Infusion mainsheet reeving #206851
03/26/10 06:13 PM
03/26/10 06:13 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
The online manual (older) for the Infusion setup does not show the same blocks that actually ship with the boat now (HC8454 on the traveler up to HC7668 on the boom). Has anyone found a reeving diagram that is helpful?
Thanks
Re: Infusion mainsheet reeving [Re: uogecko] #206852
03/26/10 06:15 PM
03/26/10 06:15 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
This is the system that shipped with the Infusion: http://www.harken.com/OneDesign/tornado.php
This is the best picture I can find, but it's almost impossible to follow:
http://www.murrays.com/mm5/merchant...&Category_Code=N-C&Store_Code=MS
Re: Infusion mainsheet reeving [Re: uogecko] #206925
03/27/10 12:30 PM
03/27/10 12:30 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Remember that the top block should be at 90 degrees to the main lower block, every one tries to line them up above each other
Re: Infusion mainsheet reeving [Re: TEAMVMG] #206932
03/27/10 01:10 PM
03/27/10 01:10 PM
Southampton UK
NacraKid Offline
NacraKid  Offline
Southampton UK
as macca told me "work in towards the guts!"
First bit is the hardest to work out if you don't know how to do it, the old system on the manual and this new one reve up the same at first except that the double in the middle has been moved out to each side.
Re: Infusion mainsheet reeving [Re: NacraKid] #206933
03/27/10 02:36 PM
03/27/10 02:36 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Thanks but I was really hoping to find a clear diagram. I do know that the top blocks should be perpendicular to the lower blocks but both top and bottom should rotate freely, right? Harken includes little metal "limiters" that can be used to keep them from rotating. I know I'll want the lower blocks to rotate freely but what about the uppers?
Re: Infusion mainsheet reeving [Re: uogecko] #206951
03/28/10 02:06 AM
03/28/10 02:06 AM
Budapest, Hungary, Europe
CatSailingHu Offline
remove the small metal limiter...
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Infusion mainsheet reeving [Re: CatSailingHu] #206962
03/28/10 09:21 AM
03/28/10 09:21 AM
Australia
macca Offline
macca  Offline
Australia
Good question guys....
When we did the manual it was prior to the newer style Harken blocks coming out.
I will see if I can get a new demo done up.
________________________
http://aus300.blogspot.com
Re: Infusion mainsheet reeving [Re: macca] #206963
03/28/10 09:28 AM
03/28/10 09:28 AM
Australia
macca Offline
macca  Offline
Australia
As a tip in the meantime:
Always have the top block at 90deg to the bottom one.
Start at the cleat (through the ratchet backwards)
go through the back sheave on the top block
then on the side sheave on the bottom (from the back side towards the front)
then to the front sheave on the top block
then to the bottom block (side, line goes from front to back)
from here its herd to go wrong, you just follow your way from the back towards the front.
Re: Infusion mainsheet reeving [Re: macca] #206973
03/28/10 11:27 AM
03/28/10 11:27 AM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
A new guide would be awesome! Meanwhile thanks for the tip!
Re: Infusion mainsheet reeving [Re: uogecko] #207059
03/29/10 01:04 PM
03/29/10 01:04 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Harken just sent me a 10:1 reeving guide for the Infusion mainsheet setup I have. It's too big to attach to this post so let me know if you want it and I can email it to you.
Re: Infusion mainsheet reeving [Re: uogecko] #247910
05/07/12 03:10 PM
05/07/12 03:10 PM
World Citizen
JFR Offline
JFR  Offline
World Citizen
Sorry for asking. Have my boat miles away and need to order new mainsheet. What length are you using (I remember it to be 13.5 meter? but it sounds lengthy) provided you use it back-to-back. Also, am I right in assuming tapering would be arround 3 meters to be able to lock it upwind in full swing and outside tapered area (using normal mast rake).
Cheers,
Jonas
JFR
Infusion Mk2
Re: Infusion mainsheet reeving [Re: uogecko] #249315
06/07/12 01:37 AM
06/07/12 01:37 AM
southern germany
stampede Offline
stampede  Offline
southern germany
hope this helps
http://www.harken.com/pdf/4450.pdf
cheers from germany
in case you are looking for a 10:1 combo i can provide a diagram on request.
cheers from germany
Re: Infusion mainsheet reeving [Re: uogecko] #249473
06/12/12 09:45 AM
06/12/12 09:45 AM
Just Sail Offline
Just Sail  Offline
Here is a reeving diagram for the infusion mainsheet system. Its a reworked of the original.pdf version that Uogecko sent me last year, now in .jpg
Re: Infusion mainsheet reeving [Re: uogecko] #258962
04/15/13 04:04 PM
04/15/13 04:04 PM
southern germany
stampede Offline
stampede  Offline
southern germany
Anyone Here To provide some advice on harken 378&379 12:1 mainsheet combo reeving Diagramm?
All help is appreciated
Greetings Form germany
Re: Infusion mainsheet reeving [Re: stampede] #258975
04/16/13 08:30 AM
04/16/13 08:30 AM
Just Sail Offline
Just Sail  Offline
http://www.murrays.com/mm5/merchant...roduct_Code=28-121&Category_Code=N-C
Very confusing but perhaps you can make it out from this diagram...failing that send an email to Harken
0 registered members (), 16,262 guests, and 1,190 spiders.
Most Online22,490
Yesterday at 08:14 AM
