| windage #188864 08/24/09 08:15 PM 08/24/09 08:15 PM |
Joined: Sep 2003 Posts: 264 Long Island, NY gregP19 OP
Posts: 264 Long Island, NY | I'm curious. How significant is the aerodynamic drag(and possibly hydrodynamic drag in chop) from the mid-pole snuffer when an F16 is going upwind? It seems that racing this boat in light air solo against sloop rigged non-spin boats might be a disadvantage.
G Gove
Blade #728
Long Island, New Yawk
| | | Re: windage
[Re: gregP19]
#188869 08/24/09 08:36 PM 08/24/09 08:36 PM |
Posts: 6,049 Sebring, Florida. | There is some drag there, no doubt, but what would you do instead, launch the spin off the tramp like in the dark ages? That would be a tuff snuff if you were racing solo!
Blade F16 #777
| | | Re: windage
[Re: Brett Goodall]
#188896 08/25/09 02:09 AM 08/25/09 02:09 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I have been told that an open mouthed snuffer (The opening facing more toward the tack than the head)compared to a closed mouth snuffer (opening pointing towards the head of the kite when set) is equivalent to carrying an extra 3kgs or 6.6lbs due to the additional drag. MP*MULTIHULLS | | | Re: windage
[Re: Rolf_Nilsen]
#188902 08/25/09 04:11 AM 08/25/09 04:11 AM |
Posts: 954 Mumbles Y.C Wales U.K | Hi Rolf I used the term "drag" in the post above and this probably isn't strictly correct. Wind resistance could have been more accurate. How this ex World Champ, Engineer and Foil manufacturer amongst other things came up with 3kgs is beyond my comprehension but I still have no reason to doubt him. However, I have yet to amend the angle of my snuffer mouth to reduce wind resistance but that doesn't mean to say it wont stay on my 'to do list'. Every time I look at my avatar photo it reminds me
[Re: scooby_simon]
#188912 08/25/09 05:06 AM 08/25/09 05:06 AM |
Posts: 586 Hobart, Tasmania, Oz. | It has been suggested to me that the weight of the spinnaker, snuffer and pole when wet has an affect on the boat pitching more when sailing upwind in a chop. the pitching slows the boat down.. but how would you measure that???
| | | Re: windage
[Re: Dazz]
#188914 08/25/09 05:21 AM 08/25/09 05:21 AM |
Posts: 4,451 West coast of Norway | Increased windage is a factor, all testing and calculations indicates so. In the beginning (2001) the classic Tornado was still faster than the new rig Tornado upwind with the top Tornado teams sailing both boats. This was at the multihull evaluation event arranged by ISAF at the time and removed sailor skill quite well from the equation. I just stalled a bit on the 3kg number as there must be a lot of intermittent steps between increased windage and calculated weight on the boat. That was all that was behind my question and it was not intended as a loaded question. Dazz, only way I can see to do that would be two boat testing or some creative numbers games and a calculator. I guess it is more a question of feel and we certainly agreed when we switched from the classic to the modern Tornado. Going out on double trapeeze and trapeezing downwind more than made up for it in sailing pleasure we thought. Greg, you are sailing under a yardstick system I guess. To stop people from removing their spi gear the day of the regatta everybody here have to declare at the time of signing up for the event wether they will sail with or without spi. If they dont say anything, it is assumed that they will sail with their boat set up like it is for the boats measurement certificate. This is enforced and if you race without spi, you are still scored as if you used the spi. I think that is a good system. Even in light winds I much prefer sailing downwind with a spi compared to without  | | | Re: windage
[Re: gregP19]
#188923 08/25/09 07:35 AM 08/25/09 07:35 AM |
Posts: 548 MERRITTISLAND, FL | I'm curious. How significant is the aerodynamic drag(and possibly hydrodynamic drag in chop) from the mid-pole snuffer when an F16 is going upwind? It seems that racing this boat in light air solo against sloop rigged non-spin boats might be a disadvantage. C'mon guys - 6lbs of additional weight? Not that I am disagreeing about there being some VERY minor efect from windage, but most of it has to come from your head if is is noticable. The hoop and sock on these boats is in line with the water and moved down to be close in plane with the tramp and beams. Those would be hard to remove from a boat and provide aerodynamic drag anyway. Most drag effects, like this do not become mathmaticaly significant untill the wind is high. And the advantages of the spin off the wind are undeniably significant. The general concensus seems to be that additional volume and freeboard are good things, but both of these have a pretty significant negative effect on the windage drag also. In a solo application with light air and flat water, the current F16 designs are far from being optimal, as they have to be able to do 2-up and rough conditions equally. | | | Re: windage
[Re: Matt M]
#188925 08/25/09 08:11 AM 08/25/09 08:11 AM |
Posts: 5,525 | I've lost twice that and it doesn't seem to matter!
