
BEAM: 2.5m (8’2”)
DRAFT: n/a
DISPLACEMENT: 165kg (363lb)
SAIL AREA: 22.8sqm (245sqft) The Nacra 5.8 is the ultimate catamaran. A true international
one design class, proven successful around the world.
With an optimum crew weight of 140-165kg, the 5.8
will satisfy the most demanding racer. With its boomless
design, high volume hulls, bridal foil jib and a full
complement of standard features, safety, versatility and
value, the Nacra 5.8 offers a package that other
manufacturers can only try to equal. Spinnaker kit
available.
Race boats page two.. here
Re: Inter 17R weight [Re: Devon] #188092
08/14/09 06:47 PM
08/14/09 06:47 PM
Devon Offline
Devon  Offline
Here r 2 vids of my I17 hope this works
http://wwwhttp://www.youtube.com/watch?v=UQ9R0YEZC2g&feature=related.youtube.com/watch?v=IbPAjGvIWno
Re: Inter 17R weight [Re: Devon] #188094
08/14/09 06:53 PM
08/14/09 06:53 PM
Devon Offline
Devon  Offline
Ok try this proves im hopless at this stuff. U tube search
Devon`s Deamon Nacra l17 and
Vic Mossie Champ on Lake Tinaroo on the l17 nacra
Re: Inter 17R weight [Re: Mike Fahle] #188098
08/14/09 07:39 PM
08/14/09 07:39 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
depends what year. pre 2006 they were around 330lbs
Re: Inter 17R weight [Re: Devon] #188105
08/14/09 11:15 PM
08/14/09 11:15 PM
DougSnell
DougSnell
Here you go Devon
Doug
0 registered members (), 539 guests, and 120 spiders.
Posts267,056
