Jib with or without battens #189618
08/31/09 04:25 AM
08/31/09 04:25 AM
C
cooper engineer Offline OP
C
the next week I will buy a new one jib. it's better with or without battens ? which are the differences ?
Thanks
Re: Jib with or without battens [Re: cooper engineer] #189651
08/31/09 09:14 AM
08/31/09 09:14 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Well, we usually like to know what boat you're putting it on.
Also, is this an aftermarket, or class legal sail.
Unless they are vertical battens, or very short ones at the leech, you can't furl a fuilly battened jib. So that would be a con.
F-18 Infusion
#626- SOLD it!
Re: Jib with or without battens [Re: Todd_Sails] #189671
08/31/09 10:42 AM
08/31/09 10:42 AM
C
C
it's right.
The cat is a F20 with selftacking jib; this is a pic .......
http://www.catsailor.com/forums/ubb...p;Number=10897&filename=HPIM2748.JPG
I want modify it or buy a new one ..... but with or without battens ?
Thanks
Re: Jib with or without battens [Re: cooper engineer] #189673
08/31/09 10:50 AM
08/31/09 10:50 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
With battens. Otherwise the leech will flutter.
Mike Hill
N20 #1005
Re: Jib with or without battens [Re: cooper engineer] #189674
08/31/09 10:51 AM
08/31/09 10:51 AM
andrewscott
andrewscott
do you want the ability to furl? this is a great feature to depower or beach the cat.. but if your primary purpose is racing.. i would think battens are desired.
Self tacking jibs i have seen have not had battens but they were furlable.
You can add small angled battens afterwords if needed
It might really be worth your while to talk with a sailmaker if possible, even better for him/her to see your rig
Re: Jib with or without battens [Re: ] #189701
08/31/09 12:11 PM
08/31/09 12:11 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Most new F18 jibs are battened now. No requirement to furl.
With battens the sail will last a bit longer and you will have to take care how to put it away as you can only roll it so that is better for the sail as well.
0 registered members (), 21,518 guests, and 424 spiders.
