| Re: Alter Cup Updates from water
[Re: PTP]
#194291 10/23/09 08:34 AM 10/23/09 08:34 AM |
Posts: 6,049 Sebring, Florida. | I think I'll go put some tape on my spreader tips today, keep them from slipping upwards! Ouch!!
Blade F16 #777
[Re: Timbo]
#194293 10/23/09 08:46 AM 10/23/09 08:46 AM | andrewscott
| andrewscott
Unregistered | is "slipping" common or even possible without some impact?
i had one spreader slip down (on my TheMightyHobie18) after a capsize (or demasting, or lowering the mast on the beach) and was able to smack it back into the right spot. but it needed a good amount of force. | | | Re: Alter Cup Updates from water
[Re: ]
#194295 10/23/09 08:49 AM 10/23/09 08:49 AM |
Posts: 6,049 Sebring, Florida. | I don't think it's common but it might have been hit by a flying body part on an earlier capsize. Either way, I'm taping mine today!
Blade F16 #777
[Re: Timbo]
#194301 10/23/09 08:55 AM 10/23/09 08:55 AM |
Posts: 2,921 Michigan | can someone post the pic of the spreaders being out of whack? it can have phil's gooberness over it, I don't care.
[Re: PTP]
#194306 10/23/09 09:12 AM 10/23/09 09:12 AM |
Posts: 6,049 Sebring, Florida. | That's what I put on two years ago, no problems since, but I sail mostly in fresh water.
I think the salt water might be an issue with the original Ronstan plastic blocks, salt and sand eating into it and causing problems? Or is there just too much room between the sheeve and the wheel and the halyard gets in there?
Blade F16 #777
[Re: ]
#194308 10/23/09 09:17 AM 10/23/09 09:17 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | is "slipping" common or even possible without some impact? Was the boat whose spreader slipped the same boat that had to be laid over on its side to fix the spin block? Could the spreader have been displace during that tip-over? The spin block failure happened when the skinny halyard jammed between the sheave and the housing. I don't think the block "blew up". | | | Re: Alter Cup Updates from water
[Re: Brett Goodall]
#194311 10/23/09 10:02 AM 10/23/09 10:02 AM |
Posts: 807 Hillsborough, NC USA | Button knot would be more reliable, but the dyneema is so slippery we decided to use the ball... a plain knot might be the way to go. There are plenty of knots with a good enough nip to hold in dyneema. As a class, lanyard knots might retain their shape under load better than button knots, but I'm partial to the form of a 2-strand 8-part button. That's what I put in my soft shackles. Regards, Eric | | | Re: Alter Cup Updates from water
[Re: ThunderMuffin]
#194317 10/23/09 10:40 AM 10/23/09 10:40 AM |
Posts: 4,451 West coast of Norway | When I chartered my boat to Mischa for the 2007 T500, he put the tiniest little harken bullet block as the spin turning block on the mast. Pic, or do you know which model? | | |
386
guests, and 451
