Boyer Mk4 #200901
01/21/10 12:37 AM
01/21/10 12:37 AM
zandercage Offline OP
Hi All
I'm looking at a boyer mk4 this weekend as was wondering if there was anything in particular i need to pay attention to?
Re: Boyer Mk4 [Re: zandercage] #200971
01/21/10 08:22 PM
01/21/10 08:22 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
you can email me at [email protected] Tom
Tom Siders
A-Cat USA-79
Tornado US775
Re: Boyer Mk4 [Re: windswept] #201374
01/27/10 03:44 AM
01/27/10 03:44 AM
Thanks Tim
Are you able to tell me how i can determine which year my hulls were constructed?
Re: Boyer Mk4 [Re: zandercage] #201378
01/27/10 05:49 AM
01/27/10 05:49 AM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
Working from memory here but I think the MkIV model run was from 1996 to 2000. The earlier boats were straight and from about 1998 they were canted 7 degrees. The US association should have a record of when the sail number was issued. The card glassed inside the hatch only had hull number not date I think.
John Dowling
Re: Boyer Mk4 [Re: ACE11] #201548
01/28/10 06:04 PM
01/28/10 06:04 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
It was run through 2001. Mine was canted. They are either double kevlar hulls or kevlar/carbon. mine is kevlar/carbon. Kevlar outer skin/carbon inner skin. I think it is foam core and not nomex, but cannot remember whether my waterat or Boyer had the nomex core, I think it was the Waterat. What year is your Boyer?
Tom Siders
A-Cat USA-79
Tornado US775
Re: Boyer Mk4 [Re: windswept] #201678
01/31/10 05:02 PM
01/31/10 05:02 PM
not sure of year but the hull number is 0060. Is there anywhere that we can find the year based of the hull number?
Re: Boyer Mk4 [Re: zandercage] #201681
01/31/10 08:28 PM
01/31/10 08:28 PM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
If you look in the other hull it should be 0059. Those hulls were built in 2000.
Contrary to my earlier post they went from straight to canted in June 1997.
Re: Boyer Mk4 [Re: zandercage] #225350
12/13/10 05:12 AM
12/13/10 05:12 AM
Can anyone tell me if the boyer mk4 has breather holes? if so where they are located?
Re: Boyer Mk4 [Re: zandercage] #225352
12/13/10 06:36 AM
12/13/10 06:36 AM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
Small hole drilled above or below the upper gudgeon.
Re: Boyer Mk4 [Re: ACE11] #225891
12/26/10 04:57 AM
12/26/10 04:57 AM
thanks ACE. I have decided to change the mast bean hinge and was just wondering how you remove the existing one? i can see one screw that will remove the front of it but am unsure how to remove the top circular piece.
Re: Boyer Mk4 [Re: zandercage] #226018
12/29/10 09:12 AM
12/29/10 09:12 AM
Brisvegas
ACE11 Offline
ACE11  Offline
Brisvegas
If it's original, the small cup on top of the hinge plate is screwed in to the striker post. It should just screw out to let you remove the hinge.
Re: Boyer Mk4 [Re: zandercage] #233228
06/04/11 08:38 PM
06/04/11 08:38 PM
Hi Guys
Can anyone provide me with some photos of your mast rotation setup? I have just replaced my tramp and now the configuration is not quite right.
0 registered members (), 4,353 guests, and 592 spiders.
1 hour ago
