TMS-20 / The Man Shed Update #193280
10/12/09 09:29 PM
10/12/09 09:29 PM
Palm Beach County
TheManShed Offline OP
Palm Beach County
Well I'm back at it sort of it’s been 6 weeks since I had my shoulder redone and I’m starting to get back around. It still hurts and I can’t sleep that well yet but it’s getting better. Still in PT doing stretching soon I'll be ready to switch to strength building. Then back to sailing, that will be nice!
I finished Mark's A-Cat mast and he has been out with it and it stayed together. I don't think he will have a problem with the repair area. It's nice to have my table back again.
I cleaned the shop and put the ½ hull of the TMS-20 on the table. I shaped the outside of the hull and now I’m bogging it out. It is easy to shape with bog on it as the foam strips and glue sand at different rates. I’m just doing a little at a time at this point. It helps stretch my shoulder but I do not want to push it. Hopefully in another few weeks I can man the sander a bit more.
Later.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193298
10/13/09 08:13 AM
10/13/09 08:13 AM
andrewscott
andrewscott
welcome back! glad you are healing well!
Re: TMS-20 / The Man Shed Update [Re: ] #193311
10/13/09 09:05 AM
10/13/09 09:05 AM
Palm Beach County
Palm Beach County
Thanks Andrew!
Now if I can just adjust the sleep thing. I go a few days with just a couple hours until I zombie out.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193468
10/14/09 02:49 PM
10/14/09 02:49 PM
pgp Offline
pgp  Offline
Hi Mike! You've probably answered this before, but what kind of foam are you using? I ask because I need to replace the deck on my Tiki.
The Tiki was home built (not by me) and is generally well made. However, the original marine ply deck rotted away long ago and I wanted to replace it with a non-wood material.
Pete Pollard
Blade 702
Re: TMS-20 / The Man Shed Update [Re: pgp] #193529
10/15/09 12:22 AM
10/15/09 12:22 AM
Palm Beach County
Palm Beach County
Pete,
Divinycell 3/8" Plain H-60 on the main hull and H-80 on the ama's. Here is a good link for it: http://www.merrittsupply.com/Divinycell-C720.aspx
If you don't buy from them at least you can see what product line the foam comes in. I use west system with 407 for the bog. Just use regular wood working tools, saws, ect...
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193530
10/15/09 12:25 AM
10/15/09 12:25 AM
Palm Beach County
Palm Beach County
I was interviewed by Joe at http://smalltrimarans.com/blog/ and he gave me a very nice write-up on my TMS-20 project. Look for the story
Building a Sleek 20-Foot Trimaran in “The Man Shed”
Good Luck!
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193553
10/15/09 08:26 AM
10/15/09 08:26 AM
pgp Offline
pgp  Offline
Thanks Mike. What's your best guess as to comparable strength? If I'm replacing 1/2" ply will 1/2" divinycell sandwich be equal strength?
Pete Pollard
Blade 702
Re: TMS-20 / The Man Shed Update [Re: pgp] #193651
10/15/09 06:09 PM
10/15/09 06:09 PM
Palm Beach County
Palm Beach County
Pete,
Basically the strength is from your lay-up. There is a formula - when the skins and foam are added together the thicker the foam the stronger and stiffer the laminate as compared to a straight laminate. Some say you cannot do better then wood. Foam cost more but it is lighter and does not rot. Do you have a picture of your project perhaps a before is it a Wharram Tiki? I found a builders / Wharram website http://www.wharram.eu/cgi-bin/yabb2/YaBB.pl
There are things to plan for with foam such as masts, fittings, hardware, Crossbeams, ect...
From what I've seen most of the Tiki boat are built on frames and bulkheads so foam should not be a problem. One other thought is Balsa coring it makes a stronger and stiffer deck but it is subject to rot.
To answer your question yes I'd go with the 1/2 foam as your core thickness would be the same.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193663
10/15/09 09:25 PM
10/15/09 09:25 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Go to this site and look on page 18 for an illustrated explanation of how the core thickness effects stiffness.
http://www.marinecomposites.com/PDF_Files/G_Composite_Materials.pdf
Re: TMS-20 / The Man Shed Update [Re: TheManShed] #193678
10/16/09 06:41 AM
10/16/09 06:41 AM
pgp Offline
pgp  Offline
Mike: The deck and rudders need replacement, the rest of the boat is sound.
Seeker: Thanks for the link.
Pete Pollard
Blade 702
0 registered members (), 448 guests, and 34 spiders.
