| Re: Infusion blades
[Re: wildtsail]
#189751 08/31/09 04:18 PM 08/31/09 04:18 PM |
Posts: 1,203 uk | Almost finished making a pair for mine.
| | | Re: Infusion blades
[Re: wildtsail]
#189814 09/01/09 01:48 AM 09/01/09 01:48 AM |
Posts: 120 | The new boats are also coming with little notches in the back of the well to fit carpeting. My boat came in the same container as some of these and doesn't have this.
NACRA has scrapped the jibbing centre boards. I would say this is the different between the two wells. | | | Re: Infusion blades
[Re: wildtsail]
#189850 09/01/09 08:39 AM 09/01/09 08:39 AM |
Posts: 120 | I'm aware they scrapped the jibing daggerboards but would making the distance in the back of the well bigger help reduce the jibing? Not directly. Simply put, the leading edge of the board moves as much as the trailing edge, meaning the whole slot is a different shape. This has to do with loading the board correctly so that it jibes to the correct place in the case. The notch in the back of the case (as you describe it) simply creates space for carpet to fix the board in position. After you add the carpet the resulting gap is actually smaller and fixes the board in place. It's a simple approach to fitting a board into a hull, the production tolerances are greater resulting in cheaper production costs but the trade off that reduction in accuracy. Just to be 100% clear I haven’t seen this notch in the NACRA case as you describe it. It sounds exactly the same as what Hobie has done in the wildcat and that is what I have described above. Possibly the problems you are describing is why NACRA has moved away from the jibbing boards and chosen this new solution. | | | Re: Infusion blades
[Re: Brett Goodall]
#189885 09/01/09 12:39 PM 09/01/09 12:39 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Here is a representation of how it works, looking down from the top. I have exaggerated for this discussion. On the right is the filled in daggerboard and on the left...obviously the Gybing. There is a fair amount of space, on each side, required for the Gybers which may lead to too much extra drag in the water also it tends to chew up the trailing edge. My daggerboard's trailing edges are being repaired right now. While filling I left enough space in the back part, after filling, to allow the trailing edge to have plenty of room. I do not want the same problem again. The space is about equal to what Nacra does, since they started installing the boards fixed and not gybing. I have seen new boats with carpet and without carpet in that area but I do not think it matters if there is enough space so the trailing edge does not touch. Later, Dan | | | Re: Infusion blades
[Re: Dan_Delave]
#189897 09/01/09 01:16 PM 09/01/09 01:16 PM |
Posts: 246 Kiel, Germany | Very interesting - at long last I understood what a gybing daggerboard is! I now wonder if the fact that a boat has gybing daggerboards does influence how much (if at all) one has to lift the boards downwinds. On my Cap I have the feeling that this is only necessary when wind is > 20kts. This is confirmed by the guys of Landenberger Sails. Pretty unusual, I guess ...
F18: C2 / A-Cat: Minelli
| | | Re: Infusion blades
[Re: Baltic]
#189899 09/01/09 01:18 PM 09/01/09 01:18 PM |
Posts: 3,293 Long Beach, California | On the Cap, we have not seen the trailing edge damage Dan notes above. I've sailed happily with the stock set-up since 2006. We find that we start pulling the boards on the run when we get to solid double-trap conditions on the beat. If I'm on the trampoline to fly the 'chute, boards stay down.
| | | Re: Infusion blades
[Re: John Williams]
#189941 09/01/09 06:38 PM 09/01/09 06:38 PM |
Posts: 120 | That's a wicked animation to explain how it works. Gibing board can rip up the trailing edge pretty badly. That's why we, just like Dan, leave room at the trailing edge so it doesn't rub. We find that we start pulling the boards on the run when we get to solid double-trap conditions on the beat. If I'm on the trampoline to fly the 'chute, boards stay down. Correct | | | Re: Infusion blades
[Re: pitchpoledave]
#189943 09/01/09 06:42 PM 09/01/09 06:42 PM |
Posts: 984 2017 F18 Americas Site | I don't think this is quite right. If you look down the trunk of an infusion you will see that the trunk pinches the dagger about 2/3 of the way back. So the gybing takes place around the pinch point, not at the back, at least I think. Does not matter much. Where ever you see it gybe it still uses the same principle. Mine looked like it gybed near the trailing edge. Actually about 1/2 forward of it. That was before the shimming material. Dan | | | Re: Infusion blades
[Re: Dan_Delave]
#189970 09/02/09 07:27 AM 09/02/09 07:27 AM |
Posts: 12 | Try these then, http://www.reverie.ltd.uk/marine_home.php awesome boards made by a man in the composite industry and top nacra crew, he came 3rd in this years archipelago raid where you need strong boards !! I have a set on my shockwave and they are the business !!!. | | | Re: Infusion blades
[Re: wildtsail]
#189973 09/02/09 07:43 AM 09/02/09 07:43 AM |
Posts: 1 | Saw the thread on foils and just thought i'd point out www.reverie.ltd.uk (click marine shop) make autoclaved pre-preg carbon foils finished in white durepox epoxy with clever internal carbon stringers running the full length, lighter and much stiffer than oem plus the trailing edge does not break out easily. Very happy with ours and we have an upf__cker bush fitted so we can pull the leward board up from windward on short course racing. Avaliable for Nacra infusion (as used by several top teams) and new Hobbie wildcat (as used by Mischa at the worlds). | | | Re: Infusion blades
[Re: wildtsail]
#190197 09/03/09 10:18 PM 09/03/09 10:18 PM |
Posts: 586 Hobart, Tasmania, Oz. | Capricorn blades are nearly 1k AUD = bit over $800 USD + freight.
wouldn't want to lose one!
| | | Re: Infusion blades
[Re: Dazz]
#190217 09/04/09 03:46 AM 09/04/09 03:46 AM |
Posts: 246 Kiel, Germany | Concerning the Capricorn, according to my information the problems started with the 2008 models. Before that you are safe. Mine dates from 2007 and up till now I had no problems (knock on wood ...)
| | | Re: Infusion blades
[Re: Baltic]
#190218 09/04/09 04:03 AM 09/04/09 04:03 AM |
Posts: 120 | Concerning the Capricorn, according to my information the problems started with the 2008 models. Before that you are safe. Mine dates from 2007 and up till now I had no problems (knock on wood ...) There was a manufacturing problem, involving laminate bonding with one batch of boards. This problem has been rectified. The really unfortunate thing is that out of the affected batch 80% of them went to Germany in one order. We have replaced any boards that have failed from that batch. If you've been sailing on your board since 2007 I don't think you have much to worry about... unless you hit something  | | |
21,789
guests, and 479
