| Re: unirig pointing ability
[Re: Rolf_Nilsen]
#188610 08/20/09 09:48 PM 08/20/09 09:48 PM |
Posts: 62 | Either what they said...or the opposite. Most A cat guides explain it like this. If you can point well but the boat tends to not squirt in a puff, you need to flatten your sail. In order to not go over in a puff you have to point very high...your speed goes down, and you are pointing higher than your competition. If, on the other hand, you have speed in the puffs (squirt) but can not point as high as the competition (especially in the lulls), then you need a fuller sail (more power). Since you said you can not trapeze until the wind is up around 15 knots and you can not point, I think you need more power. With your boat you should be on the wire around 6. There are people that stop sailing at 15 knots and you are just now able to go out on the wire? Or do you just not go out before 15 knots? The trick of lying the boat on it's side is to help you tune the mast. If, for example, you decide you want to have a flatter sail there are two ways to achieve this. You can crank on the diamond wire, or rake your spreaders back (or some of each). When you crank the diamonds you will get more bend up top and less down low. When you move the spreaders back you will get more bending down low. This technique helps tell where to adjust for your sail, not how much bend your sail needs. Also, the square top is more sensitive to main sheet tension. Make sure you are in tight, especially above 5. | | | Re: unirig pointing ability
[Re: denis 18 square]
#188698 08/21/09 07:06 PM 08/21/09 07:06 PM |
Posts: 1,383 Kingston SE South Australia | . Sheething is relatively soft because when I sheet hard, I feel I'm ''chooking'' the boat I've had that feeling before with an ali mast and I found the leech was pulling the top of the mast over when the mast was rotated. After that it was a compromise between mast rotation and mainsheet tension. regards
[Re: JeffS]
#188700 08/21/09 07:26 PM 08/21/09 07:26 PM |
Posts: 757 japan | i've been running pretty loose diamonds on my straight spreader 5.2 as i sail it; underweight, solo, on a generally light air lake without much chop or wave action
it sounds as though i should start experimenting with diamond tension as i could easily imagine that is happening to me when th wind does pick up...
[Re: erice]
#188715 08/21/09 11:05 PM 08/21/09 11:05 PM |
Posts: 1,383 Kingston SE South Australia | Tight diamonds wont change what happens above the hounds and that's where my wing mast section used to lay over on the A class. Loose diamonds were the recommended setting on my 5.8, you could tell if it was too loose as the mast used to bend into the slot and the boat wouldn't point as well on the looser tack.
[Re: Rolf_Nilsen]
#188807 08/24/09 06:39 AM 08/24/09 06:39 AM |
Joined: Aug 2009 Posts: 16 qc canada denis 18 square OP
Posts: 16 qc canada | Hi Rolf, I'm back from my sailing weekend and the tests results are quite encouraging. I did increased the prebend from 1" to 1.5" and went out sailing. Wind was very light, 3 to 5 knots, going upwind, I slowly cranked the downhaul by small increment pretty much up to max and that top leech telltale finally did start to stream about 50% of the time. Altough I'm pretty bad at the seat of the pant feeling, my pointing seems better(guys at the club agreed), but also I felt the boat was running a bit faster, that choking the boat feeling when sheeting hard was gone. My lower leech telltale was still hooked to leeward all the time so I tought I should try to increase sprearders rake to flatten a bit more this part of the sail. Then back on the beach and up in the ladder to reach the spreaders to find out that the adjustments are seized up. I dont want to compromise my sailing season, I'd rather sail with a badly tuned boat than no boat at all. So that will be a winter project. I did measured the spreaders rake, I'm already at 2.5". Nacra 20 tuning guide recommend 2.6" for light crew. Since I'm all alone on the boat and the mast seem quite stiff, do you think it is safe to go beyond that recommended setting, may be 3". I tried trough the site search engine to find out more about mast and sail tuning but I had a hard time to get good result. Any clue how to refine my search? I would really like to read about the subject. Thank again for your help. Denis | | | Re: unirig pointing ability
#188814 08/24/09 07:17 AM 08/24/09 07:17 AM |
