Inspection Ports #196002
11/11/09 05:03 PM
11/11/09 05:03 PM
Argentina
Southern sailor Offline OP
Argentina
I'm considering to put 4" inspection ports on my H14T for better ventilation of the hulls and for storage.
In order not to weaken the hulls, where should they go: foredeck; between the pylons or on the rear deck?
Thanx in advance for the advise.
Re: Inspection Ports [Re: Southern sailor] #196214
11/13/09 08:07 PM
11/13/09 08:07 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
It seems like the first place the hulls go soft is just in front of the forward pylons. Putting ports there gives you easily accessible storage and you can, if needed, inject resin into the foam sandwich to strengthen the decks.
JMHO
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Inspection Ports [Re: hobie1616] #196271
11/14/09 08:56 AM
11/14/09 08:56 AM
fort Myers, FL
arievd Offline
arievd  Offline
fort Myers, FL
The reason the delam happens at that spot is because that part of the hull (in front of the pilon) is subject to the largest forces anywhere in the hull, so I would be hesitant to do anything there that would weaken the structure (and putting in ports would do exactly that).
Arie
Hobie 16 111812
Re: Inspection Ports [Re: arievd] #196403
11/15/09 05:50 PM
11/15/09 05:50 PM
+1
If the only reason you are installing ports is ventilation, then put them between the pylons.
Re: Inspection Ports [Re: mbounds] #201897
02/02/10 05:12 PM
02/02/10 05:12 PM
Chicagoland
Joel H. Offline
Joel H.  Offline
Chicagoland
I have some delam. going on in front of the front pylon on my 14'. Is there a brand or model port that is more rigid than the usual plastic ones that would be a better choice to install in that area. Assuming that I also repair the delam.
H-14T, Suzuki DRZ400, Yamaha TW200, lots of climbing gear.
0 registered members (), 2,368 guests, and 417 spiders.
Yesterday at 10:10 AM
