Hobie 18 jib halyard #20263
06/04/03 05:34 PM
06/04/03 05:34 PM
Bridge City, Texas
pirate_tx Offline OP
Bridge City, Texas
My jib halyard broke due to a kink in the wire. I was thinking about replacing the wire with some good small rope. Anyone see anything wrong with that? Anyone have a idea of what size rope would work best?
Doug Ramsey
#4383
hobie 18
Re: Hobie 18 jib halyard [Re: pirate_tx] #20264
06/04/03 05:50 PM
06/04/03 05:50 PM
catman Offline
catman  Offline
I think unless your using something like Vectran your going to have trouble keeping the jib luff properly tensioned.
Just go to West Marine or your local supply store and make one up yourself. It's easy and cheap.
Re: Hobie 18 jib halyard [Re: catman] #20265
06/04/03 06:05 PM
06/04/03 06:05 PM
just make sure you tighten up the swaging machine before you do it
Re: Hobie 18 jib halyard [Re: pirate_tx] #20266
06/05/03 12:18 PM
06/05/03 12:18 PM
Neb
flounder Offline
flounder  Offline
Neb
It will end up costing you more using vectran/dyneem/spectra based ropes. I would just make a new wire.
Re: Hobie 18 jib halyard [Re: flounder] #20267
06/05/03 12:32 PM
06/05/03 12:32 PM
Oh yeah, don't be like me and forget to put the main block on the wire before you swage the ends
Re: Hobie 18 jib halyard [Re: pirate_tx] #20268
06/05/03 04:21 PM
06/05/03 04:21 PM
U
unlvrebel Offline
unlvrebel  Offline
U
Just spend the couple of dollars for the pre-made stainless ones. No need to screw around and get cheap on rigging gear.
Re: Hobie 18 jib halyard [Re: unlvrebel] #20269
06/06/03 02:41 PM
06/06/03 02:41 PM
MN
tbosch Offline
tbosch  Offline
MN
I agree that it's not cost effective to manufacture your own. I think line would work though. The jib halyard is never supposed to take load off the forestay. It just keep the wrinkles out of the leading edge.
I bought a spare to have in my parts bag. Not too expensive and I figure I'll need it eventually anyway.
I have one complaint with this product. The swaged (sp?) on shackle pin is not a "keeper" pin. The swaged loop is small enough that you can't get the shackle out to replace it. You have to buy a new setup or cut the wire, replace the shackle and reswage. I know it sounds petty but this drives me nuts! It's such a small pin. One day it's going to slip while standing on the bow with cold wet fingers...
Todd
TheMightyHobie18, MN
0 registered members (), 2,782 guests, and 286 spiders.
