Cat rudders #19656
05/16/03 10:13 PM
05/16/03 10:13 PM
Ontario, Canada
av8or Offline OP
av8or  Offline OP
Ontario, Canada
are the rudders on a cat supposed to be perfectly straight or should they be slightly unaligned?
Just wondering how this could affect drag as the boat begins to heel to leeward
Thanks
Re: Cat rudders [Re: av8or] #19657
05/17/03 09:49 PM
05/17/03 09:49 PM
Andrew Offline
Andrew  Offline
Most of the recommendations are for somewhere between 3/8" and 3/16" of toe-in. This compensates for slack in the rudder system, as well as letting the windward rudder run at a little less angle to the water than the leeward one. Something about a surface-piercing foil vs. a non-surface-piercing one.
sail fast
0 registered members (), 367 guests, and 19 spiders.
