| What failed that caused you to demast? #193020 10/09/09 09:22 AM 10/09/09 09:22 AM | andrewscott
| andrewscott
Unregistered | I just read about someones bridal tang breaking off... wow.. thats hard to predict.
Got me thinking... maybe we could write up a list of reasons why people demast as a guide of items to inspect more often. Of course this wont prevent failures in hard to see areas (like a stress crack in a bow tang) but it may help others.
I demasted 2 weeks ago with a beautiful blond on the wire. The cause... my steel ring on top of my furler blew out. I had noticed it had elongated, but failed to replace this $3.00 part.. luckily no other damage happened and a nice power boater towed me about 5 miles to shore... | | | Re: What failed that caused you to demast?
[Re: ]
#193025 10/09/09 09:42 AM 10/09/09 09:42 AM |
Posts: 3,293 Long Beach, California | I lost a shroud - it parted just inside the fitting at the base. It was clear that the aircraft fitting had retained some moisture there and even though the boat was rinsed after each regatta, there was corrosion going on where I couldn't easily see it. Mast came down in slo-mo on the way out the inlet at the Clearwater Sailing Center with a rushing incoming tide. I though I was hot snot for getting under the bridge in one tack without missing a step... kicked a field goal on the drifting boat back through the bridge and caught a reluctant fishing boat for the short tow back. Missed the whole regatta. My standing rigging was about three years old at the time.
[Re: John Williams]
#193028 10/09/09 09:45 AM 10/09/09 09:45 AM |
Posts: 5,525 | Old stuff. Put EVERYTHING on a two year replacement schedule.
Pete Pollard Blade 702
[Re: pgp]
#193032 10/09/09 09:57 AM 10/09/09 09:57 AM |
Posts: 321 Albuquerque NM | We (Hobie fleet 48) have had 2 demastings on H18s this past sailing season. Both were when the shroud anchor pin bolt snapped. These boats are sailed maybe 2 to 3 times a month from Memorial Day into late October always in fresh water.
[b] Sail Like you have a Pair
[Re: brucat]
#193053 10/09/09 11:42 AM 10/09/09 11:42 AM | andrewscott
| andrewscott
Unregistered | Seriously Andrew? You need us to help you compile a list? I thought of this more as a general discussion to help others, and newer sailors... not really a list for me but i did hope to learn a thing or 2 perhaps | | | Re: What failed that caused you to demast?
[Re: ]
#193056 10/09/09 11:51 AM 10/09/09 11:51 AM |
Posts: 5,590 Naples, FL | The hole that the shrouds attach to on the top of the mast stretched out almost to failure (saw a crack at the bottom). Didn't lose the mast, but could have it the weather was bad.
I noticed it at disassembly after retiring from Macho Man. We retired because our upper rudder pintle broke outside the inlet for the Clearwater Sailing Center (in the middle of an Opti race course, too). Turned out this part wasn't welded on both sides, and was prone to failure (looked like a clean, sudden break)
So, I guess the rudder sacrificed itself to save the mast?
[Re: ]
#193057 10/09/09 11:52 AM 10/09/09 11:52 AM |
Posts: 129 Austin, TX | Andrew, That was me you were talking about. We didn't dismast...  As a matter of fact, the mast is still up. I've got to get out and unstep it this afternoon.
Bo Kersey Corsair 31-1D 276 | | | Re: What failed that caused you to demast?
[Re: BoK]
#193060 10/09/09 11:57 AM 10/09/09 11:57 AM |
Posts: 1,203 uk | Some boats shackle the spinny block to the shoud base replacing the clevis pin with the shackle. Repeated use of the spinny sheet seems to slowly undo the shackle over time.
Common in Dragoons [and older Pacifics apparently]
[Re: waterbug_wpb]
#193061 10/09/09 11:58 AM 10/09/09 11:58 AM | andrewscott
| andrewscott
Unregistered | I noticed it at disassembly after retiring from Macho Man. We retired because our upper rudder pintle broke outside the inlet for the Clearwater Sailing Center (in the middle of an Opti race course, too). Those opti's have no business being out in the gulf and in the clearwater / sand key pass... they take up the entire pass with 30 kids, and that pass can get insane waves and tides in different directions. 2 weeks ago the opt's stopped all traffic for 15 minutes in crazy tides while i was there. This past Mini Machoman i crewed for Catman. we were trapped with a spin out and the opti chase boats cut us off accross our bow and bullhored us to get out of their race. We were not in their race and when we yelled "WE are in a race" they said BS!!! | | | Re: What failed that caused you to demast?
[Re: ]
#193064 10/09/09 12:02 PM 10/09/09 12:02 PM |
Posts: 5,590 Naples, FL | we were trapped with a spin out and the opti chase boats cut us off accross our bow and bullhored us to get out of their race. We were not in their race and when we yelled "WE are in a race" they said BS!!!
I did about 5 macho man races when I owned my N20. I think 4 of those races ended up going through an Opti race course right there at the inlet. For the most part, they left us alone. Once the PRO boat drove up on us, but didn't give us a hard time because we ripped through one side of the course while the boats were on the other side... Personally, I'm glad to see boats out there racing, and will gladly duck them if I think I'm going to be a problem on their course. Mainly, though, I'm happy to show off multi-speed for those guys, who I hope will eventually become multi-sailors...
[Re: ]
#193070 10/09/09 12:11 PM 10/09/09 12:11 PM |
Posts: 921 Alachua, FL | This past Mini Machoman i crewed for Catman. we were trapped with a spin out and the opti chase boats cut us off accross our bow and bullhored us to get out of their race. We were not in their race and when we yelled "WE are in a race" they said BS!!!
Same thing happened to us. They were really pricks about it. Their boats were at the other end of their course and we went across one corner of their area. Barbie told them to F-OFF which I think they did.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: What failed that caused you to demast?
[Re: Mugrace72]
#193075 10/09/09 01:02 PM 10/09/09 01:02 PM |
Posts: 3,969 | Good point, I understand Andrew. All I really meant to say is, everything in the "system" is vulnerable. And, after reading some of the responses, there can be surprises, so this is a great thread. As for the Optis... It's not the 30 Optis that you have to worry about, or even the 4-5 RC boats. It's the 20 coach/parent boats... Of course, with all those power boats available, surely someone offered to tow you in?  As someone who runs a lot of kid events, including Optis, I'm very surprised they wouldn't be taking them under tow through a narrow pass, especially with heavy current. I can also tell you that we tend to be very protective of our racing circles, and you'd be amazed at what morons will do to a race course. "Look at all the cute boats..." Mike | | | Re: What failed that caused you to demast?
[Re: brucat]
#193079 10/09/09 01:18 PM 10/09/09 01:18 PM |
Posts: 1,187 38.912, -95.37 | What failed that caused you to demast? my wallet & brain  ego and testosterone won out.
[Re: Mugrace72]
#193088 10/09/09 02:53 PM 10/09/09 02:53 PM |
Posts: 5,582 “an island in the Pacifi... | Broken shackle that was part of a Harken three sheeve block for an Aussie system.
Enlarged the hole in the block and used a Schaffer stamped steel shackle. Lasted ten years. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: What failed that caused you to demast?
[Re: ]
#193124 10/09/09 11:59 PM 10/09/09 11:59 PM |
Posts: 493 Minnesota | What is the correct term for losing the mast?
I learned the term as "de-mast", but when I read an old sailing book years later, they used the term "dis-mast".
1 registered members (basket.case),
483
guests, and 25
