Stainless rivets and seal the mast base to the mast with 3M 4200 sealant (usually available at wal-mart). If you use 5200, you probably won't be able to get the mast out again.
either the 4200 or 5200 will help work against galvanic corrosion.
Use stainless (or monel) rivets where there is a high loading. Aluminum rivets are very weak.
Re: First time out, Sort of! Man those masts are tough, Sort of!
[Re: ocalacat]
#189585 08/30/0912:54 PM08/30/0912:54 PM
So here are a few pictures of the damage. Any ideas on what I need to do?
Wow, I've never seen that happen, but it is a good thing that it did and you weren't hurt and the mast wasn't damaged.
Like everyone says, just seal it well (4200) and drill new holes for SS or Monel rivets.
I wish I had been thinking because we were cat sailing at Cedar Key yesterday and that might have been within your range. I may be back down here in a few weeks. Probably Sept 19-20 weekend.
You might think ahead to the Cedar Key Regatta coming up in October (10/24-25). You don't need to be a racer to participate. It will be low key and I think mostly H16 and TheMightyHobie18 folks with a few of the remaining Prindles.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay
[Re: ocalacat]
#189586 08/30/0901:04 PM08/30/0901:04 PM
Jody:
Same thing happened to my boom on my H-17. I had to cut about 1" or so off and drill new holes and get new end cap. After that no problem. Just metal stress I guess.
Doug
[Re: ocalacat]
#189590 08/30/0903:51 PM08/30/0903:51 PM
I'll break from the pack and say use aluminum rivets. They don't need to take tremendous load under normal usage, and should something go wrong, it's better to shear the rivets than rip the mast extrusion.
Regards, Eric
[Re: Isotope235]
#189592 08/30/0904:09 PM08/30/0904:09 PM
Regards, Eric
I agree and am sure AL will be fine. They are much easier to pop and you can get them and a basic tool at the hardware store.
However, OE would be Monel and I supose there might be a reason Hobie did that. They use Monel in all applications, loaded and not loaded.
[Re: Isotope235]
#189593 08/30/0904:29 PM08/30/0904:29 PM
Regards, Eric
Gonna take a flier - huh?
#189600 08/30/0906:57 PM08/30/0906:57 PM
I have had that happen on my old Prindle 16. Just clean it up, load it up with 5200 and rivet her in. I would also check the rest of the mast closely. Chances are if you are seeing that there...you will see other areas that need attention. Also make sure you seal any possible holes with the 5200. If you capsize and the mast leaks, the boat will go turtle. We recently stripped my SC 20 mast bare and sealed everything with some special aircraft sealant Rob uses.
Monel rivetts will cost you a little bit more but they're non reactive with the metals your putting them into so if you use them this wont happen again. The state of that corrosion would make me get the mast thouroughly checked and if needed re-rivetted, the sidestays, forestay and bridle replaced. It sounds a bit much to spend on an older boat but if you read my post I'm putting up now about me sidestay breakage this year it may encourage you.
[Re: ocalacat]
#189622 08/31/0907:05 AM08/31/0907:05 AM
Sad Story! Certainly one that demonstrates the passion of someone to get on the water. Your plan started right, but I can't believe there is no one around Ocala that could have helped you. We are lucky here in New York (even though we have to tear our boats down in another month): we get to leave our boats set up sitting on trailers; we have our own tractor to drop the boats in the water and we have on-site storage for our wetsuits, shells and gear. I honestly don't think I would own a catamaran anymore if I had to set it up every time I went out. \
We go to Florida to sail every year for about a month, and I watch people drive up to the shoreline and completely set up for a day's sailing, and I always feels sorry for them because they are missing a sense of the freedom that comes with just showing up with your cooler and choosing which sail and clothing to use and shoving off.
Anyway,Good Luck. It sounds like you'll be able to get replacement mast steps and rivet them on. There is a device you can buy to make your task easier; it's easy-step or something like that; it use to sell for about $110. I guess by now its quite a bit more.
Keep sailing; it's more than fun, it becomes a way of life.
Wyatt
[Re: ocalacat]
#189860 09/01/0910:46 AM09/01/0910:46 AM
Sailing off of Singer Island Saturday. Bring the boat down and I can show you the ropes. Full Moon and you can camp on Peanut Island.
Anyone else interested come on down. Free launchiing at Phil Foster Park, less than 1 mile from the Palm Beach Inlet and less than 1/2 mile from Peanut Island.
I remember the same thing happening to me on my first H16. The first time, the cast aluminum housing broke just like yours.. I re-drilled 4 holes and fixed it with aluminum rivets but it occurred again. This time the rivets sheared off.
What I learned with raising my H16 mast.... I now have a second person push down on the bottom of the mast to push it into the mast base housing. Or if I'm by myself, Once I get the mast up on my shoulder, I pull the lower part of the mast up and back with one hand as you lift the mast with the other. The 16 mast step is designed where the lever part can get pinched and the torque of raising the mast will rip the mast plate out of the mast... Using the H14 hole for the step pin helps a little but it is just a Bad design.
The jib looks funny to me.I don't think I have something quite right?
Hard to tell exactly....are your shrouds REALLY loose? Once the jib is up, you need to pull even harder on the jib halyard to bring the mast forward and tighten the rig. This'll make that jib hang a little prettier, too. If the mast won't rotate, you've tightened too much. Under sail, your leeward shroud will still be pretty loose...that's normal.
Now go and switch those aluminum rivets in that mast base with SS or Monel like their supposed to be!
Jerome Vaughan Hobie 16 Clinton, Mississippi
[Re: rattlenhum]
#190302 09/04/0903:47 PM09/04/0903:47 PM
If you tension the jib halyard to the point the mast shrouds tighten/mast leans further forward...you will stretch/break the jib luff when you tension the mainsheet. You don't want the sail luff to be acting like a forestay!
Always tighten the mast shrouds first, getting the rig tight enough to reduce forestay slack. Then tension the jib halyard to take wrinkles out (and not much more).
[Re: Tornado]
#190307 09/04/0904:40 PM09/04/0904:40 PM
Mike,
The Hobie 16 has a wire in the luff of the jib to become the forestay.
So, should I not take this out until I replace the rivets with SS? I was hoping to finally get this thing on the water tomorrow.
Next question and this may sound really stupid, but how do I get the tiller extension from one side to the other with the main sheet in the way? Am I missing something here?
