| Re: Do it your self sail battens
[Re: Smiths_Cat]
#191947 09/25/09 03:52 AM 09/25/09 03:52 AM |
Posts: 4,451 West coast of Norway | Klaus, when you say "plane down" the wood, do you remove wood from the thick side or the narrow top? Removing from the top would be much easer of course  When you apply epoxy before glassing. Do you let the epoxy dry, clean and sand, or do you put on the glass before the first epoxy layer have hardened? Have you noticed any lasting twist/corkscrewing of the battens if you leave them in a rolled sail? What is the weight like compared to foam/glass battens? How lang have you sailed with wood/glass battens (durability)? Wood is not a uniform material so this will never lend itself to mass production with consistent results. However I would like to try this myself! I think it might work out very well! One small thing. If you tie your battens in the batten pocket it might be good to drill the hole oversize, fill with thickened epoxy and re-drill once hardened. Otherwise you might get cracking and water/moisture seeping in there. Thanks for sharing! | | | Re: Do it your self sail battens
[Re: DennisMe]
#191959 09/25/09 06:17 AM 09/25/09 06:17 AM |
Posts: 5,525 |  I'm not sure you'll get the control and accuracy you'll need. Try a block plane to rough out the desired shape- within 1mm for instance, then sand paper. Once you're comfortable with the material, I'm quessing a jig and belt sander will be the way to go.
Pete Pollard Blade 702
[Re: David Parker]
#191980 09/25/09 09:11 AM 09/25/09 09:11 AM |
Posts: 190 | I know that in the early days of the 18sq some of the guys used Shakespeare antenna cover for battens. I don't know who the supplier was though.
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: Rolf_Nilsen]
#192060 09/26/09 03:03 AM 09/26/09 03:03 AM |
Posts: 571 Hamburg | when you say "plane down" the wood, do you remove wood from the thick side or the narrow top? From the wide side. So it will always be 20mm wide but taper from 3 to 2mm for example. Thats essential, if you do it the other way, the batten will tend to break. When you apply epoxy before glassing. Do you let the epoxy dry, clean and sand, or do you put on the glass before the first epoxy layer have hardened? I let "dry" (wait a couple of hours), but do not sand. The idea is that the wood soaks the epoxy. If you do not do this first, you may have some dry glass, because the wood is like a sponge and takes the epoxy from the glass fibre. Also the wood is protected from moisture. Have you noticed any lasting twist/corkscrewing of the battens if you leave them in a rolled sail? No. If yes, you wood takes moisture, hence it wasn't fully encapsulated in resin. How lang have you sailed with wood/glass battens (durability)?
Three years on my Dart 18 (then I sold the boat) and now two years on the T. I sailed the Dart every week-end in the spring and summer for a couple of hours. The T is sailed less.  We sail in strong winds as well (25kts). One small thing. If you tie your battens in the batten pocket it might be good to drill the hole oversize, fill with thickened epoxy and re-drill once hardened. Otherwise you might get cracking and water/moisture seeping in there. I used a small brush to get epoxy in the hole. Less professional, but did the job. Or a notch on the end instead of a whole. Cheers, Klaus | | | Re: Do it your self sail battens
[Re: DennisMe]
#192092 09/26/09 09:18 PM 09/26/09 09:18 PM |
Posts: 2,844 42.904444 N; 88.008586 W | On my first Prindle, I took a set of fiberglass battens, that had no taper.
I then eyeballed it and used a belt sander to taper them.
Not exact, but it worked really well on my first Prindle 18 classic, with a dacron sail.
Cheap too.
F-18 Infusion #626- SOLD it!
367
guests, and 53
