help! Adive on centerboard systems #194738
10/28/09 03:53 AM
10/28/09 03:53 AM
Matt_Stone Offline OP
hey peoples,
i have a weird problem with the centerboards floating up, can i please get some ideas on some systems on keeping them down?
At the moment i have the trap elastic going over the top but i rather something better but without putting on too many deck hardware
Thanks matt
Re: help! Adive on centerboard systems [Re: Matt_Stone] #194739
10/28/09 03:58 AM
10/28/09 03:58 AM
Scarecrow
Scarecrow
glue some carpet in the top of the case.
Re: help! Adive on centerboard systems [Re: ] #194740
10/28/09 04:04 AM
10/28/09 04:04 AM
i have tried that and i have put carpet just inside the case but the boards are too well fitted, i got 2mm carpet but it was way too tight to get in or out,
ill try again tho as i thought of another way
thanks for replying
Re: help! Adive on centerboard systems [Re: Matt_Stone] #194741
10/28/09 04:34 AM
10/28/09 04:34 AM
MitchB Offline
MitchB  Offline
Hey Matt
Mylar Sailmakers tape! will stick really well and you can just add layers until the thickness is perfect! Easy to remove as well!
Mitch
Stingray #579
GLYCish
Re: help! Adive on centerboard systems [Re: MitchB] #194744
10/28/09 05:29 AM
10/28/09 05:29 AM
sweet thanks never thought of that, ill give a try, still open for more options
thanks matt
Re: help! Adive on centerboard systems [Re: Matt_Stone] #194880
10/29/09 09:51 AM
10/29/09 09:51 AM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
load them full of lead!!! that will stop them floating
the tape has always worked for me, but i use 90 mile an hour tape ( plumbers duct tape)
its cheaper than sailmakers mylar tape.
if the carpet too thick, we used some 1 inch webbing strap and glued that around the top and the bottomof the centre case .you should be able to find plenty of different thicknesses.
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: help! Adive on centerboard systems [Re: Brian P] #194947
10/29/09 08:51 PM
10/29/09 08:51 PM
sweet thanks ill give all a try
Re: help! Adive on centerboard systems [Re: Matt_Stone] #195193
11/03/09 02:54 AM
11/03/09 02:54 AM
Peter_Foulsum Offline
Matt,
Try glueing carpet in the longitudinal grooves below the deck line. This will be better than what you currently have and may work properly. cool Glueing carpet above the grooves would definitely have been a problem. frown
Peter
Mosquito 1814
Macka Mozzie
0 registered members (), 274 guests, and 53 spiders.
