| rules again #192644 10/05/09 12:12 PM 10/05/09 12:12 PM |
Posts: 5,525 | I'm sorry folks but I gotta get my sailing fix for the day. This question came up recently, names are witheld to protect the innocent.
Two boats on starboard tack. A F16 is finishing downwind (under spinnaker). Can he legally head up, preventing an A cat (or any other type) from finishing. By heading up he will sail faster and improve his portsmouth score, so he is not sailing above proper course.
I say this is one of those execptions. He must allow the other boat to finish.
Pete Pollard Blade 702
| | | Re: rules again
[Re: pgp]
#192647 10/05/09 12:18 PM 10/05/09 12:18 PM |
Posts: 548 MERRITTISLAND, FL | I'm sorry folks but I gotta get my sailing fix for the day. This question came up recently, names are witheld to protect the innocent.
I say this is one of those execptions. He must allow the other boat to finish. The finish is a mark of the course. If he has overlap you have to provide him room to round it. In the case where the line is closed and in the middle of the course, it is an obstruction and you have to provide room for the other boat to avoid it. | | | Re: rules again
[Re: Robi]
#192655 10/05/09 02:02 PM 10/05/09 02:02 PM |
Posts: 1,152 tampa, fl | Robi - For a long time I was of a similar opinion to you that a closed start finish line should not be viewed as an obstruction. I have had a discussion regarding that situation with several different judges and the concensus that I got was that it is an obstruction, and must be treated as such, if it is deemed to be closed by the SI's.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: rules again
[Re: pgp]
#192656 10/05/09 02:05 PM 10/05/09 02:05 PM |
Posts: 976 France | I say this is one of those execptions. He must allow the other boat to finish. Well, there is no reason he should. It's perfectly legal to pinch a boat away from the finish line. | | | Re: rules again
[Re: pepin]
#192658 10/05/09 02:07 PM 10/05/09 02:07 PM |
Posts: 5,590 Naples, FL | Is there any rule requiring you cross the finish line from a certain direction?
If you were pinched out of the finish line downwind, is there any reason you couldn't douse the spin, round up and cross the finish line close-hauled?
| | | Re: rules again
[Re: Robi]
#192659 10/05/09 02:12 PM 10/05/09 02:12 PM |
Posts: 548 MERRITTISLAND, FL | Matt, there is navigable water around the line and between the two marks that make up the imaginary start/finish line.
I was in this situation where we were both on starboard, heading to the weather mark. Leeward boat was maybe half a boat length in front. He came up and pinch me against a dingy tethered to an anchored yacht. I had no where to go and eased off my sails to fall off and prevent hitting any vessels.
I was told there was navigable waters around the yacht and dinghy so I had no rights for room.
I think this situation is similar... This falls under the room and oportunity. On approaching an obsticle that is long like an island or even a s/f line and they have to come up in time that you can tack away to take the water on the other side, it is still a normal course and no foul. If it is something short like a moored boat legaly they can wait much longer before heading you up because there is room. If they wait until the last minute and round you up so that you have sail away from your "normal" course then you have grounds to argue. If for no other reason than who ever did that is being an butt. | | | Re: rules again
[Re: pepin]
#192660 10/05/09 02:15 PM 10/05/09 02:15 PM |
Posts: 5,525 | I say this is one of those execptions. He must allow the other boat to finish. Well, there is no reason he should. It's perfectly legal to pinch a boat away from the finish line. But my understanding is that (if I'm doing the pinching)I may not finish. If you cross the line, you must give the other boat room at the mark. If you carry him above the mark, you must go above the mark yourself.
| | | Re: rules again
[Re: bobcat]
#192665 10/05/09 02:39 PM 10/05/09 02:39 PM |
Posts: 5,525 | I'm not certain, but this is how I think the situation developed. The open spin class and A class were started together but scored separately. The F16 was trying to finish as quickly as possible to obtain the best score in that class. The A cat, in this case was more like a moving obstacle rather than a competitor.
| | | Re: rules again
[Re: pgp]
#192667 10/05/09 03:14 PM 10/05/09 03:14 PM |
Posts: 3,528 Looking for a Job, I got credi... | How was the overlap gained, was the "proper" course for the F16 to sail higher angles as they would ger better VMG than the A; if there is an overlap at the zone, the leeward boat must give room to round the mark (or in this cae cross the line).
F16 - GBR 553 - SOLD I also talk sport here | | | Re: rules again
[Re: scooby_simon]
#192668 10/05/09 03:23 PM 10/05/09 03:23 PM |
Posts: 5,525 | Yes. This was a case where the wind was highly variable in both direction and speed. Proper course could have been anything!
| | | Re: rules again
[Re: Matt M]
#192671 10/05/09 03:32 PM 10/05/09 03:32 PM |
Posts: 2,718 St Petersburg FL | If for no other reason than who ever did that is being an butt. This is where good sportsmanship comes into play. Sometimes playing by the rules is OK, but pushing the rules can be dangerous as well. We were booking good speed I want to say 10+ kts upwind. | | | Re: rules again
[Re: Robi]
#192674 10/05/09 03:47 PM 10/05/09 03:47 PM |
Posts: 548 MERRITTISLAND, FL | If for no other reason than who ever did that is being an butt. This is where good sportsmanship comes into play. Sometimes playing by the rules is OK, but pushing the rules can be dangerous as well. We were booking good speed I want to say 10+ kts upwind. These things go both ways as to who to blame. If you were getting lee bowed and especially if a moored boat was comming up, tactically the best bet would have been to tack off. If you are on the lay line for the mark in all likelyhood you would have been sucked down and back behind the other boat anyway, so by ducking you ended up in the same position. | | | Re: rules again
[Re: Matt M]
#192680 10/05/09 04:07 PM 10/05/09 04:07 PM |
Posts: 1,152 tampa, fl | I was the other boat in this situation. We were not on the layline and the moored boat was in a position where we had to foot slightly to get under it. There was discussion on our boat as to whether to duck the boat or try to tack, but we could not tack with Robi on our hip. We did not take Robi up into the boat, and there was plenty of time for him to decide to tack away. Sportsmanship should not be questioned here.
[Re: ksurfer2]
#192686 10/05/09 04:35 PM 10/05/09 04:35 PM |
Posts: 3,906 Clermont, FL, USA | I was the other boat in this situation. We were not on the layline and the moored boat was in a position where we had to foot slightly to get under it. There was discussion on our boat as to whether to duck the boat or try to tack, but we could not tack with Robi on our hip. We did not take Robi up into the boat, and there was plenty of time for him to decide to tack away. Sportsmanship should not be questioned here. Dude, I thought I was the "butt" in question here, in fact I still think I am. Between rule 19.2.b and the definition of an obstruction you have me dead to rights. My bad buddy wasn't really trying to be an 'butt', at the time I had a different understanding of the rule. As for the danger bit... it was a moored boat surrounded by navigable water, 10kts is not light speed. Now, the question is... Could I have called for room to tack? assuming the course change I had to make was "substantial" enough to pass below the anchored boat.
| | | Re: rules again
[Re: David Ingram]
#192688 10/05/09 05:02 PM 10/05/09 05:02 PM |
Posts: 1,152 tampa, fl | Dave, you're off the hook on this one. The incident in question took place at GYC a month or so ago between Robi and I.
2,475
guests, and 285
