Painting Gaphics/images on Sails #19918
05/26/03 05:33 PM
05/26/03 05:33 PM
Westport, Ma. U.S.A.
Brian_Mc Offline OP
Brian_Mc  Offline OP
I understand that some of the commercial graphics we see on racer's sails, are painted on. Can anyone tell me what kind of paint to use? Thanks, Brian
Let Jake Kohl do it ... [Re: Brian_Mc] #19919
05/26/03 07:47 PM
05/26/03 07:47 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
high quality, good work in Vinyl(?)
You can find him on this site.
David Mosley
www.seacats.org
Re: Painting Gaphics/images on Sails [Re: Brian_Mc] #19920
05/26/03 09:15 PM
05/26/03 09:15 PM
Most graphics on mylar main and jib sails are high quality vinyl. Spinnakers and dacron sails are usually painted on (although success can be had with vinyl on relatively fresh dacron sails). I'm not sure what kind of airbrush paint they use.
Re: Painting Gaphics/images on Sails [Re: Jake] #19921
05/26/03 10:55 PM
05/26/03 10:55 PM
Brian_Mc Offline OP
Brian_Mc  Offline OP
Thanks guys, My sails are Dacron, and I have an airbrush from some other projects, so if I can find out what kind of paint to use, I think I'll give it a try. Brian
Re: Painting Gaphics/images on Sails [Re: Jake] #19922
05/27/03 11:22 AM
05/27/03 11:22 AM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
Jake,
Can you give me a ballpark idea of the cost (per sq ft)?
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: Painting Gaphics/images on Sails [Re: Kevin Rose] #19923
05/27/03 12:51 PM
05/27/03 12:51 PM
It depends a lot on the capabilities of the equipment being used but in my case I can cut in one piece that would fit in a 13.5" X 96" rectangle. If any parts lay outside of that rectangle It would have to be cut it in overlapping panels. Prices can be all over the place depending on complexity of the design and multiple colors. A one color graphic, up to 13.5" tall, and of medium complexity, would run roughly $5 to $7 per foot. If you can fit two graphics in that 13.5" height, the price wouldn't change much.
The following graphic (which is on my boat) would probably be about $40 per graphic (high complexity with the frazzled text, three colors, and the fade). My friend in that picture owns a highly respected sign shop in Cleveland, OH and with their 3D routing system is carving up a 3D 'Willy' (the dolphin on my bow)for a ground ornament or to stick somewhere on the RV - pretty cool stuff. It's amazing how much technology goes into sign making today.
P.S. Always make sure you are getting the premium vinyl for boat applications. A lot of places will cut the corner and use a 5 year intermediate vinyl film. The difference is both the adhesive used and the thickness of the vinyl. A thicker vinyl has a better chance of catching on something and/or trapping water underneath. I always use an 8 or 9 year vinyl. It's a good deal more expensive but you can count on it to last.
Re: Painting Gaphics/images on Sails [Re: Jake] #19924
05/27/03 01:29 PM
05/27/03 01:29 PM
I highly recommend Jake. The graphics he cut for me were top notch... my only complaint is that he wouldn't drive the 3 hours up the road to put them on my boat for me
Re: Painting Gaphics/images on Sails [Re: Jake] #19925
05/27/03 09:24 PM
05/27/03 09:24 PM
K
Kevin Rose Offline
Kevin Rose  Offline
K
Jake,
Are the vinyl graphics for sails made from the same material used on hulls?
Re: Painting Gaphics/images on Sails [Re: Kevin Rose] #19926
05/27/03 11:10 PM
05/27/03 11:10 PM
sonicassassin Offline
Jake,
I doubt it. The vinyl being applied to the hulls would be quite a rigid type, the vinyl applied to the sails would be a more flexible type probaly more often used on PVC banners and such. This is so you can roll your sail up and the vinyl wont crack/delaminate.
If I wanted something on my sails i'd screenprint it on myself, or me or a mate would airbrush it on. I've had a look at my sail and its dacron, I have inks that would last as long as the sail would likely last.
Because of the nature of the abuse a sail gets (bashed by wind, salt water, rolled up after use) I'd imagine a vinyl label/graphic to last no longer than 2 years applied to a sail.
Though I did get some dacron with an adhesive backer from a sail-loft down the road to patch a couple of what looks like cigarette burns in my sail. I noticed that my sail # must be produced from the same stuff, and it has no signs of wear and tear.
And I imagine it is possible someone has a digital printer that can print onto this substrate (Dacron with adhesive backer) which can be applied to a sail that should last years!. I think my boat was made in 1983, I imagine the sail is original as well, so that sail # has been there 20 years using the adhesive backed Dacron.
