| Re: Looking for Prindle rudders.
[Re: dand]
#189414 08/28/09 12:35 PM 08/28/09 12:35 PM |
Posts: 57 | | | | Re: Looking for Prindle rudders.
[Re: dand]
#189661 08/31/09 10:09 AM 08/31/09 10:09 AM | andrewscott
| andrewscott
Unregistered | there are 2 ads on the beachcats classified for p parts like you are looking for | | | Re: Looking for Prindle rudders.
[Re: dand]
#189679 08/31/09 11:01 AM 08/31/09 11:01 AM |
Posts: 1,403 | Dan: These things are just about bullet proof, and unless you have broken them in half they are still very useful. May I ask what it is that has you thinking you need new rudders? | | | Re: Looking for Prindle rudders.
[Re: Ventucky Red]
#189690 08/31/09 11:45 AM 08/31/09 11:45 AM |
Posts: 829 Charleston, SC | Dand, I've got a set that I'll let go very reasonably. Shoot me an email: velocitytrey (at) gmail.com
Thanks
Trey
[Re: dand]
#189779 08/31/09 06:50 PM 08/31/09 06:50 PM |
Posts: 1,403 | I'll try to describe the problem. The boat and rudders were manufactured in '76. The rudders have seen a lot of rocks. The forward bottom corners are gone. I have epoxied several times to build back the corners, but I am loosing ground. There is no longer a corner, it is a round bull nose. One rudder is split at the bottom forward corner with an 1/8" gap extending 6" up the forward edge.
I suppose anything is repairable with time, patience and skill. Repairing these rudders will require lots of epoxy and filler material (I don't even know what should be used for filler).
If I do not find replacements, I may attempt to rebuild them this coming winter. New ones are simply out of the question due to the expense.
dan Like I said, these things are bullet proof except against rocks, There are gazillion of used one around. Check out Pete Begle's add over on the beachcats. I have some, but they are for a 18-2 and/or 19 | | |
253
guests, and 55
