multipurpose righting pole #193619
10/15/09 02:37 PM
10/15/09 02:37 PM
Petten Netherlands
N
northsea junkie Offline OP
N
Petten Netherlands
AFTER building my north-sea version the Prindle 15 cat (see else in the home building forum list), I discovered that I could not lift the cat anymore at sea when I was capsized. This was caused by the mast weight (I use a Prindle 18 mast) and the lenght of the beams (now 2.50 meter).
So, something had to be invented. I made a epoxy laminated pole round a foam hart with on each end a fork-like extension. See http://www.catsailor.com/gallery/displayimage.php?album=163&pos=3.
The fork will stand and hold just in the corner from the beam and the hull while the other end will be hang on the uphaul cord. See http://www.catsailor.com/gallery/displayimage.php?album=163&pos=1
What is more important that I have something to grab for after the righting, in order to prevent a turn over to the other side (rolling over)
Last but not least it can also be used as the pole for hanging behind my car. See http://www.catsailor.com/gallery/displayimage.php?album=163&pos=2
ronald
RAIDER-15 (homebuilt)
Re: multipurpose righting pole [Re: northsea junkie] #193670
10/16/09 02:38 AM
10/16/09 02:38 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Thanks for the pics. Have you tried to right with it yet? I would have thought you have the pole too low with not much leveredge and will be in the water before the cat is up. Do you stand on it? The pole normally hinges in the middle and has a stop knot to hold it up high so that you can use your weight before you float in the water.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: multipurpose righting pole [Re: JeffS] #193677
10/16/09 06:35 AM
10/16/09 06:35 AM
Petten Netherlands
N
N
Petten Netherlands
thanks for your comment. Yes I'm familiar with the normal pole constructions. But I was looking for something more simple and rigid and very important at sea, something quick. That is why I also made the "forks"" at both ends of the pole.
I can work my way up to the end of the pole if all my weight is needed.And again because the fork is loosely tied up to the hull/beam, I have something to grasp for (there is no dolphin striker!)
I forgot to mention that it can also be used to raise the mast in a bridle construction.
ronald
Re: multipurpose righting pole [Re: northsea junkie] #195062
10/31/09 12:30 PM
10/31/09 12:30 PM
Petten Netherlands
N
N
Petten Netherlands
To be complete: here is a picture of the pole in mastraising mode:
http://www.catsailor.com/gallery/displayimage.php?pos=-1198
Afterwards it seems so logical to have only one leverage pole for every leverage task to be done on my cat.
ronald
0 registered members (), 2,830 guests, and 456 spiders.
