Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Tradewinds NOR.., Should be a great one [Re: ] #199856
01/03/10 10:49 PM
01/03/10 10:49 PM
So Rick, what's the overnight low in Key Largo tonight??
It's supposed to get down to 27 here in Sebring but we are not surrounded by the warm water like you are. Tampa news said the Gulf water is down to 61, what's the water temp in the Keys right now?
I left NH to get away from this crap! Well, at least I don't have to shovel the driveway...yet.
Guess I'd better make sure there's no water in my hulls though, it might freeze up and split them.
Here's Key Largo's weather, be sure you scroll down to the bottom.
http://www.weather.com/weather/local/USFL0243?lswe=Key%20Largo%20FL&from=searchbox_localwx
If you are too lazy to copy that, tonight's low in Key Largo is supposed to be about 40.
Re: Tradewinds NOR.., Should be a great one [Re: Jake] #199857
01/03/10 10:50 PM
01/03/10 10:50 PM
Originally Posted by Jake
I'm in upper SC freezing my ears off in 25 degrees this morning getting the double stack ready...you guys can go get lost.
Time for the New England and MI guys to tell me to get lost now.
You can get lost now.
I'm not as nearly bad as Karl, but it was 5 above this AM. High today was about 15. Good day to find air leaks around the house (just hold you hand next to an outlet, etc. to feel for a draft). I'm on the warpath to cut down my heating bills (December gas bill was ~$350).
The spousal unit was not too happy when I got aggressive with the programmable thermostats. laugh
Re: Tradewinds NOR.., Should be a great one [Re: Timbo] #199858
01/03/10 11:19 PM
01/03/10 11:19 PM
andrewscott
andrewscott
Noah has the water at 58.5( http://tidesonline.nos.noaa.gov/plotcomp.shtml?station_info=8726724+Clearwater+Beach,+FL#) at the clearwater pier
I sailed on dec 31.. it was 61* water... it only felt cold until my feet turned blue .. actually it was fine with the right gear.
Re: Tradewinds NOR.., Should be a great one [Re: ] #199875
01/04/10 11:20 AM
01/04/10 11:20 AM
RickWhite Offline OP
Played tennis this morning in temps around the mid-60s. It was pretty miserable. Tomorrow is supposed to get colder, so may opt out of tennis.
Supposed to stay that way until about Friday when it will get over 70 again.
Bet is will affect the water temps a bit, but should be better than Minn. I couldn't believe the temps were in the -29 area all over the northern plains, and that was not wind chill.
Enjoying this global warming?
Rick
Rick White
www.onlinemarinestore.com
Re: Tradewinds NOR.., Should be a great one [Re: RickWhite] #199877
01/04/10 11:25 AM
01/04/10 11:25 AM
pgp Offline
pgp  Offline
Pot stirrer.
Pete Pollard
Blade 702
Re: Tradewinds NOR.., Should be a great one [Re: pgp] #199879
01/04/10 11:33 AM
01/04/10 11:33 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Originally Posted by pgp
Pot stirrer.
+1, what Pete said!
F18 USA 242
http://www.solarwind.solar
Re: Tradewinds NOR.., Should be a great one [Re: David Ingram] #199880
01/04/10 11:39 AM
01/04/10 11:39 AM
pgp Offline
pgp  Offline
Happy New Year, your Dingness.
Pete Pollard
Blade 702
Re: Tradewinds NOR.., Should be a great one [Re: pgp] #199917
01/05/10 10:31 AM
01/05/10 10:31 AM
The real question is "will it be back in the 80's by next week?" My blood's too thin for this ...
Re: Tradewinds NOR.., Should be a great one [Re: waterbug_wpb] #199927
01/05/10 11:46 AM
01/05/10 11:46 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
...packing my spray gear. Was hoping to only have to pack the banana hammock and the sunscreen.
Re: Tradewinds NOR.., Should be a great one [Re: ThunderMuffin] #199930
01/05/10 12:16 PM
01/05/10 12:16 PM
Clermont, FL, USA
Clermont, FL, USA
eeeeuuuuwwwww... Oh wait second, I'm on Facebook... Nice!
F18 USA 242
Re: Tradewinds NOR.., Should be a great one [Re: ThunderMuffin] #199931
01/05/10 12:16 PM
01/05/10 12:16 PM
andrewscott
andrewscott
Thank god for cold weather! smile
Re: Tradewinds NOR.., Should be a great one [Re: mbounds] #199933
01/05/10 12:30 PM
01/05/10 12:30 PM
brucat Offline
brucat  Offline
Get yourself a wood-burning stove or at least a fireplace insert. I have the latter, and unless it gets below 10 degrees outside, the furnace never comes on when I have the wood going. Even when it is that cold, the furnace runs much less often than it does without the wood going.
Also helps that I get free wood from the in-laws (just have to cut, haul and split it), but it's good exercise (and we all know I could use some more of that to help my boatspeed)...
Re: Tradewinds NOR.., Should be a great one [Re: brucat] #199947
01/05/10 03:07 PM
01/05/10 03:07 PM
Bern, Switzerland
MartinS Offline
MartinS  Offline
Bern, Switzerland
well, well guys you have problems - we don't even think about sailing cry
The actual temperature at the lake of Thune in Switzerland is -3 degree celsius which is about 27 F. Water temperature is 6 degree celsius (43F). Look below how it looks like. Do you wana sail in front of snowy mountains?
Check out the live cam, but think about the time shift, we are 6 hours ahead, on http://www.swiss-sail.ch/webcam00.htm
Re: Tradewinds NOR.., Should be a great one [Re: brucat] #199953
01/05/10 04:10 PM
01/05/10 04:10 PM
Not going to work in this house (4,125 sq. ft, including the semi-finished basement). We have two furnaces - one in the basement and one in the attic. Both are +90 efficiency. Basement furnace takes the brunt of the load, since the warm air rises up to the second floor via the "grand entrance" foyer (14 ft ceiling). Yesterday, it ran 10 hrs 50 min when it was ~21°F outside.
Re: Tradewinds NOR.., Should be a great one [Re: mbounds] #199954
01/05/10 04:38 PM
01/05/10 04:38 PM
andrewscott
andrewscott
must be tough with so little space.. your closets must be overflowing smile
Re: Tradewinds NOR.., Should be a great one [Re: ] #199960
01/05/10 05:12 PM
01/05/10 05:12 PM
You gotta have some space to move around when you can't go outside for any length of time in December through February. grin
Re: Tradewinds NOR.., Should be a great one [Re: mbounds] #199962
01/05/10 05:32 PM
01/05/10 05:32 PM
Portland, Maine
Portland, Maine
How do you walk the dog when its that cold outside?
I'm about to walk Tybee and I've got 5 layers on and its 34'F !
Re: Tradewinds NOR.., Should be a great one [Re: ThunderMuffin] #199966
01/05/10 05:58 PM
01/05/10 05:58 PM
That's assuming you haven't already eaten the dog.
Re: Tradewinds NOR.., Should be a great one [Re: Karl_Brogger] #199967
01/05/10 05:59 PM
01/05/10 05:59 PM
Portland, Maine
Portland, Maine
Poor dog frown
Re: Tradewinds NOR.., Should be a great one [Re: ThunderMuffin] #199985
01/05/10 10:57 PM
01/05/10 10:57 PM
you crack open the door, shooo the dog out with your foot, and wait 20 seconds for the "WOOF! MOTHER F'ER!" and crack the door back open to let them back in. You don't need a leash and you don't need to walk them...they're not going to stray far! I lived in Cleveland for 10 years.
0 registered members (), 652 guests, and 965 spiders.
