| Need help restoring a just bought 1979 H16! Hull repair PICS #191356 09/19/09 02:22 PM 09/19/09 02:22 PM |
Posts: 22 | Hey guys! Ive posted on here before when I had a H14 that I was thinking of fixing but after some thought I decided to start with a Hobie 16. Well I ended up buying a 1979 with road and beach trailer. The sail/Jib are great, trampoline looks rough but feels pretty solid....only thing is its missing some hardware, all the lines need to be replaced (thats the next step) and the hulls are also soft. I probably should have just started with some good hulls but I felt for $400 it wasnt a bad deal. Do you guys think these hulls are worth fixing or should I search craigslist for some new used ones? I saw the FAQ about fixing the hulls with the drilling through the top part of the fiberglass. What about the big dents though? The hulls lost some of there form and while the syringe injections could make them strong again they will still be dented. Can it be fixed? Will it affect the ride quality? Im not looking to race this thing, just to have fun and cruise around with the girlfriend. Let me know what you guys think [img] http://i50.photobucket.com/albums/f320/blueovalstanggt/Hobie016.jpg[/img] [img] http://i50.photobucket.com/albums/f320/blueovalstanggt/Hobie017.jpg[/img] [img] http://i50.photobucket.com/albums/f320/blueovalstanggt/Hobie019.jpg[/img] [img] http://i50.photobucket.com/albums/f320/blueovalstanggt/Hobie020.jpg[/img] | | | Re: Need help restoring a just bought 1979 H16! Hull repair PICS
[Re: mbounds]
#191366 09/19/09 07:09 PM 09/19/09 07:09 PM |
Posts: 1,383 Kingston SE South Australia | G'day Kevin I would just plug the holes and get the few bits you need as cheaply as possible and sail it. You could spend $1000 buying bits and pieces and using the injection method to stiffen the hulls and still have a $400 cat thats cracked all over. Just enjoy it and buy a better one if the racing bug bites.
[Re: JeffS]
#191369 09/19/09 07:37 PM 09/19/09 07:37 PM |
Posts: 1,884 Detroit, MI | G'day Kevin I would just plug the holes and get the few bits you need as cheaply as possible and sail it. You could spend $1000 buying bits and pieces and using the injection method to stiffen the hulls and still have a $400 cat thats cracked all over. Just enjoy it and buy a better one if the racing bug bites. I disagree. That boat is unsafe. The foredecks are soft and buckling. Eventually, you'll end up like this (when you least expect it): BTW, the boat in the photo above was not nearly as bad as yours. | | | Re: Need help restoring a just bought 1979 H16! Hull repair PICS
[Re: Keven]
#191379 09/20/09 12:20 AM 09/20/09 12:20 AM |
Posts: 493 Minnesota | That has got to be the worst set of hulls I've seen. Not that I've seen a lot of poor condition hulls up here in Minnesota. I hear many ocean beachfronts are lined with dead Hobies. Hopefully, you got a good trailer set-up, and many non-worn Hobie parts on the boat.
[Re: Keven]
#191386 09/20/09 06:32 AM 09/20/09 06:32 AM |
Posts: 1,383 Kingston SE South Australia | Give it a go just don't go out too far. Can you try and rig it and post pics to work out what your missing?
[Re: Keven]
#191613 09/22/09 09:33 AM 09/22/09 09:33 AM |
Posts: 321 Albuquerque NM | Keven,
2 things you should do before stepping the mast:
1 Seek out other Hobie Sailors in your area (if you have not already tried that). they can help with what connects where and how.
2 LOOK UP before stepping the mast, power lines are a bad thing.
Sam
[b] Sail Like you have a Pair
[Re: Keven]
#191721 09/23/09 12:39 AM 09/23/09 12:39 AM |
Posts: 22 | Thanks! Ill see if I can get some help from friends. Along with the two questions below....can someone let me know if the comptip is that much better then my all aluminum mast? Is the only difference weight (can i re-use the sails I have now?). I found someone selling some new(used) pontoons and he also has this mast. Sure can! I have a couple huge exams coming up this week but after that I plan on trying to assemble this thing.
Can I use any stainless bolt/nut for the pin im missing between the mast/trampoline structure? And whats something I can use to clean my sails/trampoline? | | | Re: Need help restoring a just bought 1979 H16! Hull repair PICS
[Re: Keven]
#191747 09/23/09 08:57 AM 09/23/09 08:57 AM |
unless you are going to race in Hobie class races, you do not need to have a CompTip mast. I have read (more than once) that the all Al masts will be faster than the comptip, but at my level of sailing, a broom stick might work just as well.
As for the stainless bold/nut question, if you are talking about the mast step (blob of cast AL in center of front beam), you will need to use a stepping link between the mast base and the step base. The link acts like a hinge to allow the ball at the bottom of the mast to clear the side of the base.
378
guests, and 111
