| Re: Finally!
[Re: waterbug_wpb]
#188684 08/21/09 04:12 PM 08/21/09 04:12 PM |
Posts: 271 Atlanta, Ga | WRX's are almost too powerful for the autocross unless its a huge open course. We did a lot of events at the Atlanta Braves baseball stadium parking lot. The Miata drivers are probably the craziest people on the course. But other than an E36 M3, there wasn't another car I'd rather autox than my 2.8L A4 Quattro. Lets put that Vehicross between the cones and see what happens! | | | Re: Finally!
[Re: BLR_0719]
#188693 08/21/09 05:34 PM 08/21/09 05:34 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | Lets put that Vehicross between the cones and see what happens! You'd be very, very surprised Brett. The VX is more dirt track Rally than it is Autocross. | | | Re: Finally!
[Re: ThunderMuffin]
#188784 08/23/09 07:56 PM 08/23/09 07:56 PM |
Posts: 171 Cary, NC | Well I got the tope out on the water today! Hit the launch area at 8:30 and by 9:15 we were on the water  The boat is a blast to sail! I definitly have some little issues to work out, with the windward jib cleating its hard to get much purchase on the jib sheet for the crew. I also need to come up with a better way to secure the jib tack up front, what have works, its just not ideal. Managed to get out solo a little bit as well, what a difference! Only casualty of the day is the trampoline, apparently I am fat, or the stitching is just old and sunbaked. First tack we go from port to starboard and it split the seam from front to back, yanked it off tonight and am going to get it repaired this week. Anyone know someone around Raleigh with a heavy duty sewing machine? Pics to come soon
Ryan 1983 Isotope
| | | Re: Finally!
[Re: Storz]
#188786 08/23/09 08:39 PM 08/23/09 08:39 PM |
Posts: 807 Hillsborough, NC USA | Well I got the tope out on the water today! Hit the launch area at 8:30 and by 9:15 we were on the water  Great news Ryan! Too bad you couldn't make the Nationals this weekend, but we're looking forward to Catfest. The boat is a blast to sail! I definitly have some little issues to work out, with the windward jib cleating its hard to get much purchase on the jib sheet for the crew. I also need to come up with a better way to secure the jib tack up front, what have works, its just not ideal. Managed to get out solo a little bit as well, what a difference! There's a technique to getting the jib sheet all the way in, or you can switch to 2:1 purchase. I had 2:1 purchase for a while, but changed back because it's less line to haul in on each tack. I cah show you how I sheet the jib, and how to attach the tack at the lake. Only casualty of the day is the trampoline, apparently I am fat, or the stitching is just old and sunbaked. First tack we go from port to starboard and it split the seam from front to back, yanked it off tonight and am going to get it repaired this week.
Anyone know someone around Raleigh with a heavy duty sewing machine? Joleen and Howard have heavy-duty sewing machines at Howard's loft in Raleigh. If you bring your trampoline over, she or Howard can work with you to restitch it. Regards, Eric | | | Re: Finally!
[Re: Isotope235]
#188805 08/24/09 06:01 AM 08/24/09 06:01 AM |
Posts: 171 Cary, NC | Joleen and Howard have heavy-duty sewing machines at Howard's loft in Raleigh. If you bring your trampoline over, she or Howard can work with you to restitch it.
Awesome, where is the loft at? I would like to try to get it fixed during the week so we can use the boat again next weekend, I may call around a few places in Cary as well to see if they can do it - though I am doubtful I'll find anywhere...
Ryan 1983 Isotope
| | | Re: Finally!
[Re: ThunderMuffin]
#188812 08/24/09 07:12 AM 08/24/09 07:12 AM |
Posts: 171 Cary, NC | Canvas shops, shoe repair places... Shoe repair, hadn't thought of that, thanks.
Ryan 1983 Isotope
| | | Re: Finally!
[Re: Storz]
#188823 08/24/09 09:20 AM 08/24/09 09:20 AM |
Posts: 171 Cary, NC | Taking it up to a local shoe repair place at lunch, says he should be able to fix it no problem.
Ryan 1983 Isotope
| | | Re: Finally!
[Re: Storz]
#188856 08/24/09 06:02 PM 08/24/09 06:02 PM |
Ryan 1983 Isotope
| | | Re: Finally!
[Re: Storz]
#188959 08/25/09 01:14 PM 08/25/09 01:14 PM |
Posts: 271 Atlanta, Ga | An Isotope meeting the One Design class specifications can be raced as a single handed Formula 16 boat. An Isotope with a spinnaker can be raced with crew in the Formula 16 one up class.
Just trying to understand this. I guess one-up they consider the Jib to be the spin? (F16 max jib area = 3.7m sq, Isotope jib= about 4.2m sq // can't race F16 one-up with jib) And, since the difference between one or two up on an F16 is in the use of the jib with no variance to the class or rating, what exactly does "An Isotope with a spinnaker can be raced with crew in the Formula 16 one up class." mean?
| | | Re: Finally!
