| A tip for the single-handed spinnaker crowd #191521 09/21/09 08:11 PM 09/21/09 08:11 PM |
Joined: Feb 2005 Posts: 4,119 Northfield Mn Karl_Brogger OP
Posts: 4,119 Northfield Mn | When trapezing down wind, you can not gybe from the wire. I'm pretty sure it is impossible if you want to gybe quickly. When you tack, the boat turns up into you. When you gybe, it goes bye bye, and you're left hanging in space. I learned this little tid-bit on Saturday. Port/starboard situation, I had no rights, and waited too long to determine that collision was imminent with out action. I pulled the tiller, and was unable to get on the tramp before it went over.  Bad start, and I was at the back of the fleet at the windward mark, when I tipped I had made it to about the middle of the fleet though. | | | Re: A tip for the single-handed spinnaker crowd
[Re: Karl_Brogger]
#191523 09/21/09 08:16 PM 09/21/09 08:16 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | So thanks to good ol' inertia, you watched the boat turn away as the space between the hull and your feet steadily increased?
E-Scow 24' ULDB
[Re: Karl_Brogger]
#191525 09/21/09 08:20 PM 09/21/09 08:20 PM |
Posts: 531 Lake Murray SC | Doing it is waaaay cooler than than just cogitating. Bravo!
E-Scow 24' ULDB
[Re: Karl_Brogger]
#191536 09/21/09 10:11 PM 09/21/09 10:11 PM |
Posts: 334 Seattle,Wa | Karl, Where are you standing on the boat during the jibe? If you are on the back of the boat, out on the wire, and running downwind; wouldn't you pull the tiller and thereby drive the sterns toward your feet?
Regardless, I'd recommend some foot straps where ever you happen to be standing... Hobie Tiger 2003 | | | Re: A tip for the single-handed spinnaker crowd
[Re: Don_Atchley]
#191538 09/21/09 10:54 PM 09/21/09 10:54 PM |
Posts: 4,119 Northfield Mn | Karl, Where are you standing on the boat during the jibe? If you are on the back of the boat, out on the wire, and running downwind; wouldn't you pull the tiller and thereby drive the sterns toward your feet?
Regardless, I'd recommend some foot straps where ever you happen to be standing... Back foot was just a bit forward of the rear crossbar. It didn't work that way for me. The boat just drives away from you. Been meaning to order a set of foot straps, but trying to get a new boat as well. I'm not sure how much more money I want to dump into it if I'm not going to keep it. I think to wire well downwind single handed you really need to be on top of what's going on, and plan ahead well. | | | Re: A tip for the single-handed spinnaker crowd
[Re: Karl_Brogger]
#191562 09/22/09 06:13 AM 09/22/09 06:13 AM |
Posts: 1,203 uk | I will concur.. As a helm that was heavier than my crew sailing the nacF18 [which is a bitch downwind in a breeze], i went through a spell of doing the trapezing downwind - OK in a straight line, but the corners did get a bit messy! experiment abandoned. problem solved by purchase of infusion!
[Re: TEAMVMG]
#191598 09/22/09 08:10 AM 09/22/09 08:10 AM |
Posts: 3,906 Clermont, FL, USA | experiment abandoned. problem solved by purchase of infusion!
It does make the trip downhill a bit more pleasant.
[Re: Karl_Brogger]
#191601 09/22/09 08:16 AM 09/22/09 08:16 AM | andrewscott
| andrewscott
Unregistered | When trapezing down wind, you can not gybe from the wire. I'm pretty sure it is impossible if you want to gybe quickly. When you tack, the boat turns up into you. When you gybe, it goes bye bye, and you're left hanging in space. Karl, try this... next time stuff the bows just before the massive gybe.. and peter pan around the forestay to the otherside... Please report back and let us know if that helps. | | | Re: A tip for the single-handed spinnaker crowd
[Re: ]
#191611 09/22/09 09:01 AM 09/22/09 09:01 AM |
Posts: 893 | When trapezing down wind, you can not gybe from the wire. I'm pretty sure it is impossible if you want to gybe quickly. When you tack, the boat turns up into you. When you gybe, it goes bye bye, and you're left hanging in space. Karl, try this... next time stuff the bows just before the massive gybe.. and peter pan around the forestay to the otherside... Please report back and let us know if that helps. Just as you Peter Pan to the front stay, dip your feet in as far you can go into the watery mass below you, I bet the boat sails on past and scoops you back up to almost where you were, it works a real treat and I'm now well practiced in the art. | | | Re: A tip for the single-handed spinnaker crowd
[Re: TEAMVMG]
#191620 09/22/09 10:13 AM 09/22/09 10:13 AM |
Posts: 713 WA, ID, MT | I will concur.. As a helm that was heavier than my crew sailing the nacF18 [which is a bitch downwind in a breeze], i went through a spell of doing the trapezing downwind - OK in a straight line, but the corners did get a bit messy! experiment abandoned. problem solved by purchase of infusion! Can you elaborate on the Nacra F18's downwind behaviour? I buried the bow a couple of times under spinnaker recently, in about 20 kts of wind, much to my surprize. I'm new to this boat, and I've not had this much difficulty with the other spin boats I've driven. Thanks! Dave | | | Re: A tip for the single-handed spinnaker crowd
[Re: ]
#191625 09/22/09 10:27 AM 09/22/09 10:27 AM |
Posts: 4,119 Northfield Mn | Karl, try this... next time stuff the bows just before the massive gybe.. and peter pan around the forestay to the otherside...
