Need new tiller extension #189874
09/01/09 11:51 AM
09/01/09 11:51 AM
Netherlands
DennisMe Offline OP
DennisMe  Offline OP
Netherlands
Hi all,
while racing recently I pulled out the top of my tiller extension. It happened while I was trapped out, it wasn't much of a problem but it was a bear to get the pulled out end back on while bouncing around on the water!
Guess I need a new one. I sail an Nacra 5.2 solo so I need a bit more freeedom of movement. Ie; I regularly sit right up at the front beam or trap out from just aft of the shrouds. I currently have a 4' to 6' aluminum twist lock extension. No idea about the brand name, but it is nice and thick! I'm looking for a little more length though, if possible.
I have used a Ronstan X-10 on a previous boat and enjoyed that, but that was a mono...
Any good tips? What do you guys use? Would a paint roller stick work?
Thanks, Dennis
Re: Need new tiller extension [Re: DennisMe] #189881
09/01/09 12:15 PM
09/01/09 12:15 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Thanks, Dennis
I have busted several expensive carbon fiber sticks and now I just put together a "paint stick" that cost $13.95 (plus the Ronstan rubber connector of course). I haven't tried it on the water but it looks like it will work fine. If so, I will prep a spare to keep in the cat box.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Need new tiller extension [Re: Mugrace72] #189882
09/01/09 12:25 PM
09/01/09 12:25 PM
France
pepin Offline
pepin  Offline
France
Wayne buys 2.5m carbon tube in bulk, distribute them around, and never tell people how much he should be paid for them. Best deal around, a nice extension for the price of a connector smile
[Note to Wayne: I'm still waiting for that email for how much I owe you for that thing amongst others...]
It's not collapsible, but it is extremely light. Compared to the fiber arriba collapsible stick I have on the 5.2 it is way better.
Re: Need new tiller extension [Re: Mugrace72] #189883
09/01/09 12:26 PM
09/01/09 12:26 PM
Cary, NC
Storz Offline
Storz  Offline
Cary, NC
Have a picture of your set up Jack? Specifically the little connector...
Ryan
1983 Isotope
Re: Need new tiller extension [Re: Storz] #189888
09/01/09 12:52 PM
09/01/09 12:52 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
I don't have a picture but we just talked about this a week or so here. That's were I got the idea.
The rubber connector is a standard Ronstan part. You can also use the metal stlyle.
Layline has them. Rick might have them here as well. That reminds me, I have to order a set of Cat Tracks.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Need new tiller extension [Re: Mugrace72] #189890
09/01/09 12:55 PM
09/01/09 12:55 PM
Cary, NC
Storz Offline
Storz  Offline
Cary, NC
^ Thanks, I'll see if I can fine one.
Ryan
1983 Isotope
Re: Need new tiller extension [Re: Storz] #189898
09/01/09 01:17 PM
09/01/09 01:17 PM
andrewscott
andrewscott
Hi Dennis, i am "in the same boat" currently using a duct taped tiller (would not longer lock.. so i taped it up).
it is an arriba fiberglass expandable. cost $144 (largest size)
many people use ACE or HomeDepot paint sticks but i hear they splinter (or get fiber glass in your hand)
you can look at murrays.com (or here i am sure) to see what is out there.
i used to use the aluminum ones on my h16.. but i broke my last one and have switched to the more solid feeling arribas (cant say they are any better).
my friend uses the carbon/fiberglass combo arriba stick.. it looks and feels nice but is $250? the full carbon one is $350...
I think a bit pricey for a stick smile
Re: Need new tiller extension [Re: ] #189900
09/01/09 01:23 PM
09/01/09 01:23 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
The one I got is aluminum and is nicely anodized.
Of course it is illegal on a Hobie. wink
ZZZZAAAAP!!!
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Need new tiller extension [Re: Mugrace72] #189903
09/01/09 01:30 PM
09/01/09 01:30 PM
andrewscott
andrewscott
i couldn't understand why people bashed the collapsible extension untill.... while flying the hull (on video cam) i was hit with a gust, and instead of heading up when i pushed the tiller extension.. it collapsed...
