Sports Cam #192995
10/09/09 06:19 AM
10/09/09 06:19 AM
waynemarlow Offline OP
OK here's a sort of tricky one, I want to buy a small sports cam suitable for filming my many failed exploits as a cat sailor, thats the easy part as there are loads of sports cams availible. Now the tricky part, to keep " her indoors" on side I also need it for two other applications, both require an external trigger that will be operate the cam for as long as the trigger is operated.
Can anyone recommend a particular cam ?
Re: Sports Cam [Re: waynemarlow] #193066
10/09/09 12:07 PM
10/09/09 12:07 PM
Contact Brian at Adventureonline.tv
He's got all the cool toys, and even designs a few. I'm sure he'd give you the low-down on the best fit for your needs..
Re: Sports Cam [Re: waterbug_wpb] #194424
10/24/09 07:17 PM
10/24/09 07:17 PM
BrianK Offline
BrianK  Offline
Im selling 4 slightly used GoPro's as a kit:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140354901687
Re: Sports Cam [Re: BrianK] #194433
10/25/09 04:31 AM
10/25/09 04:31 AM
Ljubljana, Slovenia
mayhem Offline
mayhem  Offline
Ljubljana, Slovenia
The goPro helmet Cam the the right choice. Most people use a big memory card and have it take a picture every X seconds and do not worry about an external trigger.
Re: Sports Cam [Re: mayhem] #194438
10/25/09 07:08 AM
10/25/09 07:08 AM
japan
erice Offline
erice  Offline
japan
what about a $200 waterproof pentax w60 screwed onto a bent bit of tin that's screwed on to the front of an old bicycle helmet?
that can work as a reasonable helmet cam
put it in a small box surrounded by microcell foam with holes cut for straps to it can go on booms, beams and masts
that can work as as a remote cam
and once you pull it off the helmet or out of the box it's a rugged family digicam that can be used in the pool or at the beach
olympus make some very tough waterproof digicams for video but
the waterproof pentax optio series, w20, w30, w60, w80 can take interval photos, from once every 10sec (up to whatever) until the card fills up or the battery runs out
http://www.camrig.com/kitecam.php#whichCamera
which is why they are popular with kitecams
8gb cards don't get to fill up
or they can take 30min videos with a delayed start, say 15minutes, so you can get out to your favorite sailing spot
but i usually just start recording before i get on the boat
after 30minutes you can reach up, start the camera again and then do another 30minutes
the quality of the w60 video at 640 pixels and 30frames per sec. is as good as pretty much anything else
made these cat sailing videos on vimeo with it
http://vimeo.com/user1877838/videos
and the 1st 3 of these on your tube
http://www.youtube.com/user/eric3810101#p/u
haven't posted the link to the virtual weta trimaran video here before as i only made it a couple of days ago
if you've got a good connection and computer with lots of memory try the HD version in full screen
the video direct from the camera is far smoother than seen on youtube. vimeo better in that respect. (vimeo, "cool cat on a lake" was shot at 1280pix 15fps and seems smoother than than the weta videos shot at 30fps
presumably the online host takes the ax to the frame rate to save memory???
http://www.youtube.com/user/eric3810101#p/u/0/u-kFg4cncnA
next season i hope to get some videos from the top of the nacras mast and from the prod on the weta
if you have an lcd hd wide tv you mght want to pony up for the new w80 as it can do 1280pixels at 30fps
http://catalog.ebay.com/Pentax-Optio-W80-12-1-Megapixel-/74841813
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Sports Cam [Re: erice] #194441
10/25/09 07:46 AM
10/25/09 07:46 AM
BrianK Offline
BrianK  Offline
Re: Sports Cam [Re: BrianK] #194952
10/30/09 01:54 AM
10/30/09 01:54 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Any more cool toys Brian.... I got the ones off E-bay, thanks.... wink
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
0 registered members (), 269 guests, and 85 spiders.
Posts267,056
