| Re: Inspection Ports
[Re: Southern sailor]
#196214 11/13/09 08:07 PM 11/13/09 08:07 PM |
Posts: 5,582 “an island in the Pacifi... | It seems like the first place the hulls go soft is just in front of the forward pylons. Putting ports there gives you easily accessible storage and you can, if needed, inject resin into the foam sandwich to strengthen the decks.
JMHO US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Inspection Ports
[Re: hobie1616]
#196271 11/14/09 08:56 AM 11/14/09 08:56 AM |
Posts: 164 fort Myers, FL | The reason the delam happens at that spot is because that part of the hull (in front of the pilon) is subject to the largest forces anywhere in the hull, so I would be hesitant to do anything there that would weaken the structure (and putting in ports would do exactly that).
Arie Hobie 16 111812
[Re: arievd]
#196403 11/15/09 05:50 PM 11/15/09 05:50 PM |
Posts: 1,884 Detroit, MI | The reason the delam happens at that spot is because that part of the hull (in front of the pilon) is subject to the largest forces anywhere in the hull, so I would be hesitant to do anything there that would weaken the structure (and putting in ports would do exactly that). +1 If the only reason you are installing ports is ventilation, then put them between the pylons. | | | Re: Inspection Ports
[Re: mbounds]
#201897 02/02/10 05:12 PM 02/02/10 05:12 PM |
Posts: 5 Chicagoland | I have some delam. going on in front of the front pylon on my 14'. Is there a brand or model port that is more rigid than the usual plastic ones that would be a better choice to install in that area. Assuming that I also repair the delam.
H-14T, Suzuki DRZ400, Yamaha TW200, lots of climbing gear.
2,543
guests, and 519
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 Yesterday at 10:10 AM | | | |
