CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant #199495
12/24/09 10:26 PM
12/24/09 10:26 PM
Gainesville, FL 32607 USA
dacarls Offline OP
dacarls  Offline OP
For those who manage to score some MMM sealant to de-leak your old cats: this urethane based glue contains isocyanates and gets ruined quite fast by air and water getting through the screw-on plastic cap.
Here is how to save it: cut a little disk of aluminized plastic seal from a fruit juice jar, gum packet, tire patch, etc. Be sure the patch JUST covers the sealant and the top of the tube opening, and carefully screw the top back on.
It will now last a LONG time- almost a year so far for last spring's tube. Previously I lost several $$$ tubes of this great stuff between uses, even after drilling out the hard stuff.
Dacarls:
Re: CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant [Re: dacarls] #199526
12/26/09 10:35 AM
12/26/09 10:35 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Good tip.
I'll definitely give it a try.
Isak Dinesen
E. B. White
Re: CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant [Re: dacarls] #199681
12/30/09 12:48 AM
12/30/09 12:48 AM
Minnesota
Jeff Peterson Offline
Minnesota
Wouldn't regular aluminum foil folded over the tip,then screwing the cap on, work just as well?
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant [Re: Jeff Peterson] #199729
12/30/09 09:05 PM
12/30/09 09:05 PM
dacarls Offline OP
dacarls  Offline OP
Folding = creases= no airtight seal.
Cut a tiny circle to fit= airtight seal.
Dacarls:
Re: CHRISTMAS TIP- Saving your 3M 5200 and 4000 sealant [Re: dacarls] #199746
12/31/09 08:47 AM
12/31/09 08:47 AM
heck, I just poke a new pin hole in the body and squeeze it out there whenever I need to use a little.