SPLASH!
Re: Need new tiller extension [Re: ] #189910
09/01/09 02:55 PM
09/01/09 02:55 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
SPLASH!
Its even worse on spin boats while double trapped spin reaching :P Go to bear away and .. kerplunk.
Re: Need new tiller extension [Re: ThunderMuffin] #189913
09/01/09 03:15 PM
09/01/09 03:15 PM
andrewscott
andrewscott
i have found capsizing while flying the spinnaker kind of fun... but then again.. it wasn't my boat. and i didn't get wet... smile (until i had to jump off the dry hull and help)
Re: Need new tiller extension [Re: ] #189914
09/01/09 03:20 PM
09/01/09 03:20 PM
Daytona Beach
Jeff_Bowers Offline
Jeff_Bowers  Offline
Daytona Beach
Deleted
Jeff Bowers
Mystere 6.0(sometimes XL)
Re: Need new tiller extension [Re: Jeff_Bowers] #189915
09/01/09 03:22 PM
09/01/09 03:22 PM
andrewscott
andrewscott
Originally Posted by Jeff_Bowers
Did you break it or just pull the two sections apart. If you just pulled it apart it can be fixed. If it no longer will lock it can be fixed by the same method.
i actually have 2 that both recently both stopped locking.
1 was underway in heavy air so i pulled it apart. a piece went flying overboard so that one is shot.
the taped up one was never separated.. what is your method to repair?
Re: Need new tiller extension [Re: ] #189917
09/01/09 03:28 PM
09/01/09 03:28 PM
Daytona Beach
Jeff_Bowers Offline
Jeff_Bowers  Offline
Daytona Beach
You remove the small section at the base by removing the pin and then the small section will slide off with a little effort(I uses a wood block and the HVH method). Slide the outside off. If you look inside the base of the outside piece you will see that it has been formed to have a high ridge. This is the part that wears so it no longer locks. Use a thin artist paint brush to apply a few layers of epoxy on the ridge(only the ridge). Then reassemble.
Jeff Bowers
Re: Need new tiller extension [Re: Jeff_Bowers] #189920
09/01/09 03:59 PM
09/01/09 03:59 PM
andrewscott
andrewscott
cool... thanks for the info
Re: Need new tiller extension [Re: ] #189923
09/01/09 04:11 PM
09/01/09 04:11 PM
Ft Myers Beach, FL
walkefmb Offline
walkefmb  Offline
Ft Myers Beach, FL
Swimming pool suppliers carry a variety of extendable poles in different materials too (non-zapp). Trim to fit and pin and epoxy in the universal.
cedar tornado classic,
sunfish,
1972 morgan 27
optidad
Re: Need new tiller extension [Re: walkefmb] #189933
09/01/09 05:23 PM
09/01/09 05:23 PM
Portland, Maine
Portland, Maine
I'm told bamboo works wonders.
After breaking 4 all carbon extensions, I've had my current one now for a half a season without a problem.
Re: Need new tiller extension [Re: ThunderMuffin] #189942
09/01/09 06:39 PM
09/01/09 06:39 PM
Cary, NC
Storz Offline
Storz  Offline
Cary, NC
My 'homemade' paint handle tiller extension, max length is about 6.5 feet, the blue tape is tennis racket stuff. I figure if it is totally worthless I am out 15 bucks, and I'll just break down and buy an Arriba.
Ryan
1983 Isotope
Re: Need new tiller extension [Re: Storz] #189946
09/01/09 07:03 PM
09/01/09 07:03 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Nice job.
You have the best looking 'Tope around.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Need new tiller extension [Re: Mugrace72] #189949
09/01/09 07:22 PM
09/01/09 07:22 PM
Cary, NC
Storz Offline
Storz  Offline
Cary, NC
Originally Posted by Mugrace72
Nice job.
haha I don't know about that but thanks! grin
Ryan
1983 Isotope
Most Online22,490
Yesterday at 08:14 AM