Posts: 4,451 West coast of Norway | Great news Denis. Nothing is more fun than hearing success stories. Agree on the pre-bend issue, sounds like you need substantially more pre-bend. I would have talked with the guys at NACRA about how much bend you can put in the mast safely, then found a combination of spreader rake and diamond tension that matched the sail and your conditions well. I tried trough the site search engine to find out more about mast and sail tuning but I had a hard time to get good result. Any clue how to refine my search? I would really like to read about the subject. I can not help you with any articles on pre-bend and sail setting. That topic is quite dependent on your equipment. In your case where you try to match your mast to your sail it is a matter of trying several settings and tuning for best performance to your conditions, boat and skills. When you can make all telltales fly in all wind conditions, you are getting close in my opinion. Then start finetuning for your best performance in your dominant conditions. There is a lot of NACRA experience here and they can probably give you good advice on how far you can go with spreader rake and diamond tension. Is your mainsail a standard NACRA20 main? | | | Re: unirig pointing ability
[Re: Rolf_Nilsen]
#188829 08/24/09 11:32 AM 08/24/09 11:32 AM | andrewscott
| andrewscott
Unregistered | Is there a reason you need to put the cat on its side to see the curve of the track and sail? cant this be done with the mast straight up? | | | Re: unirig pointing ability
[Re: ]
#188833 08/24/09 11:50 AM 08/24/09 11:50 AM |
Posts: 3,528 Looking for a Job, I got credi... | Is there a reason you need to put the cat on its side to see the curve of the track and sail? cant this be done with the mast straight up? Difficult to measure as the point of max curve is usually above the spreaders!!!!
F16 - GBR 553 - SOLD I also talk sport here | | | Re: unirig pointing ability
[Re: scooby_simon]
#188837 08/24/09 12:54 PM 08/24/09 12:54 PM | andrewscott
| andrewscott
Unregistered | | | | Re: unirig pointing ability
[Re: Cheshirecatman]
#188940 08/25/09 11:25 AM 08/25/09 11:25 AM | andrewscott
| andrewscott
Unregistered | OK last question about putting the cat on her side... wouldn't that cause some bend in the mast from holding the mast head? Do you need a few people in different places to reduce bend (from being held sideways)
I ask because my cat is currently getting new diamond wire turnbuckles (the old ones were wrong/not adjustable) and i want to do this... | | | Re: unirig pointing ability
#188944 08/25/09 11:43 AM 08/25/09 11:43 AM |
Posts: 4,451 West coast of Norway | Hi Rolf, I think my mainsail was a special order from the local agent to E/P, although I was never asked my weight, wind condition,etc. I have readed on another thread, you mention 10-12% for chord to depth ratio. Is 10= flat, 12=full? What about the location of that maximum draft, 35%? Same location troughout the sail? After the sailing season, once I bring the boat home, I would like to play with the spreaders and diamonds adjustments trying to match the sail-mast and I start to believe that chord to depth ratio is probably the ultimate result I should look for. Am I wrong?
10-12 percent draft including mast is just a ballpark figure and not the answer to all your performance questions. There are too many variables like boat weight, crew weight, conditions, helming skill, trimming skill etc etc. Max draft placement is much the same, dependent on skill and conditions. With max draft further aft you get better top end speed and pointing, but it takes more skill and less waves/chop to make it efficient. Max draft should by my book be in the same position all the way up to the top on a uni-rig unless you have some unusual sailing conditions. Not so on a sloop rig. Chord to depth ratio is a key for proper setup, but what you do on the water is far more important. I think you are more than ready to play with the settings and find what suits you best on the racecourse. The above is of course just my unqualified opinions, I am neither a sailmaker or professional sailor, just an opinionated sailor  I would definately try to get my mast dialed in as soon as possible. What can be better than getting a good improvement in windward VMG just before the season ends, knowing that you have even more to improve the coming season? I would follow the advice of the good chesirecat  | | |
609
guests, and 23