[Re: BLR_0719]
#188963 08/25/09 01:39 PM 08/25/09 01:39 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | It means it was poorly written.
I think they mean it can race F16 if one man on boat, no jib, add spinnaker.
E-Scow 24' ULDB
| | | Re: Finally!
[Re: BLR_0719]
#189000 08/25/09 06:50 PM 08/25/09 06:50 PM |
Posts: 807 Hillsborough, NC USA | An Isotope meeting the One Design class specifications can be raced as a single handed Formula 16 boat. An Isotope with a spinnaker can be raced with crew in the Formula 16 one up class.
Just trying to understand this. I guess one-up they consider the Jib to be the spin? (F16 max jib area = 3.7m sq, Isotope jib= about 4.2m sq // can't race F16 one-up with jib) And, since the difference between one or two up on an F16 is in the use of the jib with no variance to the class or rating, what exactly does "An Isotope with a spinnaker can be raced with crew in the Formula 16 one up class." mean? F16 class rules allow you to sail singlehanded with main and gennaker, or doublehanded with main, jib, and gennaker. Although I can't find it in the class rules, I understand that the Isotope was grandfathered in (along with the Hobie 16 et. al.). I believe that would allow you to sail an Isotope single-handed with main and jib (rather than gennaker). I haven't looked, but a jib might fall within the measurement rules of the gennaker as well. An Isotope fitted with a gennaker could be raced 2-up with three sails (provided everything measured in). There was an effort a while back to fit various local boats with spinnakers and race them in F16 Open Class. I bought a spin but never got around to rigging it. I doubt an Isotope would be truly competitive with a boat optimized for F16 class, but it would be fun to join in anyway. Regards, Eric | | | Re: Finally!
[Re: Isotope235]
#189004 08/25/09 07:11 PM 08/25/09 07:11 PM |
Posts: 171 Cary, NC | Hmmm....Isotope with a spin  Sounds like fun
Ryan 1983 Isotope
| | | Re: Finally!
[Re: Isotope235]
#189037 08/26/09 04:26 AM 08/26/09 04:26 AM |
Posts: 976 France | Although I can't find it in the class rules, I understand that the Isotope was grandfathered in (along with the Hobie 16 et. al.). The hobie 16? That was never grandfathered into the class! Grandfathering is dependent on your local F16 association. I believe that would allow you to sail an Isotope single-handed with main and jib (rather than gennaker). I haven't looked, but a jib might fall within the measurement rules of the gennaker as well. No way. A jib is not a gennaker. The F16 box rules are really clear on what a gennaker is. | | | Re: Finally!
[Re: pepin]
#189040 08/26/09 05:09 AM 08/26/09 05:09 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I think FasterDamit is on the right tracks. As I see it from previous posts single handed the ISO fits straight into the box rules (no jib). However, if you wanted to race with a crew (two up) you would want to rig the jib but the jib is 0.5m sq to big to fit into the box rule hence the confusion. Pepin is correct it is up to the discretion of the local association chairman to decide whether or not to Grandfather a boat. Here in the UK the Stealth R has been grandfathered and that has a larger jib than the F16 rules. I have purposely left out mentioning the Spi as I didn't want to confuse the issue but would strongly recommend fitting one if you fancy racing as an Open F16. Or just enjoy the buzz of going downwind fast but before you buy anything just make sure your mast and platform will take the extra loads. MP*MULTIHULLS | | | Re: Finally!
[Re: pepin]
#189051 08/26/09 08:11 AM 08/26/09 08:11 AM |
Posts: 807 Hillsborough, NC USA | The hobie 16? That was never grandfathered into the class! Grandfathering is dependent on your local F16 association. ... No way. A jib is not a gennaker. The F16 box rules are really clear on what a gennaker is. Well, since there is no local F16 association (as far as I can tell), this discussion is rather moot. I did sail with a Taipan 4.9 once and we raced on Portsmouth. I doubt there are many (if any) Isotopes racing where the F16 is popular either, as we are primarily a local fleet. I had recalled the F16 rules being more inclusive with existing designs, but I must be mistaken. Too bad  . I admit that I don't understand why, since the other designs wouldn't be as fast as a ground-up F16 boat anyway. | | | Re: Finally!
[Re: Isotope235]
#189163 08/27/09 06:19 AM 08/27/09 06:19 AM |
Posts: 5,525 | http://www.gulfportyachtclub.com/ Come on down! We are hosting the "Global Challenge" in November and there is an annual event in April. Lots of F16s from all over. I'm sure you'll need a spinnaker to be competitive.
Pete Pollard Blade 702
1 registered members (vasil),
412
guests, and 25
