| Vertglass or polish? #20088 05/31/03 08:21 PM 05/31/03 08:21 PM |
Joined: May 2003 Posts: 139 Daytona Beach FL TheoA OP
Posts: 139 Daytona Beach FL | 94 boat Viewed from side, there is a slight shine Chalky when surface viewed perpendicular looks good when wet!  I've read a little bit about a product called Vertglass I'm wondering if that is what is for me in this case to get a good finish on my hulls I did try using an ordinary automotive orbital buffer with some mothers wax cleaner, then polish, then wax. Made the finish a bit better, but it definatly doesn't shine the way I want it to. Any pointers or tips? Or will I just have to deal with the finish the way it is
94 N5.5SL
| | | Re: Vertglass or polish?
[Re: TheoA]
#20089 05/31/03 09:17 PM 05/31/03 09:17 PM |
Posts: 3,114 BANNED | | | | Re: Vertglass or polish?
[Re: MauganN20]
#20090 05/31/03 10:14 PM 05/31/03 10:14 PM |
Posts: 139 Daytona Beach FL | Repaint the entire boat  Have you used this product, any tips to go by. I'm not sure repainting the boat is something I want to do. Perhaps I have misconceptions about cost, but it seems pretty expensive to do the right way. Any other advice from anyone else?
94 N5.5SL
[Re: TheoA]
#20091 05/31/03 10:55 PM 05/31/03 10:55 PM |
Posts: 3,114 BANNED | I was just messing with you  I just repainted my whole boat, and the shine is amazing... its like showroom quality... however, you might not have the facilities to do it like I did. if your hulls are oxidizing, meaning when you run your finger over it, you get white powder on your finger, you need to use rubbing compound first. It goes on like a wax and it stops the oxidation. After the rubbing compound has done its thing, then you can go ahead and wax. Make sure before you do anything though, you use a strong de-waxing agent on the hull to cleanse it. | | | Re: Vertglass or polish?
[Re: MauganN20]
#20092 05/31/03 11:09 PM 05/31/03 11:09 PM |
Posts: 139 Daytona Beach FL |  ok... If I run my finger down the hull, I get nada. This of course after it's clean. It just doesn't have any shine to it. I'll try some of the dewaxing/buffing and then waxing stuff this week. I was/am a little hesitant to put any acrylic stuff on the boat. I think I'd rather repaint. If you don't mind me asking, what did you spend on painting? I have a freind in the auto paint biz who is good, perhaps I could do the prep and......
94 N5.5SL
[Re: TheoA]
#20093 06/01/03 08:01 AM 06/01/03 08:01 AM |
Posts: 3,114 BANNED | Well, when I repainted, I also had a lot of hull repair to do. I also split the cost of painting with the guy that helped me do it, as we painted his wooden skiff at the same time.
What you need is a good polish. Talk to the guys at your local boat supply store, they usually can tell you what has worked for them. If your hulls aren't oxidizing then theres no need to repaint them, plus, if you start now, and don't work on it but every weekend, you'll miss the whole sailing season (assuming you're in the US). | | | Re: Vertglass or polish?
[Re: TheoA]
#20094 06/02/03 10:15 AM 06/02/03 10:15 AM |
Posts: 833 St. Louis, MO, | McGuires has tons of polishes in all kinds of grits. Buy some of the not too heavy grit polish I can't remember the number. They have different numbers for different grit levels. Anyway use your buffer and McGuires and it will look like new again.
Mike Hill H20 #791
Mike Hill N20 #1005
[Re: sonicassassin]
#20097 06/03/03 08:57 AM 06/03/03 08:57 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | There is a "sailing season"? - I just go out when there is wind, LOL. Here in Vermont, the season is limited to times when the water is in a liquid state.  (Last Sunday, the air was a chilly 48 degrees at 4 pm. Even us lifelong Vermonters were feeling that it's time to get on with summer.)
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: sonicassassin]
#20099 06/03/03 08:46 PM 06/03/03 08:46 PM |
Posts: 397 Burlington, Vermont USA | Oh I see - I guess 6 - 18 inches of ice would put a bit of a damper on water-sports.
Some of the folks just make a seasonal switch to boats with blades rather than hulls
Kevin Rose
N6.0na #215
Burlington, Vermont
2,597
guests, and 532