Please report back and let us know if that helps. Awesome! You should know, I may unhook the bungee and try this just for entertainment value.  Except I better be haulin' the mail, cause I'd have to clear the spinnaker as well. | | | Re: A tip for the single-handed spinnaker crowd
[Re: davefarmer]
#191627 09/22/09 10:31 AM 09/22/09 10:31 AM |
Posts: 6,049 Sebring, Florida. | Karl, I have found that if you put both feet out, toes up, you can usually water-ski along side the boat as you steer the boat, then you just hop up onto the tramp, toss the tiller out back, cross under, switch hands with the spin sheet, hook up, grab the tiller and jump back out on the other gybe, sheet it and go.
Nothing to it...
Blade F16 #777
[Re: Timbo]
#191636 09/22/09 11:19 AM 09/22/09 11:19 AM | andrewscott
| andrewscott
Unregistered | Karl, I have found that if you put both feet out, toes up, you can usually water-ski along side the boat as you steer the boat, then you just hop up onto the tramp, toss the tiller out back, cross under, switch hands with the spin sheet, hook up, grab the tiller and jump back out on the other gybe, sheet it and go. Nothing to it... Seems easy enough | | | Re: A tip for the single-handed spinnaker crowd
[Re: ]
#191656 09/22/09 01:12 PM 09/22/09 01:12 PM |
Posts: 5,590 Naples, FL | Timbo didn't mention adjusting the daggarboards while gybing, but maybe that's covered in his "Gybing 102" class...
[Re: waterbug_wpb]
#191659 09/22/09 01:32 PM 09/22/09 01:32 PM |
Posts: 6,049 Sebring, Florida. | I didn't want to overload him...
I forgot to mention that as you come in off the wire, of course you have to be trimming the spin sheet, I usually put my sheet hand up over my head and then around my back just before I unhook with my other hand and pass under the boom.
And wearing sneakers 3 sizes too large will help with the waterskiing.
Footstraps will just slow you down when you attempt this manouver...and they add too much weight, so save yourself the $30 and just "ski" through the gybe.
Blade F16 #777
[Re: Timbo]
#191664 09/22/09 01:44 PM 09/22/09 01:44 PM |
Posts: 186 Chattanooga, TN | I am so excited that the GCs will be soon and I can witness the master at work. Can you help me practice this on Sat before racing starts so I can be in top form for the week?
Jody
Blade F16 724
Plays with Sharp Objects
[Re: davefarmer]
#191668 09/22/09 02:15 PM 09/22/09 02:15 PM |
Posts: 1,203 uk | I will concur.. As a helm that was heavier than my crew sailing the nacF18 [which is a bitch downwind in a breeze], i went through a spell of doing the trapezing downwind - OK in a straight line, but the corners did get a bit messy! experiment abandoned. problem solved by purchase of infusion! Can you elaborate on the Nacra F18's downwind behaviour? I buried the bow a couple of times under spinnaker recently, in about 20 kts of wind, much to my surprize. I'm new to this boat, and I've not had this much difficulty with the other spin boats I've driven. Thanks! Dave I think that the F18 is one of the fastest hull shapes on flat water. we managed to win the UK inland champs 2 years on the trot! I would like to see an Infusion rig on one to see how it compares today. There was something about the lack of rocker or the finess of the bows that meant that every time the boat was at low speed in wind and waves [ bearing off, gybing or the frickin' back beam slamming a wave]the bows went down. I hate the feeling when you are sat a bit too far to windward before a start and you know that you have to bear right down and risk a dumb butt pitchpole as everyone else is sailing off. I got over this and the windward mark bear off by staying on the trapeze as long as i could [Risking the 'Peter Pan'], but coming out of a gybe or the back beam slamming - you just knew things were about to get lively and possibly messy! Ok so this may just be a quirk, but not boat is fast with 6' of bow trawling along under water.
1,303
guests, and 36
