Ideal weight #198741
12/09/09 09:19 PM
12/09/09 09:19 PM
NQLD, Australia
Learning to Fly... Offline OP
NQLD, Australia
Whats the ideal helm weight for a cat rigged Mozzie with kite?
Assuming boat was a near new class minimum foam core boat.
Re: Ideal weight [Re: Learning to Fly...] #198751
12/09/09 11:45 PM
12/09/09 11:45 PM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
OK GUYS TIME TO OWN UP!!!! WHO WEIGHS WHAT???
TIM?
GARY?
DARRYN?
THE BIG FELLA HERE WEIGHS 97KG!!!!! BUT I AINT THAT FAST IN UNDER 15 KNOTS!!!
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: Ideal weight [Re: Brian P] #198753
12/10/09 01:19 AM
12/10/09 01:19 AM
Matt_Stone Offline
Matt_Stone  Offline
well i can say that im probably the lightest at 66kg, was 71 till i got sick on a weekend and all my hard work at gym went crashing down, so im back to 66,
im still on the light side, but my ideal weight is to be 70kg, thats what im aiming for
Matt UNKO
Re: Ideal weight [Re: Learning to Fly...] #198759
12/10/09 04:31 AM
12/10/09 04:31 AM
twicebitten
twicebitten
Don't know there is a ideal weight, last time I sailed Mossies, about 4 years ago I was 95kg+ and did ok, now I am 73kg- and doing ok. It's just a matter of adjusting sail settings, the Mossies flexible mast helps.
Re: Ideal weight [Re: Learning to Fly...] #198760
12/10/09 04:56 AM
12/10/09 04:56 AM
NQLD, Australia
NQLD, Australia
I'm saving for a new boat (cat rigged 4.9 with kite). Taipan or mozzie? Seems to me I'm on the weight border at 85kg, more likely suited to a Taipan.
Gary, from what I understand you lost weight and now are too light for the F16?
Re: Ideal weight [Re: Learning to Fly...] #198797
12/10/09 04:51 PM
12/10/09 04:51 PM
Thorneside | QLD | AUS
furr_ball Offline
furr_ball  Offline
Hey there,
Drew here Jon. Would be real cool if you went the mossie path !
I weigh in at 82kg and do OK in mixed fleets with a 20 year old boat.
Not sure against other mossies, will know after Jan Nats. I have a strategy for that though with a light weight crew.....
The mossie is lighter and IMO more versatile than the Taipan. Nothing wrong with a Taipan - they are just heavier and yes a bigger sail plan. If you want a kite why not simply go F16.
The current mossies well sailed give all other classes a hard time and quite often come out on top, just look through the regatta results and posts on forums.
From Canberra you would be able to get down to Vic or SA for a lot of regattas as well with plenty of mossies.
Drew........Furr_ball........Mosquito 1635
Re: Ideal weight [Re: ] #198803
12/11/09 12:46 AM
12/11/09 12:46 AM
Bendigo, Victoria, Australia
colmc Offline
colmc  Offline
Gary when you say you did ok at 95 kg is that the year you won the national titles on Peter N's boat? cool
Col
"Now What?"
Mosquito 1810
Re: Ideal weight [Re: Learning to Fly...] #198808
12/11/09 04:27 AM
12/11/09 04:27 AM
twicebitten
twicebitten
85kg is no worries for a Mossie Cat rigged,National Champs have been that weight or more for last 15 years I think and with spinnaker I went ok at 95kg as I said.
Low 70's kg is definetly a bit light for cat rigged F16, I feel more comfortable on the Mossie now.
If I was making the choice between Taipan and Mossie, firstly I would consider how much I like being over powered, as Taipan has more power flys a hull earlier, but is more quickly over powered, not a problem if you like high winds and pushing the limits on your previous boat, also look at conditions you would sail it in most of the time.
Second choice would be comparing Mossie against Taipan in value for what you are getting, how old, good are the hulls, rig, sails etc. How competitive would the boat be in it's class, I think that would be my final decision maker they are both good cats with individual pros and cons. Also if you want to race in class or happy with handicap, others of the class sailing localy would influence decision.
Re: Ideal weight [Re: colmc] #198809
12/11/09 04:33 AM
12/11/09 04:33 AM
twicebitten
twicebitten
I was mainly thinking with spinnaker, but I was around 95kg+ when I won nationals, in fact most of the time I sailed Mossies, including the early days sloop rigged, I was around 95kg blush .
Re: Ideal weight [Re: ] #198812
12/11/09 06:23 AM
12/11/09 06:23 AM
NQLD, Australia
NQLD, Australia
Thanks for all the replies. It will be a while till I have enough dosh to commit to another boat, so I will keep doing research.
Drew, next time I'm up in Cleveland I am keen to continue the challenge. I'm now running a Spi on the 4.5 one up and slowly getting the hang of it.
0 registered members (), 20,731 guests, and 647 spiders.
18 hours ago
