What is it? #195151
11/02/09 02:48 PM
11/02/09 02:48 PM
Cairns FNQ
engineer Offline OP
engineer  Offline OP
Cairns FNQ
G'day everyone,
Does any one recognise this hull shape?
Thanks
Nacra 430 Rocket
Re: What is it? [Re: engineer] #195471
11/05/09 04:28 PM
11/05/09 04:28 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
Can you attach the photo so that it can be enlarged. I am having trouble with the transom. Looking at it I think it is an older Auscat, but again I cannot clearly see the transom.
Tom Siders
A-Cat USA-79
Tornado US775
Re: What is it? [Re: windswept] #195508
11/06/09 05:00 AM
11/06/09 05:00 AM
Cairns FNQ
engineer Offline OP
engineer  Offline OP
Cairns FNQ
Thanks for you help Tom, it needs alot of Work, and we don't race over the wet season. I thought as a project over the wet, and then try the "A" class over next season with an old dunger to see if it's for me????
Nacra 430 Rocket
Re: What is it? [Re: engineer] #195512
11/06/09 07:41 AM
11/06/09 07:41 AM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
Save your money Engineer. The $800 could be put to better use. This boat is between 35 and 40 years old and bears no relationship to anything Boyer/Goodall produced. The canoe sterns and 5308 section mast give it away as a relic from the 70's. Even if you could get it sailing it would give you no clue as to the true beauty of a modern A Class.
Only sail a modern A if you can afford to buy one because otherwise you'll spend the rest of your life wanting one!!!
John Dowling
AUS9
Re: What is it? [Re: ACE11] #195567
11/06/09 10:23 PM
11/06/09 10:23 PM
Cairns FNQ
engineer Offline OP
engineer  Offline OP
Cairns FNQ
Thanks John,
I thought as much was the case, Like all old worn out, clapped out timber boats, too much trouble, not enough gained.
Chocko
Nacra 430 Rocket
Re: What is it? [Re: engineer] #195570
11/07/09 01:36 AM
11/07/09 01:36 AM
Cairns FNQ
engineer Offline OP
engineer  Offline OP
Cairns FNQ
How is starting in a boat like a mark IV?
I've noticed one on the Aus. A cat site
Thanks
Chocko
Nacra 430 Rocket
Re: What is it? [Re: engineer] #195602
11/07/09 03:29 PM
11/07/09 03:29 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
I own a Boyer MKIV and love it. Depending upon the year of manufacter they range between $3,000-9,000 in the states. Mine is a 2002 with canted hulls. The boat is great off the wind. The olny issue that I have with it is the amount of freeboard in the bows. It makes it more difficult to tack than my Tornado. I wanted to see the transom because I ran into an eighties era Auscat that tapered down to 2 inches. The rudder heads were rounded in the front and fit into the transom. Midship it bowed out and the bows wear also narrow.
Tom Siders
A-Cat USA-79
Tornado US775
Re: What is it? [Re: windswept] #195678
11/09/09 06:44 AM
11/09/09 06:44 AM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
A Boyer MkIV is a fine boat and would give you a pretty close understanding of the modern performance and they are long lasting. I have a canted MkIV as well as a Geltek Flyer II. It is obviously faster but not by too much, and a lot more expensive. Prices in Aus around 6k to 9k depending on condition and with such things as trailer, beach rollers etc. Mine is for sale if you are interested - pm me for details and location.
John Dowling
0 registered members (), 522 guests, and 41 spiders.
