ROLLER FURLER on Hobie 18 #20246
06/04/03 04:00 PM
06/04/03 04:00 PM
rutlean Offline OP
rutlean  Offline OP
I am having trouble getting my roller furler connected right. Should the forestay also rotate as the jib is being rolled up, or does the forestay stay in the same position and the jib rolls up around it?
Thanks
Re: ROLLER FURLER on Hobie 18 [Re: rutlean] #20247
06/04/03 04:04 PM
06/04/03 04:04 PM
The forestay spins with the jib.
Re: ROLLER FURLER on Hobie 18 [Re: rutlean] #20248
06/04/03 05:19 PM
06/04/03 05:19 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Your question seems to indicate to me that you don't have the halyard, forestay and jib luff setup right. The furler rotates the forestay. If the jib luff is zippered over the forestay (don't forget the place the halyard line inside the zippered luff before you start hoisting the sail) and the tack is attached to the forestay adjuster plate on the furler, then the jib will roll up around the forestay as the latter is turned by the furler drum.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: ROLLER FURLER on Hobie 18 [Re: rutlean] #20249
06/04/03 05:26 PM
06/04/03 05:26 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
The forestay should be attached to a spindle at the top and the drum at the bottom, and rotate with them. A side note. The furler will work a lot better if you are running down wind as opposed to sheeted in hard to the wind. Tension on the forestay makes it a lot harder to rotate as opposed to being down wind with no significant load on the forestay.
Don
ARC22 #2226
Don Cook ARC22 #2226 ADRENALIN
Re: ROLLER FURLER on Hobie 18 [Re: rutlean] #20250
06/05/03 02:14 AM
06/05/03 02:14 AM
DHO Offline
DHO  Offline
Here's a couple of scans from the TheMightyHobie18 Assembly manual.
David Ho
TheMightyHobie18 1067
Re: ROLLER FURLER on Hobie 18 [Re: DHO] #20251
06/05/03 02:23 AM
06/05/03 02:23 AM
DHO Offline
DHO  Offline
Looks like it didn't work. I'll try it again.
Re: ROLLER FURLER on Hobie 18 [Re: DHO] #20252
06/05/03 02:44 AM
06/05/03 02:44 AM
DHO Offline
DHO  Offline
Ok. Here goes Take 3
Re: ROLLER FURLER on Hobie 18 [Re: rutlean] #20253
06/05/03 08:59 AM
06/05/03 08:59 AM
Neb
flounder Offline
flounder  Offline
Neb
I concur, the forestay, jib halyard and jib should all rotate as one unit. The furler drum should be under the bridle connection.
If you are starting fresh I recommend pulling all the line out of the drum, setting your jib and rolling it around the forestay by hand. This will let you set how much of the sail you want to furl acuratly.
0 registered members (), 566 guests, and 588 spiders.
