Delamination on the side of a Hobie Hull #19123
04/30/03 03:08 PM
04/30/03 03:08 PM
rutlean Offline OP
rutlean  Offline OP
I have heard it is not necessary to repair delamination to the side of the hull. Does anyone have more information on this? I bought some laminating resin this morning that I plan on injecting into the sides between the foam sandwich that seems to have rotted. Does this sound like a bad idea. I don't want soft sides, but I don't want to cause more problems than i already have. Thanks for any help.
Re: Delamination on the side of a Hobie Hull [Re: rutlean] #19124
04/30/03 03:24 PM
04/30/03 03:24 PM
C
char Offline
char  Offline
C
Hobie has a page on how to repair delam on it's website, sounds like you are on the right track. Repair it now before it spreads.
Re: Delamination on the side of a Hobie Hull [Re: char] #19125
04/30/03 03:32 PM
04/30/03 03:32 PM
rutlean Offline OP
rutlean  Offline OP
The only thing that makes me wonder though is that the repair on hobie's site looks like one for the top(deck). I just hope that the sides are that thick too.
Re: Delamination on the side of a Hobie Hull [Re: rutlean] #19126
04/30/03 07:19 PM
04/30/03 07:19 PM
catman Offline
catman  Offline
The hulls are built the same way. Just as thick.
Re: Delamination on the side of a Hobie Hull [Re: catman] #19127
04/30/03 07:33 PM
04/30/03 07:33 PM
catman Offline
catman  Offline
One other thing about injecting resin. Hobie suggested using a plastic bottle to inject resin. I would use a large syringe. Drill the holes the same size as the syringe tip. This way when you stick the tip of the syringe into the hole it will seal somewhat allowing you to pump the resin into the hull and not back out at you.
Re: Delamination on the side of a Hobie Hull [Re: catman] #19128
04/30/03 07:45 PM
04/30/03 07:45 PM
catman Offline
catman  Offline
Allright, one more thing. Thankfully this place is not far from me. If you are looking for syringes or anything for boat building or repair, check this place out. www.fgci.com
Re: Delamination on the side of a Hobie Hull [Re: catman] #19129
04/30/03 09:59 PM
04/30/03 09:59 PM
don't forget these guys - they've got a good selection and usually ship the same day:
www.aircraftspruce.com
Re: Delamination on the side of a Hobie Hull [Re: catman] #19130
04/30/03 11:12 PM
04/30/03 11:12 PM
rutlean Offline OP
rutlean  Offline OP
Thanks for the good information.
0 registered members (), 3,254 guests, and 184 spiders.
