| Re: Sliding Spi Pole
[Re: Berthos]
#19779 05/21/03 05:10 AM 05/21/03 05:10 AM |
With every rule there are borderline issues. That is why we have rule 1.1.1 in combination with rules 2.3.1, (2.3.2), 2.4.1, 2.6.1 and 2.6.2
The intend of rule 1.7.1 is mainly to limit the amount of tuning during racing and to keep the F16 setup simple and inexpensive. The F16 class is not intended to become a very technical class with all kind of baby stays or even hydrolics to finetune the rig to every point of sail individually. This will make the class to difficult for entry sailors which will be a significant portion of our fleet.
Now the intend of a sliding pole is not to finetune the rig but to gently improve on the design and or handling of the spinnaker equipment. Such a technic can just as easily be used by a novice sailor as an very experienced one.
So I wouldn't worry so much about this issue. I would worry more on how to implement such a setup.
Please note that this is not an official class interpretation of the issue as that requires a certain procedure to be followed. This is just an explaination on the workings of the rules and to illustrate that the class is not some "letter of the rule ! no matter what ! class" Where not sailing one-design lasers here.
Of course the issue may well change when the sliding mechanisme DOESN'T put the tip of the pole in the same locations each time when the setup is extended.
A good rule of thumb is that when the end situation is the same as the one achieved by other systems on other boats that than the issue is not that serious and stands a good change of being allowed by the class after due process.
300
guests, and 56
