| Re: Tradewinds NOR.., Should be a great one
[Re: ]
#199856 01/03/10 10:49 PM 01/03/10 10:49 PM |
Posts: 6,049 Sebring, Florida. | So Rick, what's the overnight low in Key Largo tonight?? It's supposed to get down to 27 here in Sebring but we are not surrounded by the warm water like you are. Tampa news said the Gulf water is down to 61, what's the water temp in the Keys right now? I left NH to get away from this crap! Well, at least I don't have to shovel the driveway...yet. Guess I'd better make sure there's no water in my hulls though, it might freeze up and split them. Here's Key Largo's weather, be sure you scroll down to the bottom. http://www.weather.com/weather/local/USFL0243?lswe=Key%20Largo%20FL&from=searchbox_localwx If you are too lazy to copy that, tonight's low in Key Largo is supposed to be about 40.
Blade F16 #777
#199857 01/03/10 10:50 PM 01/03/10 10:50 PM |
Posts: 1,884 Detroit, MI | I'm in upper SC freezing my ears off in 25 degrees this morning getting the double stack ready...you guys can go get lost.
Time for the New England and MI guys to tell me to get lost now. You can get lost now. I'm not as nearly bad as Karl, but it was 5 above this AM. High today was about 15. Good day to find air leaks around the house (just hold you hand next to an outlet, etc. to feel for a draft). I'm on the warpath to cut down my heating bills (December gas bill was ~$350). The spousal unit was not too happy when I got aggressive with the programmable thermostats. | | | Re: Tradewinds NOR.., Should be a great one
[Re: ]
#199875 01/04/10 11:20 AM 01/04/10 11:20 AM |
Joined: Mar 2002 Posts: 3,355 Key Largo, FL and Put-in-Bay, ... RickWhite OP
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Played tennis this morning in temps around the mid-60s. It was pretty miserable. Tomorrow is supposed to get colder, so may opt out of tennis. Supposed to stay that way until about Friday when it will get over 70 again. Bet is will affect the water temps a bit, but should be better than Minn. I couldn't believe the temps were in the -29 area all over the northern plains, and that was not wind chill.
Enjoying this global warming?
Rick | | | Re: Tradewinds NOR.., Should be a great one
[Re: pgp]
#199879 01/04/10 11:33 AM 01/04/10 11:33 AM |
Posts: 3,906 Clermont, FL, USA |
[Re: David Ingram]
#199880 01/04/10 11:39 AM 01/04/10 11:39 AM |
Posts: 5,525 | Happy New Year, your Dingness.
Pete Pollard Blade 702
[Re: pgp]
#199917 01/05/10 10:31 AM 01/05/10 10:31 AM |
Posts: 5,590 Naples, FL | The real question is "will it be back in the 80's by next week?" My blood's too thin for this ...
[Re: ThunderMuffin]
#199930 01/05/10 12:16 PM 01/05/10 12:16 PM |
Posts: 3,906 Clermont, FL, USA | ...packing my spray gear. Was hoping to only have to pack the banana hammock and the sunscreen. eeeeuuuuwwwww... Oh wait second, I'm on Facebook... Nice!
[Re: ThunderMuffin]
#199931 01/05/10 12:16 PM 01/05/10 12:16 PM | andrewscott
| andrewscott
Unregistered | ...packing my spray gear. Was hoping to only have to pack the banana hammock and the sunscreen. Thank god for cold weather!  | | | Re: Tradewinds NOR.., Should be a great one
[Re: mbounds]
#199933 01/05/10 12:30 PM 01/05/10 12:30 PM |
Posts: 3,969 | I'm on the warpath to cut down my heating bills (December gas bill was ~$350).
Get yourself a wood-burning stove or at least a fireplace insert. I have the latter, and unless it gets below 10 degrees outside, the furnace never comes on when I have the wood going. Even when it is that cold, the furnace runs much less often than it does without the wood going. Also helps that I get free wood from the in-laws (just have to cut, haul and split it), but it's good exercise (and we all know I could use some more of that to help my boatspeed)... Mike | | | Re: Tradewinds NOR.., Should be a great one
[Re: brucat]
#199953 01/05/10 04:10 PM 01/05/10 04:10 PM |
Posts: 1,884 Detroit, MI | I'm on the warpath to cut down my heating bills (December gas bill was ~$350).
Get yourself a wood-burning stove or at least a fireplace insert. I have the latter, and unless it gets below 10 degrees outside, the furnace never comes on when I have the wood going. Even when it is that cold, the furnace runs much less often than it does without the wood going. Also helps that I get free wood from the in-laws (just have to cut, haul and split it), but it's good exercise (and we all know I could use some more of that to help my boatspeed)... Mike Not going to work in this house (4,125 sq. ft, including the semi-finished basement). We have two furnaces - one in the basement and one in the attic. Both are +90 efficiency. Basement furnace takes the brunt of the load, since the warm air rises up to the second floor via the "grand entrance" foyer (14 ft ceiling). Yesterday, it ran 10 hrs 50 min when it was ~21°F outside. | | | Re: Tradewinds NOR.., Should be a great one
[Re: mbounds]
#199954 01/05/10 04:38 PM 01/05/10 04:38 PM | andrewscott
| andrewscott
Unregistered | Not going to work in this house (4,125 sq. ft, including the semi-finished basement)
must be tough with so little space.. your closets must be overflowing  | | | Re: Tradewinds NOR.., Should be a great one
[Re: ThunderMuffin]
#199966 01/05/10 05:58 PM 01/05/10 05:58 PM |
Posts: 4,119 Northfield Mn | How do you walk the dog when its that cold outside?
I'm about to walk Tybee and I've got 5 layers on and its 34'F ! That's assuming you haven't already eaten the dog. | | | Re: Tradewinds NOR.., Should be a great one
[Re: ThunderMuffin]
#199985 01/05/10 10:57 PM 01/05/10 10:57 PM |
Posts: 12,310 South Carolina | you crack open the door, shooo the dog out with your foot, and wait 20 seconds for the "WOOF! MOTHER F'ER!" and crack the door back open to let them back in. You don't need a leash and you don't need to walk them...they're not going to stray far! I lived in Cleveland for 10 years.
Jake Kohl | | |
362
guests, and 592
