| Re: Need new tiller extension
[Re: DennisMe]
#189881 09/01/09 12:15 PM 09/01/09 12:15 PM |
Posts: 921 Alachua, FL | !
Any good tips? What do you guys use? Would a paint roller stick work? Thanks, Dennis I have busted several expensive carbon fiber sticks and now I just put together a "paint stick" that cost $13.95 (plus the Ronstan rubber connector of course). I haven't tried it on the water but it looks like it will work fine. If so, I will prep a spare to keep in the cat box.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Need new tiller extension
[Re: Mugrace72]
#189882 09/01/09 12:25 PM 09/01/09 12:25 PM |
Posts: 976 France | Wayne buys 2.5m carbon tube in bulk, distribute them around, and never tell people how much he should be paid for them. Best deal around, a nice extension for the price of a connector  [Note to Wayne: I'm still waiting for that email for how much I owe you for that thing amongst others...] It's not collapsible, but it is extremely light. Compared to the fiber arriba collapsible stick I have on the 5.2 it is way better. | | | Re: Need new tiller extension
[Re: Mugrace72]
#189883 09/01/09 12:26 PM 09/01/09 12:26 PM |
Posts: 171 Cary, NC | Have a picture of your set up Jack? Specifically the little connector...
Ryan 1983 Isotope
[Re: Storz]
#189888 09/01/09 12:52 PM 09/01/09 12:52 PM |
Posts: 921 Alachua, FL | Have a picture of your set up Jack? Specifically the little connector... I don't have a picture but we just talked about this a week or so here. That's were I got the idea. The rubber connector is a standard Ronstan part. You can also use the metal stlyle. Layline has them. Rick might have them here as well. That reminds me, I have to order a set of Cat Tracks.
[Re: Mugrace72]
#189890 09/01/09 12:55 PM 09/01/09 12:55 PM |
Posts: 171 Cary, NC | ^ Thanks, I'll see if I can fine one.
Ryan 1983 Isotope
[Re: Storz]
#189898 09/01/09 01:17 PM 09/01/09 01:17 PM | andrewscott
| andrewscott
Unregistered | Hi Dennis, i am "in the same boat" currently using a duct taped tiller (would not longer lock.. so i taped it up). it is an arriba fiberglass expandable. cost $144 (largest size) many people use ACE or HomeDepot paint sticks but i hear they splinter (or get fiber glass in your hand) you can look at murrays.com (or here i am sure) to see what is out there. i used to use the aluminum ones on my h16.. but i broke my last one and have switched to the more solid feeling arribas (cant say they are any better). my friend uses the carbon/fiberglass combo arriba stick.. it looks and feels nice but is $250? the full carbon one is $350... I think a bit pricey for a stick  | | | Re: Need new tiller extension
[Re: ]
#189900 09/01/09 01:23 PM 09/01/09 01:23 PM |
The one I got is aluminum and is nicely anodized. Of course it is illegal on a Hobie.  ZZZZAAAAP!!!
[Re: Mugrace72]
#189903 09/01/09 01:30 PM 09/01/09 01:30 PM | andrewscott
| andrewscott
Unregistered | i couldn't understand why people bashed the collapsible extension untill.... while flying the hull (on video cam) i was hit with a gust, and instead of heading up when i pushed the tiller extension.. it collapsed...
SPLASH!
[Re: ]
#189910 09/01/09 02:55 PM 09/01/09 02:55 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | i couldn't understand why people bashed the collapsible extension untill.... while flying the hull (on video cam) i was hit with a gust, and instead of heading up when i pushed the tiller extension.. it collapsed...
SPLASH! Its even worse on spin boats while double trapped spin reaching :P Go to bear away and .. kerplunk. | | | Re: Need new tiller extension
[Re: ThunderMuffin]
#189913 09/01/09 03:15 PM 09/01/09 03:15 PM | andrewscott
| andrewscott
Unregistered | i have found capsizing while flying the spinnaker kind of fun... but then again.. it wasn't my boat. and i didn't get wet...  (until i had to jump off the dry hull and help)
[Re: ]
#189914 09/01/09 03:20 PM 09/01/09 03:20 PM |
Posts: 67 Daytona Beach | Deleted
Jeff Bowers Mystere 6.0(sometimes XL)
[Re: Jeff_Bowers]
#189915 09/01/09 03:22 PM 09/01/09 03:22 PM | andrewscott
| andrewscott
Unregistered | Did you break it or just pull the two sections apart. If you just pulled it apart it can be fixed. If it no longer will lock it can be fixed by the same method. i actually have 2 that both recently both stopped locking. 1 was underway in heavy air so i pulled it apart. a piece went flying overboard so that one is shot. the taped up one was never separated.. what is your method to repair?
[Re: ]
#189917 09/01/09 03:28 PM 09/01/09 03:28 PM |
Posts: 67 Daytona Beach | You remove the small section at the base by removing the pin and then the small section will slide off with a little effort(I uses a wood block and the HVH method). Slide the outside off. If you look inside the base of the outside piece you will see that it has been formed to have a high ridge. This is the part that wears so it no longer locks. Use a thin artist paint brush to apply a few layers of epoxy on the ridge(only the ridge). Then reassemble.
[Re: Jeff_Bowers]
#189920 09/01/09 03:59 PM 09/01/09 03:59 PM | andrewscott
| andrewscott
Unregistered | cool... thanks for the info | | | Re: Need new tiller extension
[Re: ]
#189923 09/01/09 04:11 PM 09/01/09 04:11 PM |
Joined: Mar 2008 Posts: 55 Ft Myers Beach, FL walkefmb
Posts: 55 Ft Myers Beach, FL | Swimming pool suppliers carry a variety of extendable poles in different materials too (non-zapp). Trim to fit and pin and epoxy in the universal.
cedar tornado classic, sunfish, 1972 morgan 27 optidad
[Re: ThunderMuffin]
#189942 09/01/09 06:39 PM 09/01/09 06:39 PM |
Ryan 1983 Isotope
[Re: Storz]
#189946 09/01/09 07:03 PM 09/01/09 07:03 PM |
Posts: 921 Alachua, FL | Nice job.
You have the best looking 'Tope around.
[Re: Mugrace72]
#189949 09/01/09 07:22 PM 09/01/09 07:22 PM |
Posts: 171 Cary, NC | Nice job.
You have the best looking 'Tope around. haha I don't know about that but thanks!
Ryan 1983 Isotope
16,262
guests, and 1,190
