| Re: Hobie Mast Step issues
[Re: Oleg]
#199804 01/02/10 09:33 AM 01/02/10 09:33 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | With some patience and a extra hand you might try to use a bolt - screw to hold it in place. Put a wrench on a batten, a dab of contact cement on the nut washer to hold it on the wrench, slide it in the beam and good luck.
[Re: catman]
#199805 01/02/10 09:34 AM 01/02/10 09:34 AM |
Posts: 4,119 Northfield Mn | With some patience and a extra hand you might try to use a bolt - screw to hold it in place. Put a wrench on a batten, a dab of contact cement on the nut washer to hold it on the wrench, slide it in the beam and good luck. On a curved beam? | | | Re: Hobie Mast Step issues
[Re: Karl_Brogger]
#199807 01/02/10 10:05 AM 01/02/10 10:05 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Why not? I think the curve would hold the nut closer to the top of the beam. It's certainly worth the try. Probably only nedd a couple 1/4-20's to hold down the base as compared to all those rivets. I would something like tefgel to coat the bolts-beam holes and bolt it together. Use nylocks or locktite.
[Re: catman]
#199808 01/02/10 10:24 AM 01/02/10 10:24 AM |
Posts: 5,525 | Run a stiff wire through the hole(s)in the beam; slip the wire through the nut, bend the wire to hold the nut; pull the wire back until the nut is lined-up with the hole; "goo" the nut in place. When the "goo" sets, put the base in place, screw in the bolts. Maybe?
Oh, pull the wire out at some point.
Pete Pollard Blade 702
[Re: catman]
#199814 01/02/10 01:40 PM 01/02/10 01:40 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | You could have the holes welded as long as the welder doesn't stay on it too long. To get all the corroded alluminum out, drill each hole out a little larger and take it to a welder. I've done it on my H21SE, crossbeams and mast.
Lee
[Re: TeamChums]
#199816 01/02/10 05:07 PM 01/02/10 05:07 PM |
Posts: 7 | Where are you located? There are tons of good used crossbars available for very little money. I gave at least 3 or 4 away for free. I live northeast TN With some patience and a extra hand you might try to use a bolt - screw to hold it in place. Put a wrench on a batten, a dab of contact cement on the nut washer to hold it on the wrench, slide it in the beam and good luck. Have thought of that, maybe put the bolt inside the cross bar and the nut on top of the mast step, the curve should keep the bolt from spinning... I guess I would have to use some puddy or something and drill the mast step from underneath... You could have the holes welded as long as the welder doesn't stay on it too long. To get all the corroded aluminum out, drill each hole out a little larger and take it to a welder. I've done it on my H21SE, crossbeams and mast. That aluminum is 6061 T6 which good stuff and has been very heat treated... I don't have access to an annealing oven or the funds to operate one. Welding it would weaken it by 70% Thanks for the replies, this forum is great. | | | Re: Hobie Mast Step issues
[Re: jkkartz1]
#199837 01/03/10 01:17 PM 01/03/10 01:17 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | Depending on the year of the boat there is probably a few hardwood strips that were driven up inside of the crossbar. They will never come out, so getting a wrench in there is impossible. Even if they weren't getting a wrench up in there sounds like a real test of patience.
I would either get a used xbar, or go 1/4" rivets. Use stainless and have someone pull them with a real rivet gun, you'll probably never do it with a hand gun. I carefully mark the rivet holes so that I hit the existing holes exactly. Take your time, drill once measure 4 times.
Sail on!
j
[Re: Oleg]
#199839 01/03/10 02:37 PM 01/03/10 02:37 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | Welding it would weaken it by 70% Not entirely true, hence my comment about the welder staying on it too long. Changes on strength depend on heat, time and amount of weld depsosited, which contributes to your heat affected zone, not to mention the type of force being applied under working load. Not sure how you were able to come up with the calculations to indicate a 70% weakening. Alluminum can actually be heat treated without needing to be annealed, especially for this aplication. Good luck.
Lee
[Re: jkkartz1]
#199851 01/03/10 07:43 PM 01/03/10 07:43 PM |
Posts: 921 Alachua, FL | Or.
Get a larger piece of metal, rivit to the beam and then reset the mast base.
It should be pretty easy to get a piece of scrap mast extrusion and cut a scab that can be riveted over the whole swiss cheese area. You will probaly need to use a body hammer to adjust the shape for a tight and conforming fit on the curved beam (we are working on an H16 aren't we?). Once formed it can bet set in epoxy and riveted in the corners. The new mast base can then be mounted using the conventional procedure. Having said that, a used beam would seem to be the best and easiest solution.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Hobie Mast Step issues
[Re: jkkartz1]
#199872 01/04/10 10:34 AM 01/04/10 10:34 AM |
Posts: 5 St Augustine FL | Nutserts I used these on my Hobie 18. They come in aluminum and work great. Nutsert is bascially a rivet with threads. You can buy a package with the nutsert tool for about $25 at Northern tool or maybe your local hardware store.
Hobie 18 #15767
[Re: Jerry S]
#199898 01/04/10 06:43 PM 01/04/10 06:43 PM |
Posts: 4,119 Northfield Mn | Nutserts I used these on my Hobie 18. They come in aluminum and work great. Nutsert is bascially a rivet with threads. You can buy a package with the nutsert tool for about $25 at Northern tool or maybe your local hardware store. thats an awesome name! "Why'd she kick you?" "I don't know, but my nutsert."
463
guests, and 41
