diamond wire turnbuckle hard to turn #205621
03/14/10 06:17 PM
03/14/10 06:17 PM
tedb Offline OP
tedb  Offline OP
d wire turnbuckle on my hobie 20 is very hard to turn. Almost broke the screwdriver I used to turn it with. I can only get about a half turn on it. It is at the low end of the rcomended setting. And yes I have spayed mcclube all on it
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205622
03/14/10 07:04 PM
03/14/10 07:04 PM
It's probably time to replace it - but you may want to try a penetrating lubricant like WD40...McLube will not get into the threads (the solvent evaporates quickly leaving a dry lubricant film on whatever was sprayed).
Re: diamond wire turnbuckle hard to turn [Re: Jake] #205623
03/14/10 07:24 PM
03/14/10 07:24 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
PB Blaster for the win. You can find it in the automotive stores around the brake cleaner with a yeller top.
I've let seized spark plugs sit in PB Blaster overnight and then pulled them out with finger-torque the next day. Its amazing stuff.
Re: diamond wire turnbuckle hard to turn [Re: ThunderMuffin] #205633
03/14/10 10:34 PM
03/14/10 10:34 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
PB Blaster or Kroil. Both excellent. The Kroil wicks in the best.
Isak Dinesen
E. B. White
Re: diamond wire turnbuckle hard to turn [Re: Team_Cat_Fever] #205635
03/15/10 12:19 AM
03/15/10 12:19 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Did ya try some 'Harsh Sailor Words' on it ??
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205661
03/15/10 08:05 AM
03/15/10 08:05 AM
catman Offline
catman  Offline
You might want to take it apart and run a Tap and Die over the threads. Stainless is very susceptible to galling so trying to force it will only make it worse. Then use something like Tefgel to coat the threads.
Re: diamond wire turnbuckle hard to turn [Re: catman] #205718
03/15/10 06:32 PM
03/15/10 06:32 PM
tedb Offline OP
tedb  Offline OP
I remember now sailing along in decent breeze, trapped out and hearing a PING sound from the mast somewhere. Kind of scary because I had no clue what it was. Thinking back now I'm wondering if the thing stripped itself somehow. Does this ever happen to you guys?
And yes I swore up and down at the thing
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205723
03/15/10 07:44 PM
03/15/10 07:44 PM
Portland, Maine
Portland, Maine
You might have to bring some heat into the situation. Thermal expansion and contraction is a great way to loosen up seized bolts.
Just... don't get the flame too close to the mast smile
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205742
03/15/10 10:43 PM
03/15/10 10:43 PM
Dunedin Causeway, FL
David Parker Offline
Originally Posted by tedb
I remember now sailing along in decent breeze, trapped out and hearing a PING sound from somewhere. Kind of scary because I had no clue what it was.
I've heard that noise from both my knee and my shoulder at various times!
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205749
03/16/10 02:34 AM
03/16/10 02:34 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I heard the same sound on my 5.8 when I was in plenty of wind and waves, about 30 mins later the sidestay broke inside the suage resulting in a written off boat and a rescue.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: diamond wire turnbuckle hard to turn [Re: tedb] #205767
03/16/10 07:12 AM
03/16/10 07:12 AM
I'm not familiar with the Hobie 20 turnbuckle...but no - I've never heard of such a thing. Check your rigging for a popped wire strand.
Re: diamond wire turnbuckle hard to turn [Re: Jake] #205770
03/16/10 08:03 AM
03/16/10 08:03 AM
TeamChums Offline
TeamChums  Offline
I heard a "pop" while sailing the Fernandina leg of the Tybee last year and we couldnt figure out what it was. By the time we landed, we forgot all about it. The next day we finished in Tybee and began to de rig and I found a broken chain plate on my Starboard shroud. My blood ran cold. Nothing more than sheer luck kept that thing together for the next 100 miles.
Lee
Re: diamond wire turnbuckle hard to turn [Re: TeamChums] #205775
03/16/10 08:45 AM
03/16/10 08:45 AM
That's the second chainplate breakage I've heard of...where exactly did it break? We've already inspected all of ours pretty thoroughly just last week.
Re: diamond wire turnbuckle hard to turn [Re: TeamChums] #205777
03/16/10 08:48 AM
03/16/10 08:48 AM
Lee ,
Did you replace your diamond wire yet?
Like Jake said The ping that was heard was most likely strands of wire parting. The 2 times I've heard that sound it was followed by a mast coming down.
Isak Dinesen
E. B. White
Re: diamond wire turnbuckle hard to turn [Re: Jake] #205778
03/16/10 08:55 AM
03/16/10 08:55 AM
andrewscott
andrewscott
I saw a chainplate (just like the hobie's use)break on a supercat 19, 2 summers ago.
I had a chainplate/tang break on me this past christmas day (pic below) ... i replaced both sides... and both had cracks... can't wait for the bow tangs to go... uggggg
Re: diamond wire turnbuckle hard to turn [Re: Team_Cat_Fever] #205781
03/16/10 09:04 AM
03/16/10 09:04 AM
Portland, Maine
Portland, Maine
In 2008, after the long, 15TWS beat to weather from Jupiter to Cocoa beach - Trey told me that the "mast made some nasty noises all day".
6AM the next morning, Derek and I pulled the boat over on its side and saw three strands parted at the top of the forestay. Replaced it immediately and thank goodness since the last leg to Tybee was a particularly nasty leg.
Note to Tybee sailors - tell your ground crews about the sounds you hear. These things are important since ground crews typically wont automatically inspect the top of the mast.
Re: diamond wire turnbuckle hard to turn [Re: ThunderMuffin] #205845
03/16/10 07:23 PM
03/16/10 07:23 PM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
A lotta good info here, good to share with all !!!
My 14 Hobie did that years ago ( my first cat) I'd better check my 17 & 18 this year.....
~17,18 Hobies,
~2 Kayaks~
Re: diamond wire turnbuckle hard to turn [Re: TeamChums] #205941
03/17/10 01:58 PM
03/17/10 01:58 PM
Austin, TX
BoK Offline
BoK  Offline
Austin, TX
better to be lucky than good Lee!
Bo Kersey
Corsair 31-1D 276
0 registered members (), 16,952 guests, and 774 spiders.
Most Online22,490
7 hours ago