Re: Painting Gaphics/images on Sails [Re: sonicassassin] #19927
05/28/03 07:01 AM
05/28/03 07:01 AM
I've got a set of x-Worrell sails (Key Sailing 1) that was probably from what? 1997 or 98? With the sailing the guy before me and that I've done I figure these sails have well over 2000 miles on them. I don't baby them either (because their shape is terrible). However, all the graphics on the mylar main and the dacron jib are still in fine shape. Since the jib advertises for another graphics company (other than mine!) I tried to remove it and it was such a pain in the butt that I left it. There's at least 5 years on these graphics and they're fine. Even my hull graphics (constructed of premium 9year outdoor vinyl) withstood my grinder/polisher and rubbing compound with no ill effects. The graphics were damaged when I got t-boned a couple of weeks ago by a H16 but he also took some gel-coat with him!
The vinyl used for both applications, hull or sail, should both be high quality (thinnest) vinyl. The rigidity and thickness of vinyl and respective durability and expense go hand in hand. On the sails you need the thinnest possible vinyl so it can accomodate the stitching and seams and the hulls need the thinnest possible so they will not trap water under a thick edge. Typically the higher quality vinyls with the highest quality adhesives are very, very thin (less than .05mm). Most banners, around here anyway, use cheaper thicker intermediate vinyl since the banner surface is very adhesive friendly and relatively smooth.
Re: Painting Gaphics/images on Sails [Re: MauganN20] #19928
05/28/03 04:14 PM
05/28/03 04:14 PM
you never asked me to! (and you never know - that sounds like a great excuse to go sailing)!
Re: Painting Gaphics/images on Sails [Re: Jake] #19929
05/28/03 04:46 PM
05/28/03 04:46 PM
Jake, how far is hartwell from you?
(I've got family I can stay with there)
Re: Painting Gaphics/images on Sails [Re: MauganN20] #19930
05/28/03 05:02 PM
05/28/03 05:02 PM
about 35 - 45 minutes straight down I85 to Western Carolina Sail Club (exit 14). I sail there recreationally when I get a chance. That's one of the biggest parts of the lake except for the damn where Spring Fever is held (and it's only 8 miles up the lake with no overhead obstructions to that area too)
Re: Painting Gaphics/images on Sails [Re: Brian_Mc] #19931
05/28/03 06:39 PM
05/28/03 06:39 PM
maui
jollyrodgers Offline
maui
Hello,
to get graphics on dacron you can use many types of paint or textile inks. Most waterbased paints will eventually fall off.
i think a spray can would work. i know flock adhesive would be very permanent.
you can also use insignia sticky back material. cut out and apply.
for the record, high performance vinyl is generally 2 mil thick. intermediate vinyl is generally 3.2 mil .
hope this helps
Re: Painting Gaphics/images on Sails [Re: jollyrodgers] #19932
05/28/03 10:15 PM
05/28/03 10:15 PM
2 mil is roughly .05mm
Re: Painting Gaphics/images on Sails [Re: Jake] #19933
05/28/03 11:39 PM
05/28/03 11:39 PM
Jake: I'm going to be at Lake Hartwell for a family reunion over the 4th of july weekend. I've told my family that my boat is definitely going to make the trip.
Re: Painting Gaphics/images on Sails [Re: Brian_Mc] #19934
05/29/03 03:19 AM
05/29/03 03:19 AM
Tornado_ALIVE Offline
I used premium vinal for the graphics on my sail and hulls... see attached photo.
No problem rolling the sail however might have doupts regarding it holding on a standard jib that may flog at times.... Self tacker, no problems.
Re: Painting Gaphics/images on Sails [Re: MauganN20] #19935
05/29/03 06:48 AM
05/29/03 06:48 AM
dang...not a good weekend - I'll be in Chattanooga, TN.
Re: Painting Gaphics/images on Sails [Re: Jake] #19936
05/29/03 08:07 AM
05/29/03 08:07 AM
that sucks.
How far are you from the coast then? I'm always going out there.
Re: Painting Gaphics/images on Sails [Re: MauganN20] #19937
05/29/03 09:16 AM
05/29/03 09:16 AM
It takes the Sailing Shack about 5 hours to rumble down the freeway to get to Myrtle Beach and about 4 to Charleston. NC coast is a lot farther.
0 registered members (), 20,053 guests, and 1,598 spiders.
Most Online22,490
Yesterday at 08:14 AM
