Mast Rake #199961
01/05/10 05:16 PM
01/05/10 05:16 PM
Simon C Offline OP
Simon C  Offline OP
Hi All,
I've just done up a new mast and changed a few things in the process. What's a good starting place for mast rake for sailing Mark 1?.... an observation... the new section with everything on it is considerably lighter than the old with everything off it?
Cheers,
Simon
Simon
Taipan AUS341
Re: Mast Rake [Re: Simon C] #199971
01/05/10 06:35 PM
01/05/10 06:35 PM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
i think the standard is top of mast 6 inches back from front beam, if your having trouble tacking ( getting in to irons) stand it up a bit more. if your not, and your lacking up hill speed, lean it back a bit
hope this helps, other wise, ring gary maskiell??
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: Mast Rake [Re: Simon C] #199974
01/05/10 08:04 PM
01/05/10 08:04 PM
twicebitten
twicebitten
Originally Posted by Anopheles_11
Hi All,
Cheers,
Simon
Hi Simon,
yes current Victorian section was some 1.5kg lighter than the mast I got with 1760. More flexible though, so you may need to tighten diamonds and rotate more when trying to power up.
My idea on rake is keep raking mast back until weather helm causes you to pull on tiller when trying to power up in moderate winds and then stand it back up one hole. I think ideal is that when you feel a bit of weather helm and rudders drag when trying to pull away with wrinkles up luff of mainsail, you should be able to pull on down haul and weather helm will dissapear.
Re: Mast Rake [Re: ] #199977
01/05/10 10:06 PM
01/05/10 10:06 PM
Simon C Offline OP
Simon C  Offline OP
Thanks Gents.
Yes I noticed that the new section is rather more flexible than the old. More learning to do crazy
Cheers,
Simon
Simon
Taipan AUS341
0 registered members (), 437 guests, and 34 spiders.