Pete Pollard Blade 702
| | | Re: windage
[Re: Rolf_Nilsen]
#188937 08/25/09 11:04 AM 08/25/09 11:04 AM |
Posts: 3,906 Clermont, FL, USA | Greg, you are sailing under a yardstick system I guess. To stop people from removing their spi gear the day of the regatta everybody here have to declare at the time of signing up for the event wether they will sail with or without spi. If they dont say anything, it is assumed that they will sail with their boat set up like it is for the boats measurement certificate. This is enforced and if you race without spi, you are still scored as if you used the spi. I think that is a good system. As a heads up, this issue is not covered by the F16 class rules and therefore must be in the NOR or SI's to be binding. Gentlemen's agreements are well and good but we all know people are people and regardless of an agreement reached on the beach if a rule hasn't been broken a gentlemens agreement really doesn't mean much for some people. Besides, if it's formalized you don't run the risk of souring an otherwise very pleasant weekend. Just my 2 cents, I'm leaving now.
| | | Re: windage
[Re: David Ingram]
#188955 08/25/09 12:53 PM 08/25/09 12:53 PM |
Posts: 3,528 Looking for a Job, I got credi... | As a heads up, this issue is not covered by the F16 class rules and therefore must be in the NOR or SI's to be binding. Gentlemen's agreements are well and good but we all know people are people and regardless of an agreement reached on the beach if a rule hasn't been broken a gentlemens agreement really doesn't mean much for some people. Besides, if it's formalized you don't run the risk of souring an otherwise very pleasant weekend.
F16 clas rules state what an F16 is. AS long as the boat conforms tio the class rules, it's an F16. Exactly the same is true of an F18 i'd expect, unless your class rules are different from the norm. If this is NOT the case then the boat is not an F16. No issues with class rules within the F16's.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: windage
[Re: scooby_simon]
#188961 08/25/09 01:19 PM 08/25/09 01:19 PM |
Posts: 3,906 Clermont, FL, USA | Okay before this goes off on a tanget that was not intended, my response to Rolf was created with the assumption that teams would be pulling off their spin kit during the regatta which was CLEARLY NOT what he was saying (my bad).
The events where this could be an issue it is handled by the NOR and SI's. It's all good.
| | | Re: windage
[Re: David Ingram]
#188967 08/25/09 01:55 PM 08/25/09 01:55 PM |
Posts: 3,528 Looking for a Job, I got credi... | Okay before this goes off on a tanget that was not intended, my response to Rolf was created with the assumption that teams would be pulling off their spin kit during the regatta which was CLEARLY NOT what he was saying (my bad).
The events where this could be an issue it is handled by the NOR and SI's. It's all good. If you enter an event as an "F16" or "F18" or "Tornado" or Hobie 16, if your boat starts the regatta conforming to the class rules under which you entered and then mid regatta you change something that takes the boat out-of-class, you should get protested and DSQ. Class rules simply define what boats of common name "look" like.
[Re: scooby_simon]
#188969 08/25/09 02:04 PM 08/25/09 02:04 PM |
Posts: 5,525 | This is more like it. I didn't know you guys ate popcorn.
4,285
guests, and 650
