| Re: Designing/Building an F16
[Re: mikeborden]
#191257 09/18/09 10:01 AM 09/18/09 10:01 AM |
Posts: 548 MERRITTISLAND, FL | Carbon is LEGAL, and I think if you wanted to, you could build the whole boat out of carbon if you'd like. At least, I think.
Mike At the moment carbon is legal. There was a proposal to ban it in the class with the reason being to try and keep costs in control. I think the way the rules are currently written it does not matter. A min tip weight on the mast, min weight of the platform and non-glued beams pretty much makes the use of carbon a non-issue. The potential performance difference is limited with these rules and the cost to go with carbon is significant. If some one want to have bling they can, but IMO with these limits it still will not win you any races. | | | Re: Designing/Building an F16
[Re: taipanfc]
#191266 09/18/09 11:52 AM 09/18/09 11:52 AM |
Posts: 6,049 Sebring, Florida. | Well Rolf, my only real concern here is about drilling holes into carbon tubes, through bolting them, and any potential crushing if over-tightened, or cracking if there is any slop, at the drilled hole area.
Are they (the tube builders) going to beef them up in the area of the holes to be drilled?
Blade F16 #777
[Re: Rolf_Nilsen]
#191347 09/19/09 11:02 AM 09/19/09 11:02 AM |
Posts: 50 | I got some Divinycell PVC foam to test out - 6mm H60. A bit underwhelmed... not the magic material I thought it would be - flexible, and feels soft wonder why it costs so much more than blue foam or foam core from the Art shop.. The best way I've seen for a home builder to do beams is by Dr Mark Drela of MIT. You need to get low temp prepreg carbon unidirectional and roll over an aluminium tube thats covered with mylar release film. You have to build a makeshift oven but it only needs 275 deg Fahrenheit. You need to bind it with shrink tape before you stick it in. First the outside heatshrink tape tightens, then the epoxy liquifies and the excess soaks into the paper as the carbon fibers get compacted, then the epoxy gels and finally solidifies. http://www.cstsales.com/carbon_prepreg.html$40 per pound - maybe 7lbs per beam? $280 for hitech carbon beams... Unfortunately, I dont think they can ship prepreg to Singapore since it needs to be kept refridgerated. Shane | | | Re: Designing/Building an F16
[Re: pilgrim]
#191416 09/20/09 05:35 PM 09/20/09 05:35 PM | Scarecrow
| Scarecrow
Unregistered | Pilgrim, the advantage of divinycell over your blue foam will be in the shear strength. This is the crucial property when designing a foam sandwich structure. The flexibility is actually an advantagous feature not only in building but also in the strength of the final structure is it means the skins will take the majority of the load instead of the foam. Most people would use primarily 80kg foam for your application. The 60kg will bruise easily unless you put a lot of glass/carbon over it. | | | Re: Designing/Building an F16
[Re: pilgrim]
#192452 10/01/09 10:18 AM 10/01/09 10:18 AM |
Posts: 50 | Drew up the forms incorporating some of the suggestions that Ncik gave - more volume by using a constant radius circular chine and a narrower transom.. Here are the hand drawn forms... I now realise it looks weird because I dont have the waterline horizontal..the transom bottom should be aligned with the bottom of the bow drats.. I I'll redraw it tomorrow but now its late..
[Re: Rolf_Nilsen]
#192488 10/01/09 07:36 PM 10/01/09 07:36 PM |
Posts: 120 | Looks pretty good.... the real trick now is to draw up the corresponding water line and kiel line and make sure you're happy with them. Just another quick note, and this may happen later.... see if you can let the lines flow a little more.... not just straight line to a radius. This will make it easier to get a nice surface when you get to that stage. This is pretty important in CAD modelling but the same can be said in the real world. http://en.wikipedia.org/wiki/Geometric_continuity | | | Re: Designing/Building an F16
[Re: Brett Goodall]
#192503 10/02/09 07:10 AM 10/02/09 07:10 AM |
Posts: 571 Hamburg | Try the other way around: Fee!ship or the free version of delftship. Don't ask me which one is better. The basic idea is that you control the shape of the hull indirectly with a few parameters. Main characteristics as displacement, prismatic and block coefficient, water plane area etc. are immediatly calculated. As a result you get the section shape and a hull surface which fulfils geometric continuity. You can even check which parts of the hull are developable. A few hours spend in lofting can save days in the workshop... Cheers, Klaus | | |
1,986
guests, and 437
