| Re: Tuning for Ullman Sails
[Re: bulldogbarber]
#206641 03/25/10 03:57 AM 03/25/10 03:57 AM |
Posts: 9,582 North-West Europe | Not many sailors did alot of tuning with the Ullman rig. It was replaced relatively quickly by other makes.
Try :
Matt McDonald of Falcon Marine Paul Warren or Geert Ruesink
These are the ones who fiddled about the most with the Ulman sails.
[Re: Wouter]
#206647 03/25/10 06:16 AM 03/25/10 06:16 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | From my times competing against Paul on the Blade he much preferred using his Ullman whilst solo and Landenberger when two up. His Ullman main was probably manufactured in 2006. I have been racing really closely to Paul and a major difference to his speed came as much from the correct mast rotation as did from the downhaul, mainsheet tension so I would bare that in mind whilst adjusting your rig. As for his exact settings I'm not sure but he'll let us know if he can remember them. He has a new Falcon occupying his mind at present. MP*MULTIHULLS | | | Re: Tuning for Ullman Sails
[Re: bulldogbarber]
#206650 03/25/10 07:12 AM 03/25/10 07:12 AM |
Posts: 5,525 | Come on down to Gulfport if you get the chance. There will be lots of folks you can compare notes with.
Pete Pollard Blade 702
[Re: bulldogbarber]
#206657 03/25/10 08:47 AM 03/25/10 08:47 AM |
Posts: 5,525 | Spring fever is too cold for me. And I'll be busy getting ready for Gulfport.
Keep in mind, to race in the Nationals requires certification and class membership; total of $75.
You're welcome to come down, we hope to see you.
[Re: pgp]
#206664 03/25/10 09:20 AM 03/25/10 09:20 AM |
Joined: Nov 2005 Posts: 15 Hartwell, Ga bulldogbarber OP
Posts: 15 Hartwell, Ga | Can I take care of all that once I get there?
[Re: bulldogbarber]
#206665 03/25/10 09:23 AM 03/25/10 09:23 AM |
Posts: 5,525 | Sure. Certification takes time so the earlier you arrive the better.
Let me know when you plan on arriving.
[Re: bulldogbarber]
#206707 03/25/10 12:34 PM 03/25/10 12:34 PM |
Posts: 465 Oxford, UK | I'd like to compare notes with Paul though, as I'll be racing uni most of the time. As Mark says, I used the Ullman for single handing, as the newer Landy that I bought had a deliberately full cut for 2-up sailing, and I always found the Ullman very quick when 1-up. I'm afraid my tuning isn't particularly scientific. Upwind: I adjust the mast rotation so that the back of the sail and the back of the mast form a nice smooth curve, and then generally leave it alone. I find that the big one to get right is the downhaul. I generally try to go upwind by making very small steering movements, rather than by playing the mainsheet (more through laziness than any belief that it's quicker). If you find yourself luffing significantly to get the hull down in the gusts, it's time for more downhaul. On a number of occasions I've found more speed by using more download than I thought I needed, footing off a bit and going for boat speed. I spent a lot of time racing the Stealths, and never out pointed them, but often got them on VMG by going lower and faster. Downwind: again, I do it more on the steering than the sheeting. Cleat the main, quite loosely when light, hard when it's blowing, and then sail to the kite. Don't be afraid to go really high in the light stuff to get some boat speed. Paul | | |
899
guests, and 30
