| CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant #199495 12/24/09 10:26 PM 12/24/09 10:26 PM |
Joined: Apr 2002 Posts: 805 Gainesville, FL 32607 USA dacarls OP
Posts: 805 Gainesville, FL 32607 USA | For those who manage to score some MMM sealant to de-leak your old cats: this urethane based glue contains isocyanates and gets ruined quite fast by air and water getting through the screw-on plastic cap.
Here is how to save it: cut a little disk of aluminized plastic seal from a fruit juice jar, gum packet, tire patch, etc. Be sure the patch JUST covers the sealant and the top of the tube opening, and carefully screw the top back on.
It will now last a LONG time- almost a year so far for last spring's tube. Previously I lost several $$$ tubes of this great stuff between uses, even after drilling out the hard stuff.
| | | Re: CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant
[Re: dacarls]
#199526 12/26/09 10:35 AM 12/26/09 10:35 AM |
Posts: 3,224 Roanoke Island ,N.C. | Good tip. I'll definitely give it a try.
[Re: dacarls]
#199681 12/30/09 12:48 AM 12/30/09 12:48 AM |
Posts: 493 Minnesota | Wouldn't regular aluminum foil folded over the tip,then screwing the cap on, work just as well?
[Re: Jeff Peterson]
#199729 12/30/09 09:05 PM 12/30/09 09:05 PM |
Posts: 805 Gainesville, FL 32607 USA | Folding = creases= no airtight seal. Cut a tiny circle to fit= airtight seal.
[Re: dacarls]
#199746 12/31/09 08:47 AM 12/31/09 08:47 AM |
Posts: 12,310 South Carolina | heck, I just poke a new pin hole in the body and squeeze it out there whenever I need to use a little.
Jake Kohl | | |
2,652
guests, and 166
